楼主 #1 2018-03-15 09:20:40
F1F2
已发帖子: 99
吐槽keil 5.24a 的错误: Error: Encountered an improper argument
5.14 官方就发现了这个问题,提供了补丁, 但是 5.24a 又老毛病又犯了.
http://www.keil.com/support/docs/3795.htm
SYMPTOM
When a new µVision project is created with Project - New µVision Project... and a project is already loaded, it is possible that µVision reports the error Encountered an improper argument under some circumstances for specific microcontrollers. Under Windows XP it is even possible that µVision crashes in this situation.
CAUSE
There was an issue in µVision version 5.14.2.0 which has been identified and fixed.
RESOLUTION
Download the attached file and extract it to the folder C:\Keil_v5\UV4. If you have installed PK51 to a different folder, you need to adapt the path accordingly. The file UV4.exe is replaced with version 5.14.2.1.
PK51 versions later than 9.54a will include this µVision update.
Request the files attached to this knowledgebase article.
楼主 #2 2018-03-15 09:21:46
F1F2
已发帖子: 99
Re: 吐槽keil 5.24a 的错误: Error: Encountered an improper argument
这个问题调一个小时 RT1052代码,
可以出现好几次,怎么都关不掉,只能在任务管理器暴力关掉!
