楼主 #1 2020-08-20 14:08:51
淡定
已发帖子: 21
为了V3S不吃灰,移植NES游戏
一.硬件准备工作:
1.lichee pi zero主板一块
2.无线手柄2.4g一个
3.屏幕800x480
4.xt25f128b spiflash一块,焊接到板子上。(不用sd启动,看着别扭)
二.软件准备工作:
1.参考各个大神文章,uboot,linux,buildroot
简单说明一下需要修改的地方:
u-boot:
include/configs/sun8i.h
    #define CONFIG_BOOTCOMMAND  "sf probe 0:0 6000000; " \
			     "sf read 0x41800000 0x80000 0x4000; " \
			     "sf read 0x41000000 0x90000 0x470000;" \
			     "bootz 0x41000000 - 0x41800000;"
    #define CONFIG_BOOTARGS     "console=ttyS0,115200 earlyprintk panic=5 rootwait
    mtdparts=spi32766.0:512k(uboot),64k(dtb)ro,4544k(kernel)ro,-(rootfs) root=/dev/mtdblock3 rw rootfstype=jffs2 init=/linuxrc
    vt.global_cursor_default=0"
/u-boot/drivers/mtd/spi/spi_flash_ids.c
   {"xt25f128b", INFO(0x0b4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) },
  1. linux:
    dts:
   &spi0 {
        status ="okay";
        xt25f128b:xt25f128b@0 {
                compatible = "jedec,spi-nor";
                reg = <0x0>;
                #address-cells = <1>;
                #size-cells = <1>;
/linux/drivers/mtd/devies/m25p80.c
搜jedec 在最后增加xt25定义
   {"w25q80bl"}, {"w25q128"}, {"w25q256"}, {"xt25f128b"}
  1. /linux/drivers/mtd/spi-nor
    flash_info spi_nor_ids[]中
   { "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, 0) },
   { "xt25f128b", INFO(0x0b4018, 0, 64 * 1024, 256, 0) },
menuconfig:
  • 加入SPI Flash的支持
    Device Drivers  --->
	<x> Memory Technology Device (MTD) support  --->
 		<x>   Command line partition table parsing   (用以支持命令行参数 mtdparts=spi0.0:512k(uboot)ro, … )
		<x>   Caching block device access to MTD devices
		<x>   SPI-NOR device support  --->
			 [ ]   Use small 4096 B erase sectors  	(取消这个选型,否则jffs2文件系统会报错)
  • 加入jffs2文件系统支持
     File systems  --->
	[x] Miscellaneous filesystems  --->
		<x>   Journalling Flash File System v2 (JFFS2) support
  		(0)     JFFS2 debugging verbosity (0 = quiet, 2 = noisy)
  		[x]     JFFS2 write-buffering support
  		[ ]       Verify JFFS2 write-buffer reads
		[ ]     JFFS2 summary support
  		[ ]     JFFS2 XATTR support
  		[ ]     Advanced compression options for JFFS2
4.编译:(u-boot,linux)
   make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j2
   make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- dtbs
生成的文件:
    $ ls -lh arch/arm/boot/zImage
    -rwxrwxr-x 1 xlee xlee 4.2M Apr 23 10:41 arch/arm/boot/zImage
    $ ls -lh arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dtb
    -rw-rw-r-- 1 xlee xlee 12K Apr 22 23:33 arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dtb
5.build-root
ls -l ~/buildroot-2017.08/output/images/rootfs.tar
tar 解压rootfs.tar到目录rootfs_20200820/
拷贝linux下的lib(包含module)文件夹内容到此目录,也可以添加用同样的编译编译出来的一些程序,比如InfoNes文件等
mkfs.jffs2 -s 0x100 -e 0x10000 --pad=0xAF0000 -d rootfs_20200820/ -o rootfs.jffs2
三:烧录
下载sunxi-fel 编译直接在ubuntu上烧
分区如下:
    0~0x80000              uboot
    0x80000~ 0x90000  dtb
    0x90000~ 0x500000 zImage
    0x50000~ 16M         rootfs.jffs2
短接板子spi的cs脚和地
烧录命令跑起来:
    $sudo ./sunxi-fel -p spiflash-write 0 u-boot-sunxi-with-spl.bin
    $sudo ./sunxi-fel -p spiflash-write 0x80000 sun8i-v3s-licheepi-zero-dock.dtb
    $sudo ./sunxi-fel -p spiflash-write 0x90000 zImage
    $sudo ./sunxi-fel -p spiflash-write 0x500000 rootfs.jffs2
四: 编译InfoNes
下载源码:https://github.com/nejidev/arm-NES-linux
在linux目录下修改Makefile:编译器,alsa(暂时去掉)
编译完的InfoNes拷贝到rootfs_20200820,重新生成rootfs.jffs2,
或者拷贝到sd卡,用挂载mount /dev/mmcblk0p1 /mnt/拷贝文件到板子
再到网上下载nes游戏,拷贝到sd卡
愉快的运行起来。
INfoRun
五: 待解决问题:
1.声音
2.遥控器
楼主 #2 2020-08-20 14:25:10
淡定
已发帖子: 21
Re: 为了V3S不吃灰,移植NES游戏
占位: 无线遥控器
楼主 #3 2020-08-20 14:25:34
淡定
已发帖子: 21
占位:声音
楼主 #4 2020-08-20 17:15:19
淡定
已发帖子: 21
---- 继续 ----
六.声音调试:
  1. 下载tinyalsa git clone https://github.com/tinyalsa/tinyalsa.git
    修改makefile的交叉编译工具链,make 生成几个文件
    拷贝到sd卡,执行命令:
# ./tinymix set 1 63
# ./tinymix set 2 1
# ./tinymix contents
因为只买了核心板,没有耳机孔,根据官方的原理图飞了一个滤波电路.
音频调试
第1,3,5,7脚分别是HP_COM,HP_COMFB, HP_L, HP_R
./tinyplay SoundTest.wav
插上音响,可以听到清晰的声音。
下一步,将InfoNes的声音补上。
#5 2020-08-20 18:46:15
xyzijk
已发帖子: 31
能上传版TF烧录固件感受下?
#6 2020-08-20 21:21:03
armstrong
已发帖子: 295
感谢分享!infones-linux on lichee-zero
楼主 #7 2020-08-21 09:16:55
淡定
已发帖子: 21
xyzijk wrote:
能上传版TF烧录固件感受下?
只有spi flash版本,等我搞的差不多再上传。
#8 2020-08-21 10:57:43
房地产
已发帖子: 27
nes,tinyalsa
楼主 #9 2020-08-21 11:09:45
淡定
已发帖子: 21
七.遥控器搞起
玩游戏肯定少不了手柄,本来想用一个有线usb手柄,但是作为一个精益求精的玩家,这个长线是不能接受的,所以决定搞一个无线手柄。
1.在某宝买了一个无线2.4G游戏手柄,在windows下免驱的,
估计在zeros的linux上也有相关驱动,果然,在linux目录能找到相关驱动 ~/linux/drivers/hid/hid-dr.c
小技巧:插入电脑上找到设备管理器,属性,就能看到VID和PID号,查找一下驱动目录就能找到相对于的设备商。我买的遥控器是DragonRise Inc. game
controllers
在~/linux/drivers/hid/hid-core.c 添加PID号 0x181c
#if IS_ENABLED(CONFIG_HID_DRAGONRISE)
	{ HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, 0x0006) },
	{ HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, 0x0011) },
	{ HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, 0x181c) },
  1. linux menuconfig
    > Device Drivers > Input device support
    <*> Joystick interface
    [x] Joysticks/Gamepads --->
    > Device Drivers > HID support > Special HID drivers
    <*> DragonRise Inc. game controller
  2. 在InfoNes文件joypad_input.cpp 修改键值
    看实际情况,ABXY,左右上下,start,select
  • FC手柄 bit 键位对应关系 真实手柄中有一个定时器,处理 连A 连B
  • 0 1 2 3 4 5 6 7
  • A B Select Start Up Down Left Right
4.烧录完内核后,接上usb转接器,插上无线手柄接收器,愉快的玩起来。
[   26.946678] usb 2-1: new full-speed USB device number 4 using ohci-platform
[   27.213391] input: TGZ Controller as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.0/0003:0079:181C.0005/input/input6
[   27.224832] dragonrise 0003:0079:181C.0005: input: USB HID v1.11 Gamepad [TGZ Controller] on usb-1c1a400.usb-1/input0
[   27.240256] input: TGZ Controller as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:0079:181C.0006/input/input7
[   27.316983] dragonrise 0003:0079:181C.0006: input: USB HID v1.11 Device [TGZ Controller] on usb-1c1a400.usb-1/input1
# ls /dev/input/js0
/dev/input/js0
controler
#10 2020-08-21 12:33:36
jujiaqi
楼主可以啊,花了不少精力吧。
V3S 带800x480感觉怎么样,吃力吗
#11 2020-08-21 16:06:04
642242855
已发帖子: 213
我的也在吃灰中
楼主 #12 2020-08-21 16:17:13
淡定
已发帖子: 21
烧录文件:
licheepi zeros,密码用户名:root和licheepi
16M spi flash
800*480屏幕
licheezeros_spiflash_16M_LCD_800_480_InfoNes_tar.gz
#13 2020-08-21 16:24:55
有梦的地方
已发帖子: 284
楼主优秀,求手柄购买链接
楼主 #14 2020-08-21 16:32:45
淡定
已发帖子: 21
有梦的地方 wrote:
楼主优秀,求手柄购买链接
我在这家树莓派店买的(其他店的应该也可以,但是可能要调驱动)
fu置本段内容$rNCpcXhED59$达开τao寶【树莓派4B/3B+/Zero W 2.4G 摇杆无线游戏手柄街机游戏机配件】
#15 2020-08-21 17:02:41
已发帖子: 3,403
感谢楼主分享, 电脑版的可以打开这个链接: https://item.taobao.com/item.htm?id=581516829523
楼主 #16 2020-08-24 18:48:59
淡定
已发帖子: 21
---- 继续折腾一下这个游戏机 ------------
玩了几天,发现lcd屏幕太小了,眼睛看得很累。
所以把它的视频输出端接到投影仪上,大屏玩游戏,酷。。。
#17 2020-08-25 11:45:41
小智
已发帖子: 112
好牛
#18 2020-08-25 19:17:36
xyzijk
已发帖子: 31
详细, 牛XXX, 精彩!!!!
楼主 #19 2020-08-26 18:48:07
淡定
已发帖子: 21
---- 继续移植 wifi同屏功能------
准备工作:
scrcpy软件: https://github.com/Genymobile/scrcpy
rtl7823bs wifi模块
一. 安装编译工具 pip3,meson,ninja-build,re2c
curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
sudo apt-get install python3-pip
sudo pip3 install --upgrade pip
pip3 install --user meson
apt-get install ninjia-build
或者源码安装
git clone https://github.com/ninja-build/ninja
./configure.py --bootstrap
apt-get install re2c
如果碰到问题就按照出错地方修改。
二. 下载相关库源码,交叉编译scrcpy
ffmpeg,x264,xvid,sdl2
  1. xvid
    tar zxvf xvidcore-1.3.3.tar.gz
    cd xvidcore/build/generic
    ./configure --prefix=/root/ffmpeg/ --host=arm-linux-gnueabihf --target=arm-linux
    make -j 8
    make install
  2. x264
    tar jxvf last_x264.tar.bz2
    cd x264-snapshot-20161225-2245
    ./configure --prefix=/root/ffmpeg/x264_out --host=arm-linux-gnueabihf --enable-shared --disable-asm
    修改config.mak
    修改内容如下:
    CC=gcc 改为 CC=arm-linux-gnueabihf-gcc
    LD=gcc -o 改为 LD=arm-linux-gnueabihf-gcc -o
    RANLIB=ranlib 改为 RANLIB=arm-linux-gnueabihf-ranlib
    STRIP=strip 改为 STRIP=aarm-linux-gnueabihf-strip
  3. ffmpeg
    tar jxvf ffmpeg-3.0.2.tar.bz2
    cd ffmpeg-3.0.2/
    ./configure --prefix=/root/ffmpeg/out --disable-static --enable-shared --disable-debug --disable-asm --disable-ffplay --disable-ffprobe --disable-ffserver --enable-small --disable-doc --enable-demuxer=rtsp --enable-parser=h264 --enable-cross-compile --enable-libx264 --enable-libxvid --enable-nonfree --enable-gpl --arch=arm --target-os=linux --cross-prefix=arm-linux-gnueabihf- --extra-cflags=-I/root/ffmpeg/out/include --extra-ldflags=-L/root/ffmpeg/out/lib --extra-libs=-lrt
tar -zxvf SDL2-2.0.9.tar.gz
./configure --prefix=/root/scrcpy/sdl2 --host=arm-linux-gnueabihf --build=x86_64 --with-gnu-ld --disable-video-nanox --disable-video-qtopia --disable-pulseaudio --disable-video-photon --disable-video-ggi --disable-video-svga --disable-video-aalib --disable-video-dummy --disable-video-dga --disable-arts --disable-esd --disable-alsa --disable-video-x11 --disable-nasm --enable-joystick --disable-input-tslib --disable-video-fbcon
--留一个坑,后续再修改sdl源码,直接用linux framebuffer来显示图像
  1. 进入目录scrcpy-1.16
/root/.local/bin/meson c --buildtype release --strip -Db_lto=true -Dprebuilt_server=../scrcpy-server.jar --cross-file cross_file.txt
cross_file.txt 文件的内容是:
[binaries]
c = 'arm-linux-gnueabihf-gcc'
cpp = 'arm-linux-gnueabihf-g++'
ar = 'arm-linux-gnueabihf-ar'
strip = 'arm-linux-gnueabihf-strip'
pkgconfig = '/root/buildroot-2017.08/output/host/bin/pkg-config'
[host_machine]
system = 'linux'
cpu_family = 'arm'
cpu = 'FP-ARMv7'
endian = 'little'
[build_machine]
system = 'linux'
cpu_family = 'x86_64'
cpu = 'i686'
endian = 'little'
在编译之前首先把ffmpeg 和sdl2的库生成的pkg-config文件拷贝到L/root/buildroot-2017.08/output/host/arm-buildroot-linux-gnueabihf/sysroot/usr/lib
一切准备就绪,编译生成scrcpy文件
ninja all
  1. 用buildroot勾选adb工具,生成adb文件
    二. 板子运行
  2. 把adb和所有的用到的lib拷贝到板子。
  3. 接上手机,打开usb调试模式(多次点击设置->关于手机->版本号)
    Lsusb找到pid号
    写入到~/.android/adb_usb.ini文件
    Adb devices确认能找到手机设备
    配置库路径,先录一个视频看看效果
    export LD_LIBRARY_PATH=/mnt/scrcpy/lib:/mnt/ffmpeg/lib
    ./scrcpy -N -m 800 -b 1M --max-fps 15 --rotation
    1 --window-height 480 --window-width 800 -r scr_test.mp4
三. rtl8723bs wifi模块
为了给tf留sdc0的接口,把它焊接到sdc1位置。
按照一般的做法就能正常使用,没有什么需要特别注意的地方
  1. linux make menuconfig选择drivers/ staging里面的rtl8723bs
  2. buildroot下面的wpa_supplicant工具,
  3. 然后make,刷rootfs或者直接拷贝相关文件到sd卡,rtl8723bs_nic.bin到/lib/firmware/rtlwifi/目录下。
  4. 愉快地运行起来:
    修改wpa_supplicant.conf里面的ssid和psk
insmod /lib/modules/4.13.0-licheepi-zero\+/kernel/drivers/staging/rtl8723bs/r8
723bs.ko
ifconfig wlan0 up
./wpa_supplicant -Dnl80211 -iwlan0 -c /root/rtl8723/wpa_supplicant.conf -B
udhcpc -iwlan0 &
 [  873.649642] RTL8723BS: nolinked power save leave
[  875.646510] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
# [  875.960288] RTL8723BS: start auth
[  876.017289] RTL8723BS: auth success, start assoc
[  876.052762] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  876.059904] RTL8723BS: assoc success
# [  877.599630] RTL8723BS: rtw_tkip_decrypt(wlan0) no_gkey_bc_cnt:9, no_gkey_mc_cnt:0
[  878.170886] RTL8723BS: send eapol packet
[  878.199958] RTL8723BS: send eapol packet
[  878.204510] RTL8723BS: set pairwise key camid:4, addr:28:6c:07:6c:b1:3a, kid:0, type:AES
[  878.217725] RTL8723BS: set group key camid:5, addr:28:6c:07:6c:b1:3a, kid:1, type:TKIP
[  878.226179] RTL8723BS: rtw_tkip_decrypt(wlan0) gkey installed. no_gkey_bc_cnt:2, no_gkey_mc_cnt:0
# udhcpc: sending discover
udhcpc: sending select for 192.168.31.197
udhcpc: lease of 192.168.31.197 obtained, lease time 43200
deleting routers
adding dns 192.168.31.1
#20 2020-08-27 09:19:45
木子猫
已发帖子: 63
这个小投影仪好像很香的样子 tongue
#21 2020-08-27 09:20:38
jkl
已发帖子: 269
厉害,收藏一下
#22 2020-08-31 08:35:40
有梦的地方
已发帖子: 284
楼主优秀
#23 2020-08-31 17:24:56
下雨了
实然有了学习的冲动。感谢。
#24 2020-09-05 20:28:33
TeveT
已发帖子: 149
这投影仪咋这么完美接上? 某宝有?
#25 2020-09-06 22:12:28
775624981
已发帖子: 22
大佬,位在nuc972上直接编译了试了试,为什么色彩不正常呢,运行正常但是颜色是乱的,fb是rgb565,搞了半天都不行
#26 2020-10-11 12:12:01
shawn.d
已发帖子: 164
这真是折腾成专家了。等有空我也耍耍这个。
#27 2020-10-12 11:16:53
capricorn
优秀
#28 2020-10-12 20:26:45
tcy641
很不错,受教了
#29 2020-10-20 13:15:48
nianyan99
羨幕.
#30 2020-10-26 20:56:04
hongadg
学习了
#31 2020-11-03 06:12:38
TivonLiu
已发帖子: 53
感谢,我要好好学习了。
#32 2020-11-10 20:31:04
山羊胡子
已发帖子: 22
太牛了,我也尝试下
#33 2020-11-12 15:59:10
kaixxss
已发帖子: 30
厉害了
#34 2020-11-13 16:50:34
zpyws
已发帖子: 33
突然有了学习的冲动
#35 2020-12-20 14:19:23
leefei
已发帖子: 53
淡定 wrote:
占位: 无线遥控器
请问声音搞定了吗
#36 2020-12-21 00:54:39
leefei
已发帖子: 53
淡定 wrote:
占位:声音
我有一套源码。声音正常。但是颜色不对。由于没有手柄。键盘用不了,不知怎么调
#37 2020-12-24 22:26:41
pichen
说实话,太牛X了,等我先把板子跑起来再说。。。。。
#38 2020-12-26 17:09:04
小智
已发帖子: 112
牛逼
#39 2021-01-22 11:23:59
卓林
已发帖子: 84
leefei wrote:
淡定 wrote:
占位:声音
颜色不对的问题可以解决,我的也是,屏幕泛蓝色。
1.framebuff颜色宽度设置错误,默认InfoNES颜色位宽16bit,所以RGB颜色前后8位被丢了,只剩下蓝色和绿色。
2.修改方法
打开源码 /linux/InfoNES_System_Linux.cpp
添加 全局变量 ,修改函数
long int lcd_bits_per_pixel;
static int lcd_fb_display_px(WORD color, int x, int y)
	unsigned char  *pen8;
	pen8 = (unsigned char *)(fb_mem + y*line_width + x*px_width);
    if(lcd_bits_per_pixel==32)
        (unsigned int*)pen8=color;//32bit
        (unsigned short*)pen8=color;//16bit
修改函数
static int lcd_fb_init()
	//如果使用 mmap 打开方式 必须是 读定方式
	fb_fd = open("/dev/fb0", O_RDWR);
	if(-1 == fb_fd)
		printf("cat't open /dev/fb0 \n");
		return -1;
	//获取屏幕参数
	if(-1 == ioctl(fb_fd, FBIOGET_VSCREENINFO, &var))
		close(fb_fd);
		printf("cat't ioctl /dev/fb0 \n");
		return -1;
	//计算参数
	px_width     = var.bits_per_pixel / 8;
    lcd_bits_per_pixel=var.bits_per_pixel;
	line_width   = var.xres * px_width;
	screen_width = var.yres * line_width;
	lcd_width    = var.xres;
	lcd_height   = var.yres;
	printf("fb width:%d height:%d \n", lcd_width, lcd_height);
	fb_mem = (unsigned char *)mmap(NULL, screen_width, PROT_READ | PROT_WRITE, MAP_SHARED, fb_fd, 0);
	if(fb_mem == (void *)-1)
		close(fb_fd);
		printf("cat't mmap /dev/fb0 \n");
		return -1;
	//清屏
	memset(fb_mem, 0 , screen_width);
其实就是加了个参数区分是16位宽还是24位,还没试,应该可以:P
最近编辑记录 卓林 (2021-01-22 11:24:57)
#40 2021-01-22 11:29:41
卓林
已发帖子: 84
抛砖引玉,有没有人试过ps3手柄,我在内核开启了Microsoft微软的HID支持,在Microsoft的PID列表里边添加了我这个手柄的PID,但是还是识别不到手柄,插上去之后控制台也没有输出,晚点我把开机log中关于usb的信息贴上来,看看有人能知道什么情况吗?
#41 2021-02-04 08:21:02
random_name
离题: 大佬手机上的 下厨房 体现了大佬是个热爱生活的人。
#42 2021-02-04 09:27:00
已发帖子: 649
也可以参考我这个贴子 https://whycan.com/t_5913.html 的说明,修改InfoNES中调色板的数组NesPalette,改成RGB888的
#43 2021-02-04 22:58:21
mzy2364
已发帖子: 43
大佬你好,按照你的帖子,InfoNES移植成功了,也可以看到 /dev/input/js0了,但是运行后手柄没有反应,用joystick软件是可以看到手柄的信息的,请问该怎么处理呢?
#44 2021-02-04 23:44:55
mzy2364
已发帖子: 43
解决了,是键值的问题,打印出来再改下源码就好了
#45 2021-03-07 12:06:16
夜空中最亮的灯
已发帖子: 26
请教个问题,声音滞后怎么解决?
#46 2021-04-21 15:27:49
jkl
已发帖子: 269
/files/members/4891/_20200824184516.jpg
厉害了,这个投影仪模块是个什么情况,怎么弄得,有现成的买吗,也想整一个
#47 2021-04-30 16:15:11
nikoladi
已发帖子: 27
这个投影仪多大分辨率啊?
#48 2021-05-15 02:11:39
Licheepi
四: 编译InfoNes
这个alsa 怎么去掉啊,我make后编译不了
#49 2021-06-14 23:46:51
酷酷酷
已发帖子: 48
Licheepi wrote:
四: 编译InfoNes
可以参考我的文章:
https://blog.csdn.net/qq_46604211/article/details/117914263?spm=1001.2014.3001.5501
#50 2021-07-03 15:13:47
6756bsdfsd
还能跑得动游戏?
#51 2021-07-03 15:55:27
6756bsdfsd
  • 不通过:与技术无关
#52 2021-07-04 10:38:06
995pc
已发帖子: 54
超级玛丽,马里奥,采蘑菇
#53 2021-07-05 14:50:37
sunxiang
已发帖子: 222
有兄弟向我一样一直不能移植成功的,可以试试通过QT移植。我用QT4跑INFONES还是比较流畅的,,
#54 2021-07-05 14:51:43
sunxiang
已发帖子: 222
这个硬件我也设计了一版,由于没有经验,用是可以用,但是供电还是有点问题。
#55 2021-08-19 16:59:23
surz168168
已发帖子: 0
  • 不通过:其他
#56 2021-08-19 17:33:56
mikasa
  • 不通过:与技术无关
#57 2021-09-19 19:00:11
卓林
已发帖子: 84
F1C100s的朋友谨慎尝试吧,移植后游戏卡的飞起,人物动作比模拟器慢的多,基本没法玩,换个性能好的cpu再试试。
#58 2021-10-28 14:28:37
xel
大佬这个投影模块有资料吗?
#59 2023-02-16 20:08:41
vigour1000
已发帖子: 103
adb可以使用吗
#60 2023-02-19 12:09:56
soso
已发帖子: 148
同问:大佬这个投影模块有资料吗?
看上这个投影模块了~
#61 2023-02-19 12:10:08
soso
已发帖子: 148
同问:大佬这个投影模块有资料吗?
看上这个投影模块了~
#62 2023-02-20 16:25:25
naypt
同问:大佬这个投影模块有资料吗?
看上这个投影模块了~
#64 2023-05-28 00:02:20
果子李
v3s流畅度怎么样
#65 2023-05-29 08:45:26
已发帖子: 1,409
我修改linux目录下的makefile,想在t113-s3板上运行。
# CC = arm-linux-gcc
CC = arm-openwrt-linux-gcc
TARBALL = InfoNES08J
# InfoNES
.CFILES =	./../K6502.cpp \
		./../InfoNES.cpp \
		./../InfoNES_Mapper.cpp \
		./../InfoNES_pAPU.cpp \
		./InfoNES_System_Linux.cpp joypad_input.cpp
.OFILES	=	$(.CFILES:.cpp=.o)
CCFLAGS =  -O2 -fsigned-char -I/home/any/MPU/AllWinner/T113-s3/Tina-Linux/out/t113-mq_r/staging_dir/target/usr/include
LDFILGS = -lstdc++		# gcc3.x.x
LIBS += -L/home/any/MPU/AllWinner/T113-s3/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-glibc/toolchain/lib -lpthread -lm
LIBS += -L/home/any/MPU/AllWinner/T113-s3/Tina-Linux/out/t113-mq_r/staging_dir/target/usr/lib -lasound -lz
all: InfoNES
InfoNES: $(.OFILES)
	$(CC) $(INCLUDES) -o $@ $(.OFILES) $(LDFILGS) $(LIBS)
	# $(CC) $(INCLUDES) -o $@ $(.OFILES) $(LDFILGS) -L/home/any/MPU/AllWinner/T113-s3/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-glibc/toolchain/lib -lm -lpthread -L-L/home/any/MPU/AllWinner/T113-s3/Tina-Linux/out/t113-mq_r/staging_dir/target/usr/lib -lz -lasound
.cpp.o:
	$(CC) $(INCLUDES) -c $(CCFLAGS) $*.cpp  -o $@
clean:
	rm -f $(.OFILES) ../*~ ../*/*~ core
cleanall:
	rm -f $(.OFILES) ../*~ ../*/*~ core InfoNES
release: clean all
tar:
	( cd ..; \
	tar cvf $(TARBALL).tar ./*; \
	gzip $(TARBALL).tar \
install:
	install ./InfoNES /usr/local/bin
结果在板子上运行后有如下提示,然后屏幕黑屏。
# ./InfoNES
/dev/joypad dev not found
/dev/input/js0 dev not found
fb width:800 height:480
#67 2023-05-31 15:36:44
已发帖子: 1,409
void InfoNES_LoadFrame()
    int x,y, i;
    int line_width;
    WORD wColor;
    //修正 即便没有 LCD 也可以出声
    if(0 < fb_fd)
        for (y = 0; y < lcd_height; y++ )
            line_width = zoom_y_tab[y] * NES_DISP_WIDTH;
            for (x = 0; x < lcd_width; x++ )
                wColor = WorkFrame[line_width  + zoom_x_tab[x]];
                lcd_fb_display_px(wColor, x, y);
                printf("x:%d, y:%d, color:%d, index:%d\r\n", x, y, wColor, line_width + zoom_x_tab[x]);
                // for (i = 0; i < 255; i++)
                    // printf("%d\r\n", WorkFrame[i]);
InfoNES_LoadFrame()这个函数里,我将每个像素点的wColor打印出来,结果都是0。
甚至将WorkFrame[]数组的前255个成员打印出来,结果也是0。
这是哪里出错了?
最近编辑记录 Gentlepig (2023-05-31 15:41:08)
#68 2023-06-01 10:07:49
soso
已发帖子: 148
默默跟进t113~
楼主 #70 2023-06-24 23:11:19
淡定
已发帖子: 21
naypt wrote:
同问:大佬这个投影模块有资料吗?
看上这个投影模块了~
网上没有卖,自己手工打造的模块。
最近在搞人工智能,有一起学习的不?
#72 2023-06-27 16:00:51
wj8331585
已发帖子: 44
大佬这个投影模块有资料吗?
#73 2025-11-06 20:18:34
与非门
已发帖子: 38
焊接spi flash的话 裸机怎么写程序【从0开始】?/调试
