楼主 #1 2018-10-10 16:31:33
lilo
已发帖子: 215
基于STL的内存池类 和 测试程序 在linux下已做过稳定性测试
一共三个文件:
MemPool.h
#ifndef MEMPOOL.H
#define MEMPOOL.H
#include <pthread.h>
#include <stdio.h>
#include <list>
#include <iostream>
using namespace std;
//  when you have used the mem, call InsertFreeItem
#define DEFAULT_MEM_COUNT  32
template <class TYPE>
class CMemPool
public:
	CMemPool(void);
	 ~CMemPool(void);
	int Init(int memCount=DEFAULT_MEM_COUNT);
	void Fini();
	int GetFreeMemCount(){return  m_nFreeMemItemCount;};
	TYPE* GetFreeMem();
	void  InsertFreeMem(TYPE* pItem);
	int GetUseMemCount(){return m_nUseMemItemCount;};
	TYPE* GetUsedMem();
	void  InsertUsedMem(TYPE* pItem);
private:
	int m_bInit;
	int m_nMemSize;
	int m_nMemItemCount;
	int m_nFreeMemItemCount;
	int m_nUseMemItemCount;
	pthread_mutex_t  m_freeListCs;
	list<TYPE*>   m_freeMemList;
	pthread_mutex_t  m_useListCs;
	list<TYPE*>   m_useMemList;
// implention
CMemPool<TYPE>::CMemPool(void)
    m_bInit=0;
	m_nMemItemCount=DEFAULT_MEM_COUNT;
	m_nFreeMemItemCount=m_nMemItemCount;
	m_nUseMemItemCount=0;
	pthread_mutex_init(&m_freeListCs,0);
	pthread_mutex_init(&m_useListCs,0);
CMemPool<TYPE>::~CMemPool(void)
	pthread_mutex_destroy(&m_freeListCs);
	pthread_mutex_destroy(&m_useListCs);
int CMemPool<TYPE>::Init(int memCount)
	if (m_bInit)
	if (memCount<=0)
	    return -1;
	for (int i = 0; i<memCount; i++)
	    TYPE* pMemItem=new TYPE;
		if (0!=pMemItem)
		    pthread_mutex_lock(&m_freeListCs);
			m_freeMemList.push_back(pMemItem);
			pthread_mutex_unlock(&m_freeListCs);
		    return -1;
	m_nMemItemCount=memCount;
	m_nFreeMemItemCount=memCount;
	m_bInit=1;
void CMemPool<TYPE>::Fini()
    if (!m_bInit)
        return;
	for (class list<TYPE *>::iterator itor = m_freeMemList.begin(); itor!=m_freeMemList.end(); itor++)
	    TYPE* pItem=*itor;
		delete pItem;
		itor = m_freeMemList.erase(itor);
	pthread_mutex_lock(&m_useListCs);
	for (typename list<TYPE*>::iterator itor = m_useMemList.begin(); itor!=m_useMemList.end(); itor++)
	    TYPE* pItem=*itor;
		delete  pItem;
		itor = m_useMemList.erase(itor);
	pthread_mutex_unlock(&m_useListCs);
	m_bInit=0;
TYPE* CMemPool<TYPE>::GetFreeMem()
	int nListSize=m_freeMemList.size();
	if (nListSize>0)
	    TYPE* pItem=m_freeMemList.front();
		m_freeMemList.pop_front();
		m_nFreeMemItemCount--;
		return pItem;
    return NULL;
void  CMemPool<TYPE>::InsertFreeMem(TYPE* pItem)
	if (NULL==pItem)
	    return;
	m_freeMemList.push_back(pItem);
	m_nFreeMemItemCount++;
TYPE* CMemPool<TYPE>::GetUsedMem()
	int nListSize=m_useMemList.size();
	if (nListSize>0)
	    TYPE* pItem=m_useMemList.front();
		m_useMemList.pop_front();
		m_nUseMemItemCount--;
		return pItem;
    return NULL;
void  CMemPool<TYPE>::InsertUsedMem(TYPE* pItem)
	if (NULL==pItem)
	    return;
	m_useMemList.push_back(pItem);
	m_nUseMemItemCount++;
#endif /* MEMPOOL.H */
MemPoolTest.cpp
#include "MemPool.h"
typedef struct FRAME_ITEM
    int nBufLen;
	char* pBuf;
	FRAME_ITEM()
	 	 pBuf=new char[32*1024];
		 nBufLen=32*1024;
	~FRAME_ITEM()
	    if (0!=pBuf)
	        delete pBuf;
}FRAME_ITEM;
int main()
	CMemPool<FRAME_ITEM> pool;
	int nRet=pool.Init();
	if (nRet!=0)
	    printf("init failed \n");
	int n=100;
	while (n)
		FRAME_ITEM* pItem=pool.GetFreeMem();
		printf("free item num %d \n",pool.GetFreeMemCount());
		pool.InsertUsedMem(pItem);
		printf("used item num %d \n",pool.GetUseMemCount());
		pItem=pool.GetUsedMem();
		pool.InsertFreeMem(pItem);
		usleep(10*1000);
		n--;
	pool.Fini();
	getchar();
Makefile
#INCLUDE := ./*.h
CFLAGS =
SRC = *.cpp
LIB = -lpthread
BIN = test
all:
	g++ -o ${BIN} ${CFLAGS} ${SRC} ${LIB} -g
clean:
	rm ${BIN}
install:
	cp ${BIN} /bin/
uninstall:
	rm -rf /bin/${BIN}
.PHONY:
	all clean install uninstall
