参考链接1: 2d绘图引擎 Cairo 在 V3s@Linux运行成功
参考链接2: 2d绘图引擎 Cairo 在 SDL@Ubuntu 运行成功
参考cairo 绘图引擎和buildroot帖子:
打开buidroot根目录下 .config 文件,开启:
BR2_PACKAGE_CAIRO=y
BR2_PACKAGE_PIXMAN=y
接下来直接make即可.
打包部分 lib 文件:
cd /disk4/buildroot-2017.08.1/output/host/arm-buildroot-linux-gnueabi/sysroot
tar cvf /mnt/hgfs/E/libcairo.tar ./usr/lib/libcairo ./usr/lib/engines/lib ./usr/lib/libpixman-1. ./usr/lib/libfontconfig. ./usr/lib/libexpat. ./usr/lib/libfreetype. ./usr/lib/libatomic.*
下载解压缩到目标板子:
tftp 192.168.1.99 -g -r libcairo.tar;
tar xvf libcairo.tar -C /;
下载一个 cairo 应用源码 https://raw.githubusercontent.com/toradex/cairo-fb-examples/master/rectangles/rectangles.c:
* Demo application drawing rectangles on screen using fbdev
* This demo shows how to use the fbdev API to sync to vertical blank
* on Colibri VF50/VF61
* Copyright (c) 2015, Toradex AG
* This project is licensed under the terms of the MIT license (see
* LICENSE)
#include <cairo/cairo.h>
#include <fcntl.h>
#include <linux/types.h>
#include <linux/ioctl.h>
#include <linux/fb.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <signal.h>
#include <stropts.h>
#include <sys/mman.h>
#include <tslib.h>
#include <time.h>
static volatile sig_atomic_t cancel = 0;
typedef struct _cairo_linuxfb_device {
int fb_fd;
unsigned char *fb_data;
long fb_screensize;
struct fb_var_screeninfo fb_vinfo;
struct fb_fix_screeninfo fb_finfo;
} cairo_linuxfb_device_t;
void signal_handler(int signum)
cancel = 1;
* Flip framebuffer, return the next buffer id which will be used
int flip_buffer(cairo_linuxfb_device_t *device, int vsync, int bufid)
int dummy = 0;
/* Pan the framebuffer */
device->fb_vinfo.yoffset = device->fb_vinfo.yres * bufid;
if (ioctl(device->fb_fd, FBIOPAN_DISPLAY, &device->fb_vinfo)) {
perror("Error panning display");
return -1;
if (vsync) {
if (ioctl(device->fb_fd, FBIO_WAITFORVSYNC, &dummy)) {
perror("Error waiting for VSYNC");
return -1;
/* Destroy a cairo surface */
void cairo_linuxfb_surface_destroy(void *device)
cairo_linuxfb_device_t *dev = (cairo_linuxfb_device_t *)device;
if (dev == NULL)
return;
munmap(dev->fb_data, dev->fb_screensize);
close(dev->fb_fd);
free(dev);
/* Create a cairo surface using the specified framebuffer */
cairo_surface_t *cairo_linuxfb_surface_create(cairo_linuxfb_device_t *device, const char *fb_name)
cairo_surface_t *surface;
// Open the file for reading and writing
device->fb_fd = open(fb_name, O_RDWR);
if (device->fb_fd == -1) {
perror("Error: cannot open framebuffer device");
goto handle_allocate_error;
// Get variable screen information
if (ioctl(device->fb_fd, FBIOGET_VSCREENINFO, &device->fb_vinfo) == -1) {
perror("Error: reading variable information");
goto handle_ioctl_error;
/* Set virtual display size double the width for double buffering */
device->fb_vinfo.yoffset = 0;
device->fb_vinfo.yres_virtual = device->fb_vinfo.yres * 2;
if (ioctl(device->fb_fd, FBIOPUT_VSCREENINFO, &device->fb_vinfo)) {
perror("Error setting variable screen info from fb");
// Get fixed screen information
if (ioctl(device->fb_fd, FBIOGET_FSCREENINFO, &device->fb_finfo) == -1) {
perror("Error reading fixed information");
// Map the device to memory
device->fb_data = (unsigned char *)mmap(0, device->fb_finfo.smem_len,
PROT_READ | PROT_WRITE, MAP_SHARED,
device->fb_fd, 0);
if ((int)device->fb_data == -1) {
perror("Error: failed to map framebuffer device to memory");
/* Create the cairo surface which will be used to draw to */
surface = cairo_image_surface_create_for_data(device->fb_data,
CAIRO_FORMAT_RGB16_565,
device->fb_vinfo.xres,
device->fb_vinfo.yres_virtual,
cairo_format_stride_for_width(CAIRO_FORMAT_RGB16_565,
device->fb_vinfo.xres));
cairo_surface_set_user_data(surface, NULL, device,
&cairo_linuxfb_surface_destroy);
return surface;
handle_ioctl_error:
close(device->fb_fd);
handle_allocate_error:
free(device);
exit(1);
void draw_rectangles(cairo_t *fbcr, struct tsdev *ts, cairo_linuxfb_device_t *device)
int bufid = 1; /* start drawing into second buffer */
float r, g, b;
int fbsizex = device->fb_vinfo.xres;
int fbsizey = device->fb_vinfo.yres;
int startx, starty, sizex, sizey;
struct ts_sample sample;
cairo_t *cr;
float scale = 1.0f;
surface = cairo_image_surface_create(CAIRO_FORMAT_RGB16_565,
fbsizex, fbsizey);
cr = cairo_create(surface);
* We clear the cairo surface here before drawing
* This is required in case something was drawn on this surface
* previously, the previous contents would not be cleared without this.
cairo_set_operator(cr, CAIRO_OPERATOR_CLEAR);
cairo_paint(cr);
cairo_set_operator(cr, CAIRO_OPERATOR_OVER);
srand(time(NULL));
while (!cancel) {
r = (rand() % 100) / 100.0;
g = (rand() % 100) / 100.0;
b = (rand() % 100) / 100.0;
startx = rand() % fbsizex;
starty = rand() % fbsizey;
sizex = rand() % (fbsizex - startx);
sizey = rand() % (fbsizey - starty);
cairo_identity_matrix(cr);
if (ts) {
int pressed = 0;
/* Pressure is our identication whether we act on axis... */
while (ts_read(ts, &sample, 1)) {
if (sample.pressure > 0)
pressed = 1;
if (pressed) {
scale *= 1.05f;
cairo_translate(cr, sample.x, sample.y);
cairo_scale(cr, scale, scale);
//r = g = b = 0;
startx = -5;
starty = -5;
sizex = 10;
sizey = 10;
} else {
scale = 1.0f;
cairo_set_source_rgb(cr, r, g, b);
cairo_rectangle(cr, startx, starty, sizex, sizey);
cairo_stroke_preserve(cr);
cairo_fill(cr);
/* Draw to framebuffer at y offset according to current buffer.. */
cairo_set_source_surface(fbcr, surface, 0, bufid * fbsizey);
cairo_paint(fbcr);
flip_buffer(device, 1, bufid);
/* Switch buffer ID for next draw */
bufid = !bufid;
usleep(20000);
/* Make sure we leave with buffer 0 enabled */
flip_buffer(device, 1, 0);
/* Destroy and release all cairo related contexts */
cairo_destroy(cr);
cairo_surface_destroy(surface);
int main(int argc, char *argv[]) {
char fb_node[16] = "/dev/fb0";
char *tsdevice = NULL;
struct tsdev *ts;
struct sigaction action;
cairo_linuxfb_device_t *device;
cairo_surface_t *fbsurface;
cairo_t *fbcr;
if (argc > 1) {
strcpy(fb_node, argv[1]);
printf("Frame buffer node is: %s\n", fb_node);
if( (tsdevice = getenv("TSLIB_TSDEVICE")) != NULL )
ts = ts_open(tsdevice, 1);
ts = ts_open("/dev/input/event0", 1);
if (ts_config(ts)) {
perror("ts_config");
exit(1);
device = malloc(sizeof(*device));
if (!device) {
perror("Error: cannot allocate memory\n");
exit(1);
memset(&action, 0, sizeof(struct sigaction));
action.sa_handler = signal_handler;
sigaction(SIGTERM, &action, NULL);
sigaction(SIGINT, &action, NULL);
fbsurface = cairo_linuxfb_surface_create(device, fb_node);
fbcr = cairo_create(fbsurface);
draw_rectangles(fbcr, ts, device);
cairo_destroy(fbcr);
cairo_surface_destroy(fbsurface);
}编译应用程序:
/disk4/buildroot-2017.08.1/output/host/bin/arm-linux-gcc -o test rectangles.c -lcairo -lts
可以运行,但是会抛出一个错误:
./test
Frame buffer node is: /dev/fb0
Error panning display: Invalid argument
运行结果:
看起来这个画矩形的 cairo demo 有点问题。
代码改成这样,重新编译运行,基本正常了.
CAIRO_FORMAT_RGB24
* LICENSE)
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <signal.h>
#include <tslib.h>
#include <time.h>
int fb_fd;
long fb_screensize;
cancel = 1;
int dummy = 0;
return -1;
if (vsync) {
return -1;
if (dev == NULL)
return;
close(dev->fb_fd);
free(dev);
device->fb_fd, 0);
CAIRO_FORMAT_RGB24,
cairo_format_stride_for_width(CAIRO_FORMAT_RGB24,
return surface;
handle_ioctl_error:
free(device);
exit(1);
float r, g, b;
cairo_t *cr;
float scale = 1.0f;
surface = cairo_image_surface_create(CAIRO_FORMAT_RGB24,
fbsizex, fbsizey);
cairo_paint(cr);
srand(time(NULL));
while (!cancel) {
if (ts) {
int pressed = 0;
pressed = 1;
if (pressed) {
scale *= 1.05f;
//r = g = b = 0;
startx = -5;
starty = -5;
sizex = 10;
sizey = 10;
} else {
scale = 1.0f;
cairo_fill(cr);
cairo_paint(fbcr);
bufid = !bufid;
usleep(20000);
cairo_destroy(cr);
struct tsdev *ts;
cairo_t *fbcr;
if (argc > 1) {
exit(1);
if (!device) {
exit(1);
}离线
* LICENSE)
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <signal.h>
#include <tslib.h>
#include <time.h>
#include <math.h>
int fb_fd;
long fb_screensize;
cancel = 1;
int dummy = 0;
return -1;
if (vsync) {
return -1;
if (dev == NULL)
return;
close(dev->fb_fd);
free(dev);
device->fb_fd, 0);
CAIRO_FORMAT_RGB24,
return surface;
handle_ioctl_error:
free(device);
exit(1);
float r, g, b;
cairo_t *cr;
float scale = 1.0f;
fbsizex, fbsizey);
cairo_paint(cr);
srand(time(NULL));
int k = 0;
while (!cancel)
k++;
if(k>3) break;
int width=800, height=480;
cairo_set_line_width(cr, 9);
cairo_set_source_rgb(cr, 0.69, 0.19, 0);
cairo_translate(cr, width/2, height/2);
cairo_arc(cr, 0, 0, 50, 0, 2 * M_PI);
cairo_set_source_rgb(cr, 0.3, 0.4, 0.6);
cairo_fill(cr);
cairo_set_line_width(cr, 10);
cairo_set_line_cap(cr, CAIRO_LINE_CAP_BUTT);
cairo_move_to(cr, 30, 50);
cairo_line_to(cr, 150, 50);
cairo_stroke(cr);
cairo_set_line_cap(cr, CAIRO_LINE_CAP_ROUND);
cairo_move_to(cr, 30, 90);
cairo_line_to(cr, 150, 90);
cairo_stroke(cr);
cairo_set_line_cap(cr, CAIRO_LINE_CAP_SQUARE);
cairo_move_to(cr, 30, 130);
cairo_line_to(cr, 150, 130);
cairo_stroke(cr);
cairo_set_line_width(cr, 1.5);
cairo_move_to(cr, 30, 40);
cairo_line_to(cr, 30, 140);
cairo_stroke(cr);
cairo_move_to(cr, 150, 40);
cairo_line_to(cr, 150, 140);
cairo_stroke(cr);
cairo_move_to(cr, 155, 40);
cairo_line_to(cr, 155, 140);
cairo_stroke(cr);
cairo_paint(fbcr);
bufid = !bufid;
usleep(20000);
cairo_destroy(cr);
struct tsdev *ts;
cairo_t *fbcr;
if (argc > 1) {
exit(1);
if (!device) {
exit(1);
}离线
有V3S的板子,有空试试!谢谢晕哥!!!
BR2_PACKAGE_CAIRO=y
BR2_PACKAGE_PIXMAN=y接下来直接make即可.
我在.config中加入后编译出现这样的错误
zhang@zhang-virtual-machine:~/buildroot-2017.08.1$ make
Makefile:539: *** fontconfig is in the dependency chain of cairo that has added it to its _DEPENDENCIES variable without selecting it or depending on it from Config.in。 停止。
Makefile:79: recipe for target '_all' failed
make: *** [_all] Error 2是buildroot没配置好?
BR2_PACKAGE_CAIRO=y
zhang@zhang-virtual-machine:~/buildroot-2017.08.1$ make Makefile:539: *** fontconfig is in the dependency chain of cairo that has added it to its _DEPENDENCIES variable without selecting it or depending on it from Config.in。 停止。 Makefile:79: recipe for target '_all' failed make: *** [_all] Error 2是buildroot没配置好?
应该是缺 字体相关配置, 把 字体相关先全部勾上试一试。
# ./arm_test
Couldn't open tslib config file: No such file or directory
ts_config: No such file or directory.程序代码是帖子的应用源码。。。
