楼主 # 2024-05-13 14:10:44
stmMode
rv1126开发板上电kernel过后黑屏几秒才进入qt界面
rv1126开发板上电,进入到kernel logo后,该logo显示时间大概有6-7秒后,立刻就黑屏,持续3s-4s才进入qt应用界面,
请问怎么在kernel logo后,快速进入qt应用界面.
最近编辑记录 stmMode (2024-05-13 14:13:52)
#1 2024-05-13 14:21:20
ubuntu
已发帖子: 338
Re: rv1126开发板上电kernel过后黑屏几秒才进入qt界面
看下日志
楼主 #2 2024-05-13 14:36:38
stmMode
看哪部分的日志呢,
dmesg的还是开机的全部日志呢
楼主 #3 2024-05-13 14:37:23
stmMode
kernel logo过后,黑屏持续3s-4s进入qt程序界面.zip
DDR Version V1.08 20210825
DDR4, 328MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc6ee75eec1-210728 #zzz (Sep 13 2021 - 10:36:14)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC error: The cmd index is 1, ret is -110
mmc_init: -95, time 10
Trying to boot from MMC1
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
## Verified-boot: 0
## Checking optee 0x08400000 (gzip @0x08600000) ... sha256(7beb6b43df...) + sha256(bae962097a...) + OK
## Checking uboot 0x00600000 (gzip @0x00800000) ... sha256(a79b29d8d6...) + sha256(b07be23f78...) + OK
## Checking fdt 0x006bd070 ... sha256(a362d022de...) + OK
Jumping to U-Boot(0x00600000) via OP-TEE(0x08400000)
Total: 150.157 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
I/TC: Next entry point address: 0x00600000
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #zhangzj (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug  4 03:30:34 UTC 2021 arm
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
U-Boot 2017.09 (May 07 2024 - 03:53:30 -0700)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM:  2 GiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 7bbf9e50 - 7bbfede0
CR: M/C/I
device_node_name:adc-keys
device_node_name:dwmmc
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
fdt_addr_r = 8300000
resource_is_empty fun:resource_is_empty line:456
test--------------------
test-33333--------------line:479
test-33333--------------line:502
test-33333--------------line:516
---------------size =12631552, offset =6317568, dev_desc->blksz = 512
data =7bdd58c0
test444444---------------276
test444444---------------279
test444444---------------281
test444444---part->start =8000--blk_off =3036----blk_num =24671------282
__fit_image_load_one 283   7bdd58c0
52 53 43 45 00 00 00 00 01 01 01 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
test444444---------------339
test-33333--------------line:522
test-33333--------------line:529
FIT: no signed, no conf required
func:resource_traverse_init_list line:717
DTB: --------1-------<NULL>
[HW-ADC]: rv1126-xygd-1080p#_saradc_ch4=0.dtb
lcd adc_record[4] = 0,adc_record[4]= 0
adc_val =0.dtb
dtb_adc = 0
   - dev=saradc, channel=4, dtb_adc=0, read=0, found=1
cell_name =<NULL>
DTB: --------2-------rv1126-xygd-1080p#_saradc_ch4=0.dtb
len = 0
len = 92766
file->ram = 1
file->rsce_base = 7bdd58c0
file->f_size = 92766
file->name =rv1126-xygd-1080p#_saradc_ch4=0.dtb
file->f_offset = 187, offset = 0, dev_desc->blksz = 512
src = 7bdecec0
d0 0d fe ed 00 01 6a 5e 00 00 00 38 00 01 34 c8 00 00 00 28
p = 08300000
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
end--
src = 7bdecec0
p = 08300000
1---end--
end--
----end--
DTB: rv1126-xygd-1080p#_saradc_ch4=0.dtb
device_node_name:crypto
HASH(c): OK
device_node_name:saradc
device_node_name:ethernet
device_node_name:gpio1
device_node_name:gpio3
device_node_name:i2c
device_node_name:decompress
device_node_name:nandc
device_node_name:usb0
device_node_name:usb2-phy
device_node_name:serial
device_node_name:sfc
device_node_name:dwc3
device_node_name:phy
device_node_name:volumeup-key
device_node_name:menu-key
device_node_name:amba
device_node_name:clock-controller
io-domain: OK
rockchip_display_probe node.np->name = route-dsi
rockchip_display_probe: panel_i2c_busnum = 3
lt9211_is_connected  lt9211 connect = 0
find connect node's handle 16
find ep_node /vop@ffb00000/port/endpoint@1
find port_node /vop@ffb00000/port
find port_parent_node /vop@ffb00000
load_mipi2lvds_driver: lt9211@2d
I2c3 speed: 400000Hz
lt9211_parse_dt mipi-format=2 mipi-bpp=24 test-pattern=false
lt9211_ConvertBoard_power_off
lt9211_ConvertBoard_power_on
lt9211_chip_shutdown
lt9211_chip_enable
id: 0x21 0x03 0xe0
lt9211_detect successful
lt9211_probe : lt9211 is connected!
lt9211_probe -
load_mipi2lvds_driver: lt9211@2d : ret=0
lt9211_is_connected  lt9211 connect = 1
panel_simple_dsi_of_get_desc_data t1=1 t2=500 t3=200 t4=1 t5=1000
test:-------------------------------2362
test:2364 dsi@ffb30000.0
Can't get crtc id, default set to id = 0
Could not find baseparameter partition
Model: Rockchip RV1126 38x38 V10 EMMC DDR3 Board
len = 512
len = 512
file->ram = 1
file->f_size = 6220854
file->f_offset = 369, offset = 0, dev_desc->blksz = 512
src = 7be03ac0
42 4d 36 ec 5e 00 cf 20 00 00 36 00 00 00 28 00 00 00 80 07
p = 7ca0a298
end--
src = 7be03ac0
p = 7ca0a298
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7be03ac0
p = 7df00000
end--
src = 7be03ac0
p = 7df00000
1---end--
end--
----end--
Rockchip UBOOT DRM driver version: v1.0.1
test 857
test 863
test 866
test 892
test 894
test:541
timing = display-timings
lt9211_set_videomode - clk: 148500000 hact: 1920 hfp: 88 hs: 44 hbp: 148 vact: 1080  vfp: 4 vs: 5 vbp: 36
display_get_timing_from_dts hactive = 1920 vactive = 1080 pixelclock = 148500 flags =0xa
Using display timing dts
test 896
test 932
test 937
dsi@ffb30000:  detailed mode clock 148500 kHz, flags[a]
    H: 1920 2008 2052 2200
    V: 1080 1084 1089 1125
bus_format: 100e
final DSI-Link bandwidth: 990 Mbps x 4
in panel_simple_prepare 1
in panel_simple_prepare 2
lt9211_bridge_enable
lt9211_chip_enable
lt9211_init_seq
[INFO ] MIPI Input PortA
[INFO ] Mipi DSI Input
[INFO ] hact = 1920
[INFO ] vact = 1080
[INFO ] fmt = 0x0a
[INFO ] pa_lpn = 0x55
[INFO ] MipiRx Input Format: RGB 8Bit
[INFO ] ---------test, line:380
[INFO ] ---------test, line:386
[INFO ] FrameRate = 59
[INFO ] Video Timing Set 1920x1080_59
[INFO ] Mipi Rx PixClk: 148500
[WARN ] PCR unstable M = 0x17
[INFO ] LT9211C pcr stable
-----ulRtn = 74247
[INFO ] Tx Pll Lock
[INFO ] MIPI Output PortA & B
-----ulRtn = 125000
[INFO ] MipiTx Output Format: RGB 8bit
Start initial panel
cmd_list set 0x25 , mdelay(100).
cmd_list set 0x26 , mdelay(100).
cmd_list set 0x11 , mdelay(100).
cmd_list set 0x29 , mdelay(100).
cmd_list set 0xCD , mdelay(100).
Finish initial panel
[INFO ] Mipi DSI Out
[exit:]lt9211_init_seq
panel_simple_enable
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 462000 KHz
  gpll 1188000 KHz
  cpll 500000 KHz
  hpll 1400000 KHz
  aclk_pdbus 500000 KHz
  hclk_pdbus 198000 KHz
  pclk_pdbus 99000 KHz
  aclk_pdphp 297000 KHz
  hclk_pdphp 198000 KHz
  hclk_pdaudio 148500 KHz
  hclk_pdcore 198000 KHz
  pclk_pdpmu 99000 KHz
Net:   device_node_name:ethernet
eth0: ethernet@ffc40000
Hit key to stop autoboot('CTRL+C'):  0
## Booting FIT Image at 0x7b3f0240 with size 0x00606c00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 7b3f0240 ...
   Using 'conf' configuration
optee api revision: 2.0
TEEC: Waring: Could not find security partition
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x7b407640
     Data Size:    6223864 Bytes = 5.9 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x02008000
     Entry Point:  0x02008000
     Hash algo:    sha256
     Hash value:   eb3b3ea53c676c4c5e85d576bdf7d302ddb74187aeba2c3afd56337b087cb0fa
   Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 7b3f0240 ...
   Trying 'fdt' fdt subimage
     Data Start:   0x7b3f0a40
     Data Size:    92766 Bytes = 90.6 KiB
     Architecture: ARM
     Load Address: 0x08300000
     Hash algo:    sha256
     Hash value:   dfd9f487ab1061510e53e2bcc4af8add91318a8c74e8e0b32cc878b246e31b3c
   Loading fdt from 0x08300000 to 0x08300000
   Booting using the fdt blob at 0x08300000
--Debug-Load the OS---func:do_bootm_states, line: 722
-----BOOT LOAD OS Line:526
   Loading Kernel Image from 0x7b407640 to 0x02008000 ... -------------comp: 0
------Line: 430
---------------to : 02008000, from :7b407640, len =6223864
testttt 568
------Line: 432
OK
-----BOOT LOAD OS END Line:530
   kernel loaded at 0x02008000, end = 0x025f77f8
--Debug-Load the OS-end----func:do_bootm_states, line: 738
  'reserved-memory' ramoops@8000000: addr=8000000 size=100000
--Debug----func:do_bootm_states, line: 764
   Using Device Tree in place at 08300000, end 08319a5d
len = 512
len = 512
file->ram = 1
file->f_offset = 12520, offset = 0, dev_desc->blksz = 512
src = 7c3f28c0
p = 7ca0df60
end--
src = 7c3f28c0
p = 7ca0df60
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7c3f28c0
p = 7e4ef000
end--
src = 7c3f28c0
p = 7e4ef000
1---end--
end--
----end--
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x80000000 (size: 0x779b8000)
Total: 3616.666 ms
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Linux version 4.19.111 (kingsun@ubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #110 SMP PREEMPT Sun Apr 28 04:42:10 PDT 2024
[    0.000000] OF: fdt: Machine model: Rockchip RV1126 38x38 V10 EMMC DDR3 Board
[    0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x7f800000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x5dc00000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522376
[    0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 snd_aloop.index=7
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1518464K/2094816K available (8192K kernel code, 391K rwdata, 1960K rodata, 1024K init, 276K bss, 43872K reserved, 532480K cma-reserved, 872584K highmem)
[    0.000000]     vmalloc : 0xda000000 - 0xff800000   ( 600 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xd9800000   ( 664 MB)
[    0.000000]     pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
[    0.000000]     modules : 0xaf000000 - 0xafe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 392 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 277 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000758] Switching to timer-based delay loop, resolution 41ns
[    0.002594] Console: colour dummy device 80x30
[    0.003064] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.004024] pid_max: default: 4096 minimum: 301
[    0.004625] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.005254] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.006650] CPU: Testing write buffer coherency: ok
[    0.007477] /cpus/cpu@f00 missing clock-frequency property
[    0.008005] /cpus/cpu@f01 missing clock-frequency property
[    0.008528] /cpus/cpu@f02 missing clock-frequency property
[    0.009052] /cpus/cpu@f03 missing clock-frequency property
[    0.009612] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.010885] Setting up static identity map for 0x100000 - 0x100060
[    0.011640] rcu: Hierarchical SRCU implementation.
[    0.012735] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.014758] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.016446] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.018097] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.018234] smp: Brought up 1 node, 4 CPUs
[    0.020243] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.020825] CPU: All CPU(s) started in SVC mode.
[    0.022271] devtmpfs: initialized
[    0.046437] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.047828] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.048745] futex hash table entries: 16 (order: -2, 1024 bytes)
[    0.049547] pinctrl core: initialized pinctrl subsystem
[    0.051284] NET: Registered protocol family 16
[    0.052385] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.055190] cpuidle: using governor menu
[    0.055592] Registered FIQ tty driver
[    0.056507] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.057255] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.059997] console [pstore-1] enabled
[    0.060595] pstore: Registered ramoops as persistent store backend
[    0.061179] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[    0.108985] cryptd: max_cpu_qlen set to 1000
[    0.110261] fiq debugger fiq mode enabled
[[     0.111056] console [ttyFIQ0] enabled
[    0.111740] bootconsole [uart8250] disabled
[    0.112447] Registered fiq debugger ttyFIQ0
[    0.113107] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    0.116674] vcc_sd: supplied by vcc3v3_sys
[    0.117171] reg-fixed-voltage vdd-arm: Fixed regulator specified with variable voltages
[    0.117227] reg-fixed-voltage: probe of vdd-arm failed with error -22
[    0.117338] reg-fixed-voltage vdd-logic-npu-vepu: Fixed regulator specified with variable voltages
[    0.117381] reg-fixed-voltage: probe of vdd-logic-npu-vepu failed with error -22
[    0.118485] rk_iommu ffb00f00.iommu: version = 1
[    0.119125] rk_iommu ffb20800.iommu: version = 1
[    0.119592] rk_iommu ffb60e00.iommu: version = 1
[    0.120234] rk_iommu ffb80480.iommu: version = 1
[    0.120785] rk_iommu ffb90800.iommu: version = 1
[    0.121271] rk_iommu ffbb0f00.iommu: version = 1
[    0.122353] SCSI subsystem initialized
[    0.122677] usbcore: registered new interface driver usbfs
[    0.122769] usbcore: registered new interface driver hub
[    0.122945] usbcore: registered new device driver usb
[    0.123065] media: Linux media interface: v0.10
[    0.123136] videodev: Linux video capture interface: v2.00
[    0.123206] pps_core: LinuxPPS API ver. 1 registered
[    0.123228] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.123272] PTP clock support registered
[    0.125274] Bluetooth: Core ver 2.22
[    0.125366] NET: Registered protocol family 31
[    0.125390] Bluetooth: HCI device and connection manager initialized
[    0.125420] Bluetooth: HCI socket layer initialized
[    0.125447] Bluetooth: L2CAP socket layer initialized
[    0.125504] Bluetooth: SCO socket layer initialized
[    0.126029] rockchip-cpuinfo cpuinfo: SoC            : 11260000
[    0.126065] rockchip-cpuinfo cpuinfo: Serial         : 04a143fbbeca61df
[    0.127026] clocksource: Switched to clocksource arch_sys_counter
[    0.140971] NET: Registered protocol family 2
[    0.141876] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.141936] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.142093] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.142295] TCP: Hash tables configured (established 8192 bind 8192)
[    0.142457] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.142538] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.142776] NET: Registered protocol family 1
[    0.144735] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.147567] Initialise system trusted keyrings
[    0.147844] workingset: timestamp_bits=29 max_order=19 bucket_order=0
[    0.155290] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.158112] Key type asymmetric registered
[    0.158144] Asymmetric key parser 'x509' registered
[    0.158223] bounce: pool size: 64 pages
[    0.158295] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.158321] io scheduler noop registered
[    0.158342] io scheduler deadline registered
[    0.158510] io scheduler cfq registered (default)
[    0.158537] io scheduler mq-deadline registered
[    0.158558] io scheduler kyber registered
[    0.158715] io scheduler bfq registered
[    0.162957] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
[    0.168853] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.168991] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.169390] mpp_service mpp-srv: 4a6b4c5b4 author: sun fan 2023-09-09 version 1.0
[    0.169417] mpp_service mpp-srv: probe start
[    0.170482] iommu: Adding device ffb80000.rkvdec to group 3
[    0.170539] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[    0.170728] mpp_rkvdec ffb80000.rkvdec: probing start
[    0.171371] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[    0.171394] rkvdec_init:1190: No niu aclk reset resource define
[    0.171431] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[    0.171453] rkvdec_init:1193: No niu hclk reset resource define
[    0.171743] mpp_rkvdec ffb80000.rkvdec: probing finish
[    0.172575] iommu: Adding device ffbb0000.rkvenc to group 5
[    0.172631] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[    0.172923] mpp_rkvenc ffbb0000.rkvenc: probing start
[    0.173602] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.7
[    0.173722] mpp_rkvenc ffbb0000.rkvenc: bin=0
[    0.173783] mpp_rkvenc ffbb0000.rkvenc: leakage=2.625
[    0.173874] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[    0.173926] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[    0.174489] mpp_rkvenc ffbb0000.rkvenc: avs=0
[    0.174887] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[    0.174922] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[    0.175553] mpp_rkvenc ffbb0000.rkvenc: probing finish
[    0.176246] iommu: Adding device ffb90400.vdpu to group 4
[    0.176305] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[    0.176412] mpp_vdpu2 ffb90400.vdpu: probe device
[    0.176967] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177080] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177345] mpp_vdpu2 ffb90400.vdpu: probing finish
[    0.177992] iommu: Adding device ffb90000.vepu to group 4
[    0.178048] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[    0.178177] mpp_vepu2 ffb90000.vepu: probe device
[    0.178690] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178729] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178983] mpp_vepu2 ffb90000.vepu: probing finish
[    0.179518] iommu: Adding device ffb20000.iep to group 1
[    0.179576] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[    0.179686] mpp-iep2 ffb20000.iep: probe device
[    0.180404] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[    0.180620] mpp-iep2 ffb20000.iep: probing finish
[    0.180889] mpp_service mpp-srv: probe success
[    0.186045] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.186090] dma-pl330 ff4e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.188183] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.189081] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.190082] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 32, base_baud = 1500000) is a 16550A
[    0.191042] ff590000.serial: ttyS4 at MMIO 0xff590000 (irq = 33, base_baud = 1500000) is a 16550A
[    0.191827] ff5a0000.serial: ttyS5 at MMIO 0xff5a0000 (irq = 34, base_baud = 1500000) is a 16550A
[    0.193818] rockchip_drm_init----------------000--------------
[    0.193981] random: fast init done
[    0.194379] random: crng init done
[    0.194919] iommu: Adding device ffb00000.vop to group 0
[    0.194984] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[    0.195065] clk: failed to reparent dclk_vop to cpll: -22
[    0.198260] rockchip_drm_init----------------001--------------
[    0.198340] rockchip_drm_platform_probe----------------001--------------
[    0.198384] rockchip_drm_platform_probe----------------002--------------
[    0.199301] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[    0.200435] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[    0.201637] rockchip_drm_platform_probe----------------003--------------
[    0.201668] rockchip_drm_bind----------------011--------------
[    0.201860] rockchip-drm display-subsystem: devfreq is not set
[    0.202359] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.202390] dw_mipi_dsi_bind----------------00--------------
[    0.202394] dw_mipi_dsi_bind----------------01--------------
[    0.202418] dw_mipi_dsi_bind----------------02--------------
[    0.202457] drm_of_find_panel_or_bridge  panel is null
[    0.202498] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
[    0.202542] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb09439ac): -517
[    0.202808] rockchip-drm display-subsystem: master bind failed: -517
[    0.203165] rockchip_drm_init----------------002--------------
[    0.208059] panel_simple_dsi_probe dsi_id =-19
[    0.208089] panel_simple_dsi_probe node--name =dsi@ffb30000
[    0.208148] drm_display_mode_from_videomode------------------------------148
[    0.208176] panel_simple_dsi_probe----------------0002--------------
[    0.208238] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply power not found, using dummy regulator
[    0.208354] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[    0.208404] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[    0.208505] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[    0.209777] zram: Added device: zram0
[    0.211838] libphy: Fixed MDIO Bus: probed
[    0.213137] PPP generic driver version 2.4.2
[    0.213385] PPP BSD Compression module registered
[    0.213413] PPP Deflate Compression module registered
[    0.213453] PPP MPPE Compression module registered
[    0.213474] NET: Registered protocol family 24
[    0.213582] usbcore: registered new interface driver asix
[    0.213668] usbcore: registered new interface driver ax88179_178a
[    0.213781] usbcore: registered new interface driver cdc_ether
[    0.213864] usbcore: registered new interface driver net1080
[    0.213936] usbcore: registered new interface driver cdc_subset
[    0.214006] usbcore: registered new interface driver zaurus
[    0.214102] usbcore: registered new interface driver cdc_ncm
[    0.215773] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[    0.221387] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.221426] ehci-platform: EHCI generic platform driver
[    0.225021] ehci-platform ffe00000.usb: EHCI Host Controller
[    0.225086] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[    0.225299] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[    0.237078] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[    0.237372] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.237415] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.237439] usb usb1: Product: EHCI Host Controller
[    0.237463] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[    0.237486] usb usb1: SerialNumber: ffe00000.usb
[    0.238242] hub 1-0:1.0: USB hub found
[    0.238316] hub 1-0:1.0: 1 port detected
[    0.239060] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.239102] ohci-platform: OHCI generic platform driver
[    0.239657] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[    0.239718] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[    0.239903] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[    0.298129] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.298166] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.298186] usb usb2: Product: Generic Platform OHCI controller
[    0.298235] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[    0.298261] usb usb2: SerialNumber: ffe10000.usb
[    0.299025] hub 2-0:1.0: USB hub found
[    0.299101] hub 2-0:1.0: 1 port detected
[    0.300813] usbcore: registered new interface driver cdc_acm
[    0.300844] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.300995] usbcore: registered new interface driver usb-storage
[    0.301154] usbcore: registered new interface driver option
[    0.301216] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.302360] i2c /dev entries driver
[    0.305635] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.305926] rtc-pcf8563 0-0051: registered as rtc0
[    0.307147] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.307178] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[    0.311723] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[    0.313085] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[    0.313141] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[    0.313277] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[    0.313382] rkcif rkcif_dvp: attach to cif hw node
[    0.313404] rkcif rkcif_dvp: rkcif wait line 0
[    0.313446] RKCIF_WORKMODE_PINGPONG
[    0.314940] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[    0.315047] rkcif rkcif_mipi_lvds: attach to cif hw node
[    0.315076] rkcif rkcif_mipi_lvds: rkcif wait line 0
[    0.315113] RKCIF_WORKMODE_PINGPONG
[    0.316152] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[    0.316185] rockchip-mipi-csi2: Async registered subdev
[    0.318573] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[    0.318612] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[    0.318931] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[    0.318978] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[    0.319303] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[    0.319544] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    0.319801] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.319846] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.319877] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.322872] rkisp rkisp-vir1: rkisp driver version: v01.06.02
[    0.323133] rkisp rkisp-vir1: No memory-region-thunderboot specified
[    0.323362] rkisp rkisp-vir1: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.323404] rkisp rkisp-vir1: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.323434] rkisp rkisp-vir1: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.327399] iommu: Adding device ffb60000.rkispp to group 2
[    0.327472] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[    0.327896] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[    0.327947] rkispp_hw ffb60000.rkispp: can't request region for resource [mem 0xffb60000-0xffb7ffff]
[    0.328215] rkispp_hw ffb60000.rkispp: failed to get cru reset
[    0.328521] rkispp rkispp-vir0: rkispp driver version: v01.06.02
[    0.330969] rkispp rkispp-vir1: rkispp driver version: v01.06.02
[    0.333739] usbcore: registered new interface driver uvcvideo
[    0.333771] USB Video Class driver (1.1.1)
[    0.334273] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.3
[    0.334317] rockchip-iodomain fe020000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    0.334443] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[    0.334564] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    0.334686] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.5
[    0.334730] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc3v3_sys
[    0.334874] rockchip-iodomain fe020000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    0.334997] rockchip-iodomain fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vcc_1v8
[    0.335110] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(1800000 uV) supplied by vcc_1v8
[    0.335250] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[    0.338079] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -7
[    0.338524] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[    0.339014] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -7
[    0.339316] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[    0.340951] Bluetooth: HCI UART driver ver 2.3
[    0.340986] Bluetooth: HCI UART protocol H4 registered
[    0.341333] cpu cpu0: bin=0
[    0.341384] cpu cpu0: leakage=3.375
[    0.341441] cpu cpu0: Failed to get reg
[    0.341478] cpu cpu0: bin-scale=5
[    0.341808] cpuidle: enable-method property 'psci' found operations
[    0.341988] cpuidle: enable-method property 'psci' found operations
[    0.342145] cpuidle: enable-method property 'psci' found operations
[    0.342297] cpuidle: enable-method property 'psci' found operations
[    0.343033] Synopsys Designware Multimedia Card Interface Driver
[    0.344033] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[    0.344117] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[    0.344152] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[    0.344257] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    0.344476] mmc_host mmc0: card is non-removable.
[    0.357323] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.371202] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[    0.371309] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[    0.371338] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[    0.371489] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    0.371670] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.6
[    0.371772] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.3
[    0.407114] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[    0.407176] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[    0.407742] mmc0: new HS200 MMC card at address 0001
[    0.410826] mmcblk0: mmc0:0001 DA4064 58.2 GiB
[    0.412132] mmcblk0boot0: mmc0:0001 DA4064 partition 1 4.00 MiB
[    0.413334] mmcblk0boot1: mmc0:0001 DA4064 partition 2 4.00 MiB
[    0.413944] mmcblk0rpmb: mmc0:0001 DA4064 partition 3 16.0 MiB, chardev (242:0)
[    0.424496]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    0.490075] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.503743] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.503832] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.503862] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.503966] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.505067] usbcore: registered new interface driver usbhid
[    0.505094] usbhid: USB HID core driver
[    0.507746] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.3
[    0.509567] rksfc_base v1.1 2016-01-08
[    0.510238] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[    0.510438] rkflash_dev_init enter
[    0.510478] sfc nor id: 0 0 0
[    0.510495] rkflash[1] is invalid
[    0.510500] rkflash_dev_init enter
[    0.510530] sfc_nand id: 0 0 0
[    0.510545] rkflash[2] is invalid
[    0.511262] NET: Registered protocol family 17
[    0.511348] NET: Registered protocol family 15
[    0.512714] Bluetooth: RFCOMM TTY layer initialized
[    0.512788] Bluetooth: RFCOMM socket layer initialized
[    0.512840] Bluetooth: RFCOMM ver 1.11
[    0.512874] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    0.512931] Bluetooth: HIDP socket layer initialized
[    0.512957] [BT_RFKILL]: Enter rfkill_rk_init
[    0.512976] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    0.513467] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    0.513599] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = USB-WiFi
[    0.513631] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    0.513647] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    0.513764] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 16 flags = 0.
[    0.513859] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    0.513882] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    0.513937] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    0.516577] flash vendor_init_thread!
[    0.516612] flash vendor storage:20170308 ret = -1
[    0.517528] gc2145 1-003c: driver version: 00.01.06
[    0.517596] gc2145_probe---------------00000---------------
[    0.517637] gc2145_probe---------------11111---------------
[    0.517695] gc2145_probe---------------22222---------------
[    0.517740] gc2145_probe---------------222221---------------
[    0.517767] gc2145_probe---------------2222211---------------
[    0.517785] fps =25
[    0.517811] gc2145_probe---------------33333---------------
[    0.517850] m01_b_gc2145 1-003c: Async registered subdev
[    0.517896] rkcif rkcif_dvp: Entity type for entity rkcif-dvp-sof was not initialized!
[    0.519922] ----------i=5
[    0.519976] ----------i=5
[    0.520000] ----------i=5
[    0.520023] ----------i=5
[    0.520044] rkcif_dvp: Async subdev notifier completed
[    0.520064] gc2145_probe---------------44444---------------
[    0.520078] gc2145 1-003c: m01_b_gc2145 1-003c sensor driver registered !!
[    0.520556] sc2210 1-0030: driver version: 00.01.06
[    0.520592] sc2210 1-0030:  Get hdr mode failed! no hdr default
[    0.520908] sc2210 1-0030: could not get sleep pinstate
[    0.521138] sc2210 1-0030: Linked as a consumer to regulator.2
[    0.521332] sc2210 1-0030: Linked as a consumer to regulator.3
[    0.521481] sc2210 1-0030: Linked as a consumer to regulator.4
[    0.521571] sc2210_initialize_controls---------------11111---------------0
[    0.521584] sc2210_initialize_controls---------------11111---------------0 74250000
[    0.529546] sc2210 1-0030: gain_mode 0b02
[    0.529607] sc2210 1-0030: Detected SC2210 sensor
[    0.529720] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: match m00_f_sc2210 1-0030:bus type 4
[    0.529755] sc2210_probe---------------11111---------------hdr_mode0
[    0.529772] sc2210_runtime_suspend---------------11111---------------
[    0.530431] Registering SWP/SWPB emulation handler
[    0.535275] Loading compiled-in X.509 certificates
[    0.538268] rga2: Driver loaded successfully ver:3.2.56726
[    0.538710] rga2: Module initialized.
[    0.582675] rockchip_drm_platform_probe----------------001--------------
[    0.582698] rockchip_drm_platform_probe----------------002--------------
[    0.586407] rockchip_drm_platform_probe----------------003--------------
[    0.586510] rockchip_drm_bind----------------011--------------
[    0.586764] rockchip-drm display-subsystem: devfreq is not set
[    0.587459] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.587521] dw_mipi_dsi_bind----------------00--------------
[    0.587527] dw_mipi_dsi_bind----------------01--------------
[    0.587558] dw_mipi_dsi_bind----------------02--------------
[    0.587618] drm_of_find_panel_or_bridge  panel ret =0
[    0.587644] dw_mipi_dsi_bind----------------03--------------
[    0.587673] dw_mipi_dsi_bind----------------04--------------
[    0.587707] dw_mipi_dsi_bind----------------05--------------
[    0.587749] dw_mipi_dsi_bind----------------06--------------
[    0.587789] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb09439ac)
[    0.587834] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.587870] [drm] No driver support for vblank timestamp query.
[    0.588023] rockchip_drm_bind----------------010--------------
[    0.588030] show_loader_logo----------------011--------------
[    0.588304] setup_initial_state----------------encoder_funcs->loader_protect--------------
[    0.588365] dw_mipi_dsi_encoder_loader_protect----------------dw_mipi_dsi_encoder_loader_protect--------------581be353
[    0.588390] panel_simple_loader_protect: on = 1!
[    0.588432] panel_simple_loader_protect----------------panel_simple_loader_protect--------------581be353 1
[    0.588647] show_loader_logo----------------012--------------
[    0.620635] rockchip-drm display-subsystem: fb0:  frame buffer device
[    0.623910] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    0.623978] rockchip_drm_platform_probe----------------004--------------
[    0.624788] input: adc-keys as /devices/platform/adc-keys/input/input0
[    0.626886] vendor storage:20190527 ret = 0
[    0.627780] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.627883] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.627919] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.627986] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.630251] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.630411] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.630450] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.630512] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.632942] rkcif rkcif_dvp: clear unready subdev num: 0
[    0.633028] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[    0.633058] rockchip-mipi-csi2: No link between dphy and sensor
[    0.633387] rockchip-mipi-csi2: No link between dphy and sensor
[    0.633414] rkcif_mipi_lvds: Async subdev notifier completed
[    0.634262] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    0.639583] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    0.639836] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    0.639866] cfg80211: failed to load regulatory.db
[    0.641398] rkisp rkisp-vir0: clear unready subdev num: 1
[    0.642787] rockchip-mipi-csi2: No link between dphy and sensor
[    0.642834] rockchip-mipi-csi2: No link between dphy and sensor
[    0.642861] rkisp0: Invalid mipi data type
[    0.642876] rkisp0: update sensor failed
[    0.642903] rkisp rkisp-vir1: clear unready subdev num: 1
[    0.643773] rkisp1: Async subdev notifier completed
[    0.646756] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[    0.646808] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[    0.717608] EXT4-fs (mmcblk0p6): recovery complete
[    0.719931] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    0.720037] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    0.726111] devtmpfs: mounted
[    0.728344] Freeing unused kernel memory: 1024K
[    0.729198] Run /sbin/init as init process
[    0.860933] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
NAME=Buildroot
VERSION=2018.02-rc3
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME="Buildroot 2018.02-rc3"
Starting logging: OK
/usr/bin/modetest
[    1.447243] phy phy-ff4c0000.usb2-phy.1: charger = USB_SDP_CHARGER
Populating /dev using udev: [    1.533102] udevd[118]: starting version 3.2.7
[    1.549240] udevd[118]: specified group 'kvm' unknown
[    1.600141] udevd[119]: starting eudev-3.2.7
[    1.883380] gc2145 1-003c: gc2145_power(2721) on(1)
[    1.885634] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.885671] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.885729] rkcif_dvp: rkcif_update_sensor_info: stream[1] get remote sensor_sd failed!
[    1.885747] stream_cif_dvp_id1: update sensor info failed -19
[    1.885803] rkcif_dvp: rkcif_update_sensor_info: stream[3] get remote sensor_sd failed!
[    1.885869] stream_cif_dvp_id3: update sensor info failed -19
[    1.888799] gc2145 1-003c: gc2145_power(2721) on(0)
[    1.890828] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.891235] rkcif_dvp: rkcif_update_sensor_info: stream[2] get remote sensor_sd failed!
[    1.891495] stream_cif_dvp_id2: update sensor info failed -19
[    1.926374] rockchip-mipi-csi2: No link between dphy and sensor
[    1.934836] rockchip-mipi-csi2: No link between dphy and sensor
[    1.937304] rockchip-mipi-csi2: No link between dphy and sensor
[    1.952011] rockchip-mipi-csi2: No link between dphy and sensor
[    1.992166] rockchip-mipi-csi2: No link between dphy and sensor
[    2.089173] sc2210 cmd =80685600
[    2.152557] sc2210_runtime_suspend---------------11111---------------
[    2.167282] sc2210_runtime_suspend---------------11111---------------
[    2.218667] sc2210_runtime_suspend---------------11111---------------
done
Will now mount all partitions in /etc/fstab
Note: Will auto format partitons, remove /.auto_mkfs to disable
Note: Create /.skip_fsck to skip fsck
 - The check might take a while if didn't shutdown properly!
Handling rootfs: /dev/mmcblk0p6 / ext2 rw,noauto 1
Checking /dev/mmcblk0p6(ext2)
[    2.228170] sc2210_runtime_suspend---------------11111---------------
[    3.001038] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
e2fsck 1.43.9 (8-Feb-2018)
rootfs: clean, 6951/65536 files, 171119/262144 blocks
[    3.068520] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
Handling misc: /dev/mmcblk0p2 /misc emmc defaults 0
Unsupported file system emmc for /dev/mmcblk0p2
Handling oem: /dev/mmcblk0p7 /oem ext2 defaults 2
Checking /dev/mmcblk0p7(ext2)
oem: recovering journal
oem: clean, 381/49152 files, 156117/196608 blocks
Mounting /dev/mmcblk0p7(ext2) on /oem
[    3.808491] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Handling userdata: /dev/mmcblk0p8 /userdata ext2 defaults 2
Checking /dev/mmcblk0p8(ext2)
userdata was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
userdata: 27/163840 files (0.0% non-contiguous), 149411/1048576 blocks
Mounting /dev/mmcblk0p8(ext2) on /userdata
[    5.678168] EXT4-fs (mmcblk0p8): mounting ext2 file system using the ext4 subsystem
[    5.686335] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
Handling demo: /dev/mmcblk0p10 /demo ext4 defaults 0
Mounting /dev/mmcblk0p10(ext4) on /demo
[    6.655545] EXT4-fs (mmcblk0p10): recovery complete
[    6.658390] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
Log saved to /tmp/mountall.log
Starting system message bus: done
/etc/init.d/S36load_rv1109_wifi_modules: line 45: can't create /sys/class/rfkill/rfkill1/state: nonexistent directory
load wifi modules: [    6.979994] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[    6.980046] ======== dhd_wlan_init_plat_data ========
[    6.980063] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    6.980078] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: wifi OOB pin isn't defined.
[    6.980092] dhd_wlan_init_gpio: unknown oob irqflags !
[    6.980108] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=-1, oob_irq_flags=0x410
[    6.980123] dhd_wlan_init_gpio: WL_REG_ON=-1
[    6.980154] dhd_wifi_platform_load: Enter
[    6.980170] Power-up adapter 'DHD generic adapter'
[    6.980264] wifi_platform_set_power = 1
[    6.980288] ======== PULL WL_REG_ON(-1) HIGH! ========
[    6.980310] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    6.980331] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    7.087270] [WLAN_RFKILL]: wifi turn on power [GPIO16-1]
[    7.393975] wifi_platform_bus_enumerate device present 1
[    7.394023] ======== Card detection to detect SDIO card! ========
[    7.394040] sdio: host isn't  initialization successfully.
[    9.443930] failed to power up DHD generic adapter, 1 retry left
[    9.460282] wifi_platform_set_power = 0
[    9.460398] ======== PULL WL_REG_ON(-1) LOW! ========
[    9.460418] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    9.460434] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    9.460448] wifi power off
[    9.567272] [WLAN_RFKILL]: wifi shut off power [GPIO16-0]
[    9.567324] wifi_platform_bus_enumerate device present 0
[    9.567339] ======== Card detection to remove SDIO card! ========
[    9.567354] sdio: host isn't  initialization successfully.
[    9.567497] wifi_platform_set_power = 1
[    9.567520] ======== PULL WL_REG_ON(-1) HIGH! ========
[    9.567543] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    9.567564] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    9.673936] [WLAN_RFKILL]: wifi turn on power [GPIO16-1]
[    9.980614] wifi_platform_bus_enumerate device present 1
[    9.980664] ======== Card detection to detect SDIO card! ========
[    9.980681] sdio: host isn't  initialization successfully.
[   12.003944] failed to power up DHD generic adapter, 0 retry left
[   12.020303] wifi_platform_set_power = 0
[   12.020428] ======== PULL WL_REG_ON(-1) LOW! ========
[   12.020455] [WLAN_RFKILL]: rockchip_wifi_power: 0
[   12.020473] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[   12.020492] wifi power off
[   12.127271] [WLAN_RFKILL]: wifi shut off power [GPIO16-0]
[   12.127324] wifi_platform_bus_enumerate device present 0
[   12.127339] ======== Card detection to remove SDIO card! ========
[   12.127354OK
[   12.127368] failed to power up DHD generic adapter, max retry reached**
[   12.127383] unregister wifi platform drivers
[   12.127397] wifi_platform_bus_enumerate device present 0
[   12.127412] ======== Card detection to remove SDIO card! ========
[   12.127439] sdio: host isn't  initialization successfully.
[   12.127453] ======== dhd_wlan_deinit_plat_data ========
[   12.127476] dhd_module_init: Failed to load the driver, try cnt 0
[   12.127564] dhd_module_init: Failed to load driver max retry reached**
[   12.127586] dhd_module_init: Exit err=-19
Starting network: OK
Starting connman ... done.
alsactl: load_state:1735: No soundcards found...
Starting ntpd: OK
Starting QDesktop...
gpiochip0: GPIOs 0-31, parent: platform/pinctrl, gpio0:
 gpio-4   (                    |vcc_sd              ) out lo
 gpio-16  (                    |rkwifi_wlan_poweren ) out lo
gpiochip1: GPIOs 32-63, parent: platform/pinctrl, gpio1:
gpiochip2: GPIOs 64-95, parent: platform/pinctrl, gpio2:
 gpio-64  (                    |pwdn                ) out lo
 gpio-65  (                    |reset               ) out hi
gpiochip3: GPIOs 96-127, parent: platform/pinctrl, gpio3:
gpiochip4: GPIOs 128-129, parent: platform/pinctrl, gpio4:
Starting dropbear sshd: OK
Starting fcgiwrap daemon: OK
Starting nginx...
Debug: configfs_init
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0': No such file or directory
[   12.837899] file system registered
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
[   12.881719] using random self ethernet address
[   12.881795] using random host ethernet address
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mass_storage.0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/hid.usb0': No such file or directory
[   13.068109] read descriptors
[   13.068189] read strings
media get entity by name: stream_cif_mipi_id0 is null
media get entity by name: stream_cif_mipi_id1 is null
media get entity by name: stream_cif_mipi_id2 is null
media get entity by name: stream_cif_mipi_id3 is null
media get entity by name: rockchip-mipi-csi2 is null
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rockchip-mipi-dphy-rx is null
media get entity by name: stream_cif is null
[   13.463766] gc2145_enum_frame_interval---------------00000---------------0, 0
[   13.463775] file->index = 0, cfg_num =1
[   13.463837] gc2145_enum_frame_interval--media get entity by name: str-eam_cif_dvp_id0 is null
media get entity by name: stream_ci-f_dvp_id1 is null
media get -entity by name: stream_cif_dvp-_id2 is null
media get entit-y by name: stream_cif_dvp_id3- is null
media get entity by -name: rkcif-lvds-subdev is null
media get entity by name: r-kcif-lite-lvds-subdev is null
media get entity by name: -rkcif-dvp-sof is null
----111111---------------0, 0
[   13.463890] gc2145_enum_frame_interval---------------00000---------------1, 8198
[   13.463917] file->index = 1, cfg_num =1
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rkcif_dvp is null
media get entity by name: rkcif_lite_mipi_lvds is null
media get entity by name: rkcif_mipi_lvds is null
[   13.475953] sc2210 cmd =8eb656c0
[08:00:13.475999][CAMHW]:XCAM ERROR CamHwIsp20.cpp:973: get isp or ispp info fail, something gos wrong!
register factory : rkmpp
register factory : live555_rtsp_server
register factory : video_enc
register factory : audio_enc
register factory : video_dec
register factory : file_read_flow
register factory : file_write_flow
register factory : filter
register factory : link_flow
register factory : source_stream
register factory : muxer_flow
register factory : audio_dec
register factory : output_stream
register factory : move_detec
register factory : occlusion_detec
register factory : file_write_stream
register factory : file_read_stream
register factory : alsa_playback_stream
register factory : alsa_capture_stream
register factory : v4l2_capture_stream
register factory : v4l2_output_stream
register factory : drm_output_stream
rga_api version 1.3.0_[11] (RGA is compiling with meson base: $PRODUCT_BASE)
register factory : rkrga
register factory : through_guard
register factory : ANR
register factory : AEC
register factory : rockx_filter
register factory : nn_result_input
register factory : draw_filter
register factory : rknn
register factory : face_capture
register factory : rockface_detect
register factory : rockface_evaluate
register factory : rockface_bodydetect
register factory : rockface_recognize
insmod NPU modules: QObject::startTimer: Timers can only be used with threads started with QThread
[   14.129807] galcore: loading out-of-tree module taints kernel.
[   14.147537] galcore: npu init.
[   14.149412] galcore: start npu probe.
[   14.149673] galcore ffbc0000.npu: Linked as a consumer to regulator.7
[   14.149991] npu: platform_get_irq irq = 67
[   14.150015] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[   14.150039] Galcore version 6.4.6.5.351518
[   14.150057] Galcore options:
[   14.150076]   irqLine           = 67
[   14.150093]   registerMemBase   = 0xFFBC0000
[   14.150112]   registerMemSize   = 0x00004000
[   14.150131]   contiguousSize    = 0x00400000
[   14.150149]   contiguousBase    = 0x0
[   14.150167]   externalSize      = 0x00000000
[   14.150184]   externalBase      = 0x0
[   14.150202]   exclusiveSize     = 0x00000000
[   14.150219]   exclusiveBase     = 0x0
[   14.150233]   bankSize          = 0x00000000
[   14.150246]   fastClear         = -1
[   14.150264]   compression       = 15
[   14.150283]   powerManagement   = 1
[   14.150301]   baseAddress       = 0x00000000
[   14.150319]   physSize          = 0x00000000
[   14.150395]   recovery          = 1
[   14.150431]   stuckDump         = 0
[   14.150461]   GPU smallBatch    = 1
[   14.150484]   allMapInOne       = 1
[   14.150518]   enableNN          = 0xff
[   14.150551]   userClusterMasks  =
[   14.150559] ff,
[   14.150583] ff,
[   14.150600] ff,
[   14.150634] ff,
[   14.150652] ff,
[   14.150670] ff,
[   14.150688] ff,
[   14.150707] ff,
[   14.150742]
[   14.150776]   irqs              =
[   14.150786] 67,
[   14.150831] -1,
[   14.150856] -1,
[   14.150874] -1,
[   14.150892] -1,
[   14.150909] -1,
[   14.150926] -1,
[   14.150939] -1,
[   14.150952] -1,
[   14.150969] -1,
[   14.150990] -1,
[   14.151006]
[   14.151042]   registerBases     =
[   14.151045] 0xFFBC0000,
[   14.151065] 0x00000000,
[   14.151082] 0x00000000,
[   14.151100] 0x00000000,
[   14.151117] 0x00000000,
[   14.151134] 0x00000000,
[   14.151152] 0x00000000,
[   14.151169] 0x00000000,
[   14.151182] 0x00000000,
[   14.151195] 0x00000000,
[   14.151212] 0x00000000,
[   14.151230]
[   14.151256]   registerSizes     =
[   14.151260] 0x00004000,
[   14.151278] 0x00000000,
[   14.151295] 0x00000000,
[   14.151313] 0x00000000,
[   14.151330] 0x00000000,
[   14.151346] 0x00000000,
[   14.151364] 0x00000000,
[   14.151381] 0x00000000,
[   14.151398] 0x00000000,
[   14.151416] 0x00000000,
[   14.151429] 0x00000000,
[   14.151450]
[   14.151486]   chipIDs           =
[   14.151489] 0xFFFFFFFF,
[   14.151507] 0xFFFFFFFF,
[   14.151526] 0xFFFFFFFF,
[   14.151543] 0xFFFFFFFF,
[   14.151560] 0xFFFFFFFF,
[   14.151578] 0xFFFFFFFF,
[   14.151596] 0xFFFFFFFF,
[   14.151613] 0xFFFFFFFF,
[   14.151631] 0xFFFFFFFF,
[   14.151648] 0xFFFFFFFF,
[   14.151663] 0xFFFFFFFF,
[   14.151675]
[   14.151762]   core 0 internal sRAMBases =
[   14.151766] 0xFFFFFFFFFFFFFFFF,
[   14.151792] 0xFFFFFFFFFFFFFFFF,
[   14.151810]
[   14.151850]   core 1 internal sRAMBases =
[   14.151853] 0xFFFFFFFFFFFFFFFF,
[   14.151871OK
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
[   14.151890]
[   14.151911]   core 2 internal sRAMBases =
[   14.151914] 0xFFFFFFFFFFFFFFFF,
[   14.151932] 0xFFFFFFFFFFFFFFFF,
[   14.151962]
[   14.152119]   core 3 internal sRAMBases =
[   14.152128] 0xFFFFFFFFFFFFFFFF,
[   14.152159] 0xFFFFFFFFFFFFFFFF,
[   14.152179]
[   14.152210]   core 4 internal sRAMBases =
[   14.152214] 0xFFFFFFFFFFFFFFFF,
[   14.152233] 0xFFFFFFFFFFFFFFFF,
[   14.152262]
[   14.152304]   core 5 internal sRAMBases =
[   14.152308] 0xFFFFFFFFFFFFFFFF,
[   14.152326] 0xFFFFFFFFFFFFFFFF,
[   14.152344]
[   14.152371]   core 6 internal sRAMBases =
[   14.152375] 0xFFFFFFFFFFFFFFFF,
[   14.152388] 0xFFFFFFFFFFFFFFFF,
[   14.152403]
[   14.152431]   core 7 internal sRAMBases =
[   14.152434] 0xFFFFFFFFFFFFFFFF,
[   14.152452] 0xFFFFFFFFFFFFFFFF,
[   14.Starting vsftpd: 152469]
[   14.152503]   core 8 internal sRAMBases =
[   14.152506] 0xFFFFFFFFFFFFFFFF,
[   14.152576] 0xFFFFFFFFFFFFFFFF,
[   14.152599]
[   14.152626]   core 9 internal sRAMBases =
[   14.152630] 0xFFFFFFFFFFFFFFFF,
[   14.152652] 0xFFFFFFFFFFFFFFFF,
[   14.152669]
[   14.152703]   core 10 internal sRAMBases =
[   14.152707] 0xFFFFFFFFFFFFFFFF,
[   14.152725] 0xFFFFFFFFFFFFFFFF,
[   14.152741]
[   14.152768]   External sRAMBases =
[   14.152772] 0xffffffffffffffff,
[   14.152789] 0xffffffffffffffff,
[   14.152806]
[   14.152836]   mmuPageTablePool  = 1
[   14.152853]   mmuDynamicMap     = 1
[   14.152867]   isrPoll           = 0x00000000
[   14.152888] Build options:
[   14.152907]   gcdGPU_TIMEOUT    = 20000
[   14.152925]   gcdGPU_2D_TIMEOUT = 4000
[   14.152943]   gcdINTERRUPT_STATISTIC = 1
[   14.159162] Galcore Info: ContiguousBase=0x7f855000 ContiguousSize=0x400000
[   14.164610] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual address=0x400000 size=0x40000
[   14.164670] Galcore Info: MMU mapped core 0 SRAM[1] hardware virtual address=0x440000 size=0x40000
[   14.167927] galcore ffbc0000.npu: Init npu devfreq
[   14.168012] galcore ffbc0000.npu: bin=0
[   14.168092] galcore ffbc0000.npu: leakage=2.125
[   14.168492] galcore ffbc0000.npu: Failed to set pvtm_volt
[   14.168641] galcore ffbc0000.npu: Failed to get pvtm
[   14.168701] galcore ffbc0000.npu: bin-scale=23
[   14.169520] galcore ffbc0000.npu: avs=0
[   14.169989] galcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[   14.170045] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[   14.170194] galcore ffbc0000.npu: failed to find power_model node
[   14.170223] galcore ffbc0000.npu: failed to initialize power model
[   14.174427] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[   14.174550] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[   14.174588] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[   14.174664] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
OK
[   14.203862] Freeing drm_logo memory: 12148K
[   14.210500] dwc3 ffd00000.dwc3: device reset
Starting dnsmasq:
dnsmasq: failed to create listening socket for port 53: Address already in use
FAIL
[   14.282701] dwc3 ffd00000.dwc3: device reset
[   14.282820] android_work: did not send uevent (0 0   (null))
LOG_INFO :*** update_engine: Version V1.1.4 ***.
LOG_INFO :Current Mode is recovery.
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf...
input-event-daemon: Adding device: /dev/input/event0...
input-event-daemon: open(/dev/input/event1): No such file or directory
input-event-daemon: open(/dev/input/event2): No such file or directory
input-event-daemon: Start listening on 1 devices...
done
[root@ATK-DLRV1126:/]# [   14.341521] android_work: sent uevent USB_STATE=CONNECTED
test stdout
[   14.476792] dwc3 ffd00000.dwc3: device reset
[   14.477001] android_work: sent uevent USB_STATE=DISCONNECTED
[   14.546332] dwc3 ffd00000.dwc3: device reset
[   14.546446] android_work: did not send uevent (0 0   (null))
[   14.606615] android_work: sent uevent USB_STATE=CONNECTED
[   14.613767] configfs-gadget gadget: full-speed config #1: b
[   14.614128] android_work: sent uevent USB_STATE=CONFIGURED
start rknn server, version:1.7.0 (7880361 build: 2021-08-16 14:05:08)
I NPUTransfer: Starting NPU Transfer Server, Transfer version 2.1.0 (b5861e7@2020-11-23T11:51:07)
fontfamilies: ("Montserrat")
[   16.363763] of_dma_request_slave_channel: dma-names property of node '/serial@ff590000' missing or empty
[   16.363821] ttyS4 - failed to request DMA, use interrupt mode
[   16.364108] ttyS4 set divisor fail, quot:156 != dll,dlh:0
[   16.364418] ttyS4 set divisor fail, quot:13 != dll,dlh:0
[   16.364900] of_dma_request_slave_channel: dma-names property of node '/serial@ff5a0000' missing or empty
[   16.364937] ttyS5 - failed to request DMA, use interrupt mode
[   16.365166] ttyS5 set divisor fail, quot:156 != dll,dlh:0
[   16.365255] ttyS5 set divisor fail, quot:13 != dll,dlh:0
WARNING: Cannot find style "greywhite" - fallback: "default"
Please check the path in QCoreApplication::applicationDirPath:  "/demo"
[   19.189524] gc2145_enum_frame_interval---------------00000---------------0, 0
[   19.189533] file->index = 0, cfg_num =1
[   19.189612] gc2145_enum_frame_interval---------------111111---------------0, 0
[   19.189642] gc2145_enum_frame_interval---------------00000---------------1, 8198
[   19.189661] file->index = 1, cfg_num =1
[   19.194033] sc2210 cmd =8eb656c0
[   19.300865] gc2145 1-003c: gc2145_power(2721) on(1)
[   19.301033] ----------i=5
[   19.308327] rkcif_dvp: stream[0] start streaming
[   19.308405] ----------i=5
[   19.308958] rkcif_dvp: Allocate dummy buffer, size: 0x00065400
[   19.309031] -----multi_id = 16
[   19.309056] BT1120_CLOCK_SINGLE_EDGES
[   19.309080] rkcif_dvp: set dual edge mode(off,0x1000000)!!!
[   19.309094] RKCIF_CLK_RISING
[   19.309109] V4L2_STD_PAL
[   19.309122] V4L2_MBUS_BT656
[   19.309135] BT1120_TRANSMIT_INTERFACE
[   19.309149] -------val=10010009
[   19.309165] -------val=10010009
[   19.309188] val = 720
[   19.309226] pingpong enter:2924
[   19.309256] pingpong exit:2928
[   19.309316] gc2145 1-003c: gc2145_s_stream: on: 1, 720x576@25
[   19.309349] gc2145->streaming =0 on=1
[   20.312235] sc2210 cmd =401056c5
[   20.312319] sc2210 1-0030: set fmt: cur_mode: 1920x1080, hdr: 0
[   20.312354] sc2210 1-0030: sensor mode: 0
[   20.312872] sc2210 cmd =801056c9
[   20.341660] sc2210 cmd =801056c9
[   20.341733] sc2210 cmd =400456c6
[   20.341765] sc2210 cmd =401056c8
[   20.360413] sc2210 cmd =801056c4
[   20.469357] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: stream on:1
[   20.469433] rockchip-mipi-dphy-rx: data_rate_mbps 222
[   20.630223] sc2210 1-0030: set exposure 0x60
[   20.630286] sc2210 1-0030: recv:48 set again 0x3, again_fine 0x30, set dgain 0x0, dgain_fine 0x80
[   20.793628] rkisp1: tx stream:4 lose frame:3, isp state:0x204 frame:1
[   20.803916] sc2210 cmd =801056c9
[   20.804006] sc2210 cmd =400456c6
[   20.804052] sc2210 cmd =401056c8
[   20.836628] sc2210 cmd =801056c9
[   20.836714] sc2210 cmd =400456c6
[   20.836736] sc2210 cmd =401056c8
qml: onGlobal_Page_final_process_btnChanged0
ButtonProcessSlot_map "fn_info_boardcast_enable" "0" -------------
[server.c][fn_info_boardcast_enable]:fn_info_boardcast_enable==========
QThread::wait: Thread tried to wait on itself
[   20.870174] sc2210 cmd =801056c9
[   20.870250] sc2210 cmd =400456c6
[   20.870272] sc2210 cmd =401056c8
[   20.903309] sc2210 cmd =801056c9
[   20.903379] sc2210 cmd =400456c6
[   20.903408] sc2210 cmd =401056c8
[   20.936417] sc2210 cmd =801056c9
[   20.936495] sc2210 cmd =400456c6
[   20.936525] sc2210 cmd =401056c8
[   20.970044] sc2210 cmd =801056c9
[   20.970114] sc2210 cmd =400456c6
[   20.970137] sc2210 cmd =401056c8
qml: global_appIndex : 1
qml: normalStartApp  --------1---------ATKCamera
[   21.003304] sc2210 cmd =801056c9
[   21.003381] sc2210 cmd =400456c6
[   21.003438] sc2210 cmd =401056c8
[   21.036428] sc2210 cmd =801056c9
[   21.036502] sc2210 cmd =400456c6
[   21.036525] sc2210 cmd =401056c8
[   21.069825] sc2210 cmd =801056c9
[   21.069902] sc2210 cmd =400456c6
[   21.069923] sc2210 cmd =401056c8
[   21.103090] sc2210 cmd =801056c9
[   21.103170] sc2210 cmd =400456c6
[   21.103199] sc2210 cmd =401056c8
qml: 当前item是0
[   21.136443] sc2210 cmd =801056c9
[   21.136518] sc2210 cmd =400456c6
[   21.136545] sc2210 cmd =401056c8
[   21.170011] sc2210 cmd =801056c9
[   21.170101] sc2210 cmd =400456c6
[   21.170123] sc2210 cmd =401056c8
[   21.203107] sc2210 cmd =801056c9
[   21.203183] sc2210 cmd =400456c6
[   21.203210] sc2210 cmd =401056c8
[   21.236519] sc2210 cmd =801056c9
[   21.236631] sc2210 cmd =400456c6
[   21.236659] sc2210 cmd =401056c8
[   21.269762] sc2210 cmd =801056c9
[   21.269837] sc2210 cmd =400456c6
[   21.269865] sc2210 cmd =401056c8
[   21.303104] sc2210 cmd =801056c9
[   21.303180] sc2210 cmd =400456c6
[   21.303209] sc2210 cmd =401056c8
[   21.336424] sc2210 cmd =801056c9
[   21.336507] sc2210 cmd =400456c6
[   21.336536] sc2210 cmd =401056c8
[   21.369851] sc2210 cmd =801056c9
[   21.369935] sc2210 cmd =400456c6
[   21.369965] sc2210 cmd =401056c8
[   21.403136] sc2210 cmd =801056c9
[   21.403211] sc2210 cmd =400456c6
[   21.403240] sc2210 cmd =401056c8
qml: onGlobal_Page_final_process_btnChangednone
ButtonProcessSlot_map "fn_config_para_main2storage" "none" -------------
[server.c][fn_config_para_main2storage]:fn_config_para_main2storage==========////////////////
[rkipc_server][__rec_configPara_handler]:-----------__rec_configPara_handler------1----100-
DDR Version V1.08 20210825
DDR4, 328MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc6ee75eec1-210728 #zzz (Sep 13 2021 - 10:36:14)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC error: The cmd index is 1, ret is -110
mmc_init: -95, time 9
Trying to boot from MMC1
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
## Verified-boot: 0
## Checking optee 0x08400000 (gzip @0x08600000) ... sha256(7beb6b43df...) + sha256(bae962097a...) + OK
## Checking uboot 0x00600000 (gzip @0x00800000) ... sha256(a79b29d8d6...) + sha256(b07be23f78...) + OK
## Checking fdt 0x006bd070 ... sha256(a362d022de...) + OK
Jumping to U-Boot(0x00600000) via OP-TEE(0x08400000)
Total: 128.529 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
I/TC: Next entry point address: 0x00600000
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #zhangzj (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug  4 03:30:34 UTC 2021 arm
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
U-Boot 2017.09 (May 07 2024 - 03:53:30 -0700)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM:  2 GiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 7bbf9e50 - 7bbfede0
CR: M/C/I
device_node_name:adc-keys
device_node_name:dwmmc
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
fdt_addr_r = 8300000
resource_is_empty fun:resource_is_empty line:456
test--------------------
test-33333--------------line:479
test-33333--------------line:502
test-33333--------------line:516
---------------size =12631552, offset =6317568, dev_desc->blksz = 512
data =7bdd58c0
test444444---------------276
test444444---------------279
test444444---------------281
test444444---part->start =8000--blk_off =3036----blk_num =24671------282
__fit_image_load_one 283   7bdd58c0
52 53 43 45 00 00 00 00 01 01 01 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
test444444---------------339
test-33333--------------line:522
test-33333--------------line:529
FIT: no signed, no conf required
func:resource_traverse_init_list line:717
DTB: --------1-------<NULL>
[HW-ADC]: rv1126-xygd-1080p#_saradc_ch4=0.dtb
lcd adc_record[4] = 0,adc_record[4]= 0
adc_val =0.dtb
dtb_adc = 0
   - dev=saradc, channel=4, dtb_adc=0, read=0, found=1
cell_name =<NULL>
DTB: --------2-------rv1126-xygd-1080p#_saradc_ch4=0.dtb
len = 0
len = 92766
file->ram = 1
file->rsce_base = 7bdd58c0
file->f_size = 92766
file->name =rv1126-xygd-1080p#_saradc_ch4=0.dtb
file->f_offset = 187, offset = 0, dev_desc->blksz = 512
src = 7bdecec0
d0 0d fe ed 00 01 6a 5e 00 00 00 38 00 01 34 c8 00 00 00 28
p = 08300000
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
end--
src = 7bdecec0
p = 08300000
1---end--
end--
----end--
DTB: rv1126-xygd-1080p#_saradc_ch4=0.dtb
device_node_name:crypto
HASH(c): OK
device_node_name:saradc
device_node_name:gpio1
device_node_name:gpio3
device_node_name:i2c
device_node_name:decompress
device_node_name:nandc
device_node_name:usb0
device_node_name:usb2-phy
device_node_name:serial
device_node_name:sfc
device_node_name:dwc3
device_node_name:phy
device_node_name:volumeup-key
device_node_name:menu-key
device_node_name:amba
device_node_name:clock-controller
io-domain: OK
rockchip_display_probe node.np->name = route-dsi
rockchip_display_probe: panel_i2c_busnum = 3
lt9211_is_connected  lt9211 connect = 0
find connect node's handle 16
find ep_node /vop@ffb00000/port/endpoint@1
find port_node /vop@ffb00000/port
find port_parent_node /vop@ffb00000
load_mipi2lvds_driver: lt9211@2d
I2c3 speed: 400000Hz
lt9211_parse_dt mipi-format=2 mipi-bpp=24 test-pattern=false
lt9211_ConvertBoard_power_off
lt9211_ConvertBoard_power_on
lt9211_chip_shutdown
lt9211_chip_enable
id: 0x21 0x03 0xe0
lt9211_detect successful
lt9211_probe : lt9211 is connected!
lt9211_probe -
load_mipi2lvds_driver: lt9211@2d : ret=0
lt9211_is_connected  lt9211 connect = 1
panel_simple_dsi_of_get_desc_data t1=1 t2=500 t3=200 t4=1 t5=1000
test:-------------------------------2362
test:2364 dsi@ffb30000.0
Can't get crtc id, default set to id = 0
Could not find baseparameter partition
Model: Rockchip RV1126 38x38 V10 EMMC DDR3 Board
len = 512
len = 512
file->ram = 1
file->f_size = 6220854
file->f_offset = 369, offset = 0, dev_desc->blksz = 512
src = 7be03ac0
42 4d 36 ec 5e 00 cf 20 00 00 36 00 00 00 28 00 00 00 80 07
p = 7ca0a298
end--
src = 7be03ac0
p = 7ca0a298
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7be03ac0
p = 7df00000
end--
src = 7be03ac0
p = 7df00000
1---end--
end--
----end--
Rockchip UBOOT DRM driver version: v1.0.1
test 857
test 863
test 866
test 892
test 894
test:541
timing = display-timings
lt9211_set_videomode - clk: 148500000 hact: 1920 hfp: 88 hs: 44 hbp: 148 vact: 1080  vfp: 4 vs: 5 vbp: 36
display_get_timing_from_dts hactive = 1920 vactive = 1080 pixelclock = 148500 flags =0xa
Using display timing dts
test 896
test 932
test 937
dsi@ffb30000:  detailed mode clock 148500 kHz, flags[a]
    H: 1920 2008 2052 2200
    V: 1080 1084 1089 1125
bus_format: 100e
final DSI-Link bandwidth: 990 Mbps x 4
in panel_simple_prepare 1
in panel_simple_prepare 2
lt9211_bridge_enable
lt9211_chip_enable
lt9211_init_seq
[INFO ] MIPI Input PortA
[INFO ] Mipi DSI Input
[INFO ] hact = 1920
[INFO ] vact = 1080
[INFO ] fmt = 0x0a
[INFO ] pa_lpn = 0x55
[INFO ] MipiRx Input Format: RGB 8Bit
[INFO ] ---------test, line:380
[INFO ] ---------test, line:386
[INFO ] FrameRate = 59
[INFO ] Video Timing Set 1920x1080_59
[INFO ] Mipi Rx PixClk: 148500
[WARN ] PCR unstable M = 0x17
[INFO ] LT9211C pcr stable
-----ulRtn = 74247
[INFO ] Tx Pll Lock
[INFO ] MIPI Output PortA & B
-----ulRtn = 125000
[INFO ] MipiTx Output Format: RGB 8bit
Start initial panel
cmd_list set 0x25 , mdelay(100).
cmd_list set 0x26 , mdelay(100).
cmd_list set 0x11 , mdelay(100).
cmd_list set 0x29 , mdelay(100).
cmd_list set 0xCD , mdelay(100).
Finish initial panel
[INFO ] Mipi DSI Out
[exit:]lt9211_init_seq
panel_simple_enable
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 462000 KHz
  gpll 1188000 KHz
  cpll 500000 KHz
  hpll 1400000 KHz
  aclk_pdbus 500000 KHz
  hclk_pdbus 198000 KHz
  pclk_pdbus 99000 KHz
  aclk_pdphp 297000 KHz
  hclk_pdphp 198000 KHz
  hclk_pdaudio 148500 KHz
  hclk_pdcore 198000 KHz
  pclk_pdpmu 99000 KHz
Net:   device_node_name:ethernet
eth0: ethernet@ffc40000
Hit key to stop autoboot('CTRL+C'):  0
## Booting FIT Image at 0x7b3f0240 with size 0x00606c00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 7b3f0240 ...
   Using 'conf' configuration
optee api revision: 2.0
TEEC: Waring: Could not find security partition
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x7b407640
     Data Size:    6223864 Bytes = 5.9 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x02008000
     Entry Point:  0x02008000
     Hash algo:    sha256
     Hash value:   eb3b3ea53c676c4c5e85d576bdf7d302ddb74187aeba2c3afd56337b087cb0fa
   Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 7b3f0240 ...
   Trying 'fdt' fdt subimage
     Data Start:   0x7b3f0a40
     Data Size:    92766 Bytes = 90.6 KiB
     Architecture: ARM
     Load Address: 0x08300000
     Hash algo:    sha256
     Hash value:   dfd9f487ab1061510e53e2bcc4af8add91318a8c74e8e0b32cc878b246e31b3c
   Loading fdt from 0x08300000 to 0x08300000
   Booting using the fdt blob at 0x08300000
--Debug-Load the OS---func:do_bootm_states, line: 722
-----BOOT LOAD OS Line:526
   Loading Kernel Image from 0x7b407640 to 0x02008000 ... -------------comp: 0
------Line: 430
---------------to : 02008000, from :7b407640, len =6223864
testttt 568
------Line: 432
OK
-----BOOT LOAD OS END Line:530
   kernel loaded at 0x02008000, end = 0x025f77f8
--Debug-Load the OS-end----func:do_bootm_states, line: 738
  'reserved-memory' ramoops@8000000: addr=8000000 size=100000
--Debug----func:do_bootm_states, line: 764
   Using Device Tree in place at 08300000, end 08319a5d
len = 512
len = 512
file->ram = 1
file->f_offset = 12520, offset = 0, dev_desc->blksz = 512
src = 7c3f28c0
p = 7ca0df60
end--
src = 7c3f28c0
p = 7ca0df60
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7c3f28c0
p = 7e4ef000
end--
src = 7c3f28c0
p = 7e4ef000
1---end--
end--
----end--
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x80000000 (size: 0x779b8000)
Total: 3527.702 ms
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Linux version 4.19.111 (kingsun@ubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #110 SMP PREEMPT Sun Apr 28 04:42:10 PDT 2024
[    0.000000] OF: fdt: Machine model: Rockchip RV1126 38x38 V10 EMMC DDR3 Board
[    0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x7f800000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x5dc00000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522376
[    0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 snd_aloop.index=7
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1518464K/2094816K available (8192K kernel code, 391K rwdata, 1960K rodata, 1024K init, 276K bss, 43872K reserved, 532480K cma-reserved, 872584K highmem)
[    0.000000]     vmalloc : 0xda000000 - 0xff800000   ( 600 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xd9800000   ( 664 MB)
[    0.000000]     pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
[    0.000000]     modules : 0xaf000000 - 0xafe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 392 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 277 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000758] Switching to timer-based delay loop, resolution 41ns
[    0.002602] Console: colour dummy device 80x30
[    0.003073] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.004033] pid_max: default: 4096 minimum: 301
[    0.004634] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.005261] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.006659] CPU: Testing write buffer coherency: ok
[    0.007489] /cpus/cpu@f00 missing clock-frequency property
[    0.008016] /cpus/cpu@f01 missing clock-frequency property
[    0.008539] /cpus/cpu@f02 missing clock-frequency property
[    0.009061] /cpus/cpu@f03 missing clock-frequency property
[    0.009620] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.010886] Setting up static identity map for 0x100000 - 0x100060
[    0.011643] rcu: Hierarchical SRCU implementation.
[    0.012742] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.014776] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.016475] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.018120] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.018258] smp: Brought up 1 node, 4 CPUs
[    0.020268] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.020852] CPU: All CPU(s) started in SVC mode.
[    0.022298] devtmpfs: initialized
[    0.046448] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.047836] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.048754] futex hash table entries: 16 (order: -2, 1024 bytes)
[    0.049557] pinctrl core: initialized pinctrl subsystem
[    0.051306] NET: Registered protocol family 16
[    0.052409] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.055209] cpuidle: using governor menu
[    0.055610] Registered FIQ tty driver
[    0.056521] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.057267] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.060003] console [pstore-1] enabled
[    0.060604] pstore: Registered ramoops as persistent store backend
[    0.061189] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[    0.108892] cryptd: max_cpu_qlen set to 1000
[    0.110171] fiq debugger fiq mode enabled
[ [    0.110966] console [ttyFIQ0] enabled
[    0.111647] bootconsole [uart8250] disabled
[    0.112356] Registered fiq debugger ttyFIQ0
[    0.113019] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    0.116585] vcc_sd: supplied by vcc3v3_sys
[    0.117085] reg-fixed-voltage vdd-arm: Fixed regulator specified with variable voltages
[    0.117138] reg-fixed-voltage: probe of vdd-arm failed with error -22
[    0.117248] reg-fixed-voltage vdd-logic-npu-vepu: Fixed regulator specified with variable voltages
[    0.117290] reg-fixed-voltage: probe of vdd-logic-npu-vepu failed with error -22
[    0.118397] rk_iommu ffb00f00.iommu: version = 1
[    0.119033] rk_iommu ffb20800.iommu: version = 1
[    0.119500] rk_iommu ffb60e00.iommu: version = 1
[    0.120141] rk_iommu ffb80480.iommu: version = 1
[    0.120693] rk_iommu ffb90800.iommu: version = 1
[    0.121180] rk_iommu ffbb0f00.iommu: version = 1
[    0.122248] SCSI subsystem initialized
[    0.122574] usbcore: registered new interface driver usbfs
[    0.122667] usbcore: registered new interface driver hub
[    0.122844] usbcore: registered new device driver usb
[    0.122964] media: Linux media interface: v0.10
[    0.123035] videodev: Linux video capture interface: v2.00
[    0.123104] pps_core: LinuxPPS API ver. 1 registered
[    0.123126] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.123170] PTP clock support registered
[    0.125169] Bluetooth: Core ver 2.22
[    0.125258] NET: Registered protocol family 31
[    0.125282] Bluetooth: HCI device and connection manager initialized
[    0.125312] Bluetooth: HCI socket layer initialized
[    0.125338] Bluetooth: L2CAP socket layer initialized
[    0.125397] Bluetooth: SCO socket layer initialized
[    0.125917] rockchip-cpuinfo cpuinfo: SoC            : 11260000
[    0.125953] rockchip-cpuinfo cpuinfo: Serial         : 04a143fbbeca61df
[    0.126916] clocksource: Switched to clocksource arch_sys_counter
[    0.140936] NET: Registered protocol family 2
[    0.141924] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.141987] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.142143] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.142347] TCP: Hash tables configured (established 8192 bind 8192)
[    0.142520] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.142596] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.142827] NET: Registered protocol family 1
[    0.144736] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.147571] Initialise system trusted keyrings
[    0.147831] workingset: timestamp_bits=29 max_order=19 bucket_order=0
[    0.155259] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.158090] Key type asymmetric registered
[    0.158125] Asymmetric key parser 'x509' registered
[    0.158200] bounce: pool size: 64 pages
[    0.158267] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.158295] io scheduler noop registered
[    0.158315] io scheduler deadline registered
[    0.158491] io scheduler cfq registered (default)
[    0.158520] io scheduler mq-deadline registered
[    0.158541] io scheduler kyber registered
[    0.158703] io scheduler bfq registered
[    0.162897] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
[    0.168763] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.168919] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.169312] mpp_service mpp-srv: 4a6b4c5b4 author: sun fan 2023-09-09 version 1.0
[    0.169336] mpp_service mpp-srv: probe start
[    0.170403] iommu: Adding device ffb80000.rkvdec to group 3
[    0.170459] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[    0.170662] mpp_rkvdec ffb80000.rkvdec: probing start
[    0.171305] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[    0.171329] rkvdec_init:1190: No niu aclk reset resource define
[    0.171362] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[    0.171383] rkvdec_init:1193: No niu hclk reset resource define
[    0.171704] mpp_rkvdec ffb80000.rkvdec: probing finish
[    0.172499] iommu: Adding device ffbb0000.rkvenc to group 5
[    0.172556] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[    0.172846] mpp_rkvenc ffbb0000.rkvenc: probing start
[    0.173546] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.7
[    0.173687] mpp_rkvenc ffbb0000.rkvenc: bin=0
[    0.173747] mpp_rkvenc ffbb0000.rkvenc: leakage=2.625
[    0.173825] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[    0.173877] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[    0.174439] mpp_rkvenc ffbb0000.rkvenc: avs=0
[    0.174839] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[    0.174877] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[    0.175483] mpp_rkvenc ffbb0000.rkvenc: probing finish
[    0.176185] iommu: Adding device ffb90400.vdpu to group 4
[    0.176231] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[    0.176348] mpp_vdpu2 ffb90400.vdpu: probe device
[    0.176884] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.176990] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177260] mpp_vdpu2 ffb90400.vdpu: probing finish
[    0.177963] iommu: Adding device ffb90000.vepu to group 4
[    0.178019] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[    0.178147] mpp_vepu2 ffb90000.vepu: probe device
[    0.178639] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178681] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178910] mpp_vepu2 ffb90000.vepu: probing finish
[    0.179393] iommu: Adding device ffb20000.iep to group 1
[    0.179447] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[    0.179569] mpp-iep2 ffb20000.iep: probe device
[    0.180340] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[    0.180552] mpp-iep2 ffb20000.iep: probing finish
[    0.180786] mpp_service mpp-srv: probe success
[    0.185966] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.186011] dma-pl330 ff4e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.188069] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.189011] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.190032] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 32, base_baud = 1500000) is a 16550A
[    0.191032] ff590000.serial: ttyS4 at MMIO 0xff590000 (irq = 33, base_baud = 1500000) is a 16550A
[    0.191820] ff5a0000.serial: ttyS5 at MMIO 0xff5a0000 (irq = 34, base_baud = 1500000) is a 16550A
[    0.193791] rockchip_drm_init----------------000--------------
[    0.193918] random: fast init done
[    0.194316] random: crng init done
[    0.194865] iommu: Adding device ffb00000.vop to group 0
[    0.194923] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[    0.195013] clk: failed to reparent dclk_vop to cpll: -22
[    0.198188] rockchip_drm_init----------------001--------------
[    0.198268] rockchip_drm_platform_probe----------------001--------------
[    0.198312] rockchip_drm_platform_probe----------------002--------------
[    0.199223] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[    0.200360] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[    0.201557] rockchip_drm_platform_probe----------------003--------------
[    0.201589] rockchip_drm_bind----------------011--------------
[    0.201765] rockchip-drm display-subsystem: devfreq is not set
[    0.202251] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.202283] dw_mipi_dsi_bind----------------00--------------
[    0.202288] dw_mipi_dsi_bind----------------01--------------
[    0.202313] dw_mipi_dsi_bind----------------02--------------
[    0.202352] drm_of_find_panel_or_bridge  panel is null
[    0.202385] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
[    0.202429] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb09439ac): -517
[    0.202702] rockchip-drm display-subsystem: master bind failed: -517
[    0.203060] rockchip_drm_init----------------002--------------
[    0.207926] panel_simple_dsi_probe dsi_id =-19
[    0.207974] panel_simple_dsi_probe node--name =dsi@ffb30000
[    0.208033] drm_display_mode_from_videomode------------------------------148
[    0.208059] panel_simple_dsi_probe----------------0002--------------
[    0.208116] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply power not found, using dummy regulator
[    0.208230] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[    0.208272] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[    0.208374] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[    0.209642] zram: Added device: zram0
[    0.211705] libphy: Fixed MDIO Bus: probed
[    0.213012] PPP generic driver version 2.4.2
[    0.213261] PPP BSD Compression module registered
[    0.213288] PPP Deflate Compression module registered
[    0.213327] PPP MPPE Compression module registered
[    0.213348] NET: Registered protocol family 24
[    0.213464] usbcore: registered new interface driver asix
[    0.213549] usbcore: registered new interface driver ax88179_178a
[    0.213658] usbcore: registered new interface driver cdc_ether
[    0.213733] usbcore: registered new interface driver net1080
[    0.213803] usbcore: registered new interface driver cdc_subset
[    0.213894] usbcore: registered new interface driver zaurus
[    0.214000] usbcore: registered new interface driver cdc_ncm
[    0.215663] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[    0.221284] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.221323] ehci-platform: EHCI generic platform driver
[    0.224929] ehci-platform ffe00000.usb: EHCI Host Controller
[    0.224996] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[    0.225208] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[    0.236981] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[    0.237288] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.237323] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.237348] usb usb1: Product: EHCI Host Controller
[    0.237371] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[    0.237395] usb usb1: SerialNumber: ffe00000.usb
[    0.238171] hub 1-0:1.0: USB hub found
[    0.238248] hub 1-0:1.0: 1 port detected
[    0.238968] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.239009] ohci-platform: OHCI generic platform driver
[    0.239578] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[    0.239637] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[    0.239826] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[    0.298004] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.298041] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.298060] usb usb2: Product: Generic Platform OHCI controller
[    0.298080] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[    0.298120] usb usb2: SerialNumber: ffe10000.usb
[    0.298866] hub 2-0:1.0: USB hub found
[    0.298939] hub 2-0:1.0: 1 port detected
[    0.300658] usbcore: registered new interface driver cdc_acm
[    0.300691] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.300834] usbcore: registered new interface driver usb-storage
[    0.300995] usbcore: registered new interface driver option
[    0.301048] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.302182] i2c /dev entries driver
[    0.305413] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.305681] rtc-pcf8563 0-0051: registered as rtc0
[    0.306935] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.306968] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[    0.311527] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[    0.312905] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[    0.312960] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[    0.313093] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[    0.313195] rkcif rkcif_dvp: attach to cif hw node
[    0.313218] rkcif rkcif_dvp: rkcif wait line 0
[    0.313262] RKCIF_WORKMODE_PINGPONG
[    0.314801] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[    0.314907] rkcif rkcif_mipi_lvds: attach to cif hw node
[    0.314931] rkcif rkcif_mipi_lvds: rkcif wait line 0
[    0.314961] RKCIF_WORKMODE_PINGPONG
[    0.315998] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[    0.316030] rockchip-mipi-csi2: Async registered subdev
[    0.318437] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[    0.318476] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[    0.318799] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[    0.318848] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[    0.319174] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[    0.319413] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    0.319659] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.319703] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.319734] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.322760] rkisp rkisp-vir1: rkisp driver version: v01.06.02
[    0.323013] rkisp rkisp-vir1: No memory-region-thunderboot specified
[    0.323237] rkisp rkisp-vir1: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.323279] rkisp rkisp-vir1: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.323308] rkisp rkisp-vir1: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.327128] iommu: Adding device ffb60000.rkispp to group 2
[    0.327191] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[    0.327619] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[    0.327669] rkispp_hw ffb60000.rkispp: can't request region for resource [mem 0xffb60000-0xffb7ffff]
[    0.327911] rkispp_hw ffb60000.rkispp: failed to get cru reset
[    0.328211] rkispp rkispp-vir0: rkispp driver version: v01.06.02
[    0.330620] rkispp rkispp-vir1: rkispp driver version: v01.06.02
[    0.333331] usbcore: registered new interface driver uvcvideo
[    0.333366] USB Video Class driver (1.1.1)
[    0.333886] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.3
[    0.333939] rockchip-iodomain fe020000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    0.334075] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[    0.334198] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    0.334335] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.5
[    0.334372] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc3v3_sys
[    0.334486] rockchip-iodomain fe020000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    0.334614] rockchip-iodomain fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vcc_1v8
[    0.334745] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(1800000 uV) supplied by vcc_1v8
[    0.334870] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[    0.337722] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -7
[    0.338169] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[    0.338650] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -7
[    0.338958] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[    0.340527] Bluetooth: HCI UART driver ver 2.3
[    0.340553] Bluetooth: HCI UART protocol H4 registered
[    0.340896] cpu cpu0: bin=0
[    0.340937] cpu cpu0: leakage=3.375
[    0.340986] cpu cpu0: Failed to get reg
[    0.341017] cpu cpu0: bin-scale=5
[    0.341345] cpuidle: enable-method property 'psci' found operations
[    0.341520] cpuidle: enable-method property 'psci' found operations
[    0.341684] cpuidle: enable-method property 'psci' found operations
[    0.341834] cpuidle: enable-method property 'psci' found operations
[    0.342568] Synopsys Designware Multimedia Card Interface Driver
[    0.343546] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[    0.343658] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[    0.343696] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[    0.343793] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    0.344017] mmc_host mmc0: card is non-removable.
[    0.357077] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.370951] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[    0.371059] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[    0.371088] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[    0.371242] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    0.371445] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.6
[    0.371550] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.3
[    0.406436] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[    0.406497] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[    0.407061] mmc0: new HS200 MMC card at address 0001
[    0.410766] mmcblk0: mmc0:0001 DA4064 58.2 GiB
[    0.411960] mmcblk0boot0: mmc0:0001 DA4064 partition 1 4.00 MiB
[    0.413123] mmcblk0boot1: mmc0:0001 DA4064 partition 2 4.00 MiB
[    0.413707] mmcblk0rpmb: mmc0:0001 DA4064 partition 3 16.0 MiB, chardev (242:0)
[    0.424306]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    0.489967] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.503633] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.503721] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.503749] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.503845] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.504914] usbcore: registered new interface driver usbhid
[    0.504950] usbhid: USB HID core driver
[    0.507647] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.3
[    0.509296] rksfc_base v1.1 2016-01-08
[    0.510019] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[    0.510140] rkflash_dev_init enter
[    0.510173] sfc nor id: 0 0 0
[    0.510194] rkflash[1] is invalid
[    0.510198] rkflash_dev_init enter
[    0.510283] sfc_nand id: 0 0 0
[    0.510310] rkflash[2] is invalid
[    0.510934] NET: Registered protocol family 17
[    0.511045] NET: Registered protocol family 15
[    0.512362] Bluetooth: RFCOMM TTY layer initialized
[    0.512437] Bluetooth: RFCOMM socket layer initialized
[    0.512499] Bluetooth: RFCOMM ver 1.11
[    0.512533] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    0.512605] Bluetooth: HIDP socket layer initialized
[    0.512636] [BT_RFKILL]: Enter rfkill_rk_init
[    0.512656] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    0.513154] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    0.513294] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = USB-WiFi
[    0.513332] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    0.513367] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    0.513450] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 16 flags = 0.
[    0.513543] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    0.513559] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    0.513685] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    0.516662] flash vendor_init_thread!
[    0.516711] flash vendor storage:20170308 ret = -1
[    0.517642] gc2145 1-003c: driver version: 00.01.06
[    0.517704] gc2145_probe---------------00000---------------
[    0.517740] gc2145_probe---------------11111---------------
[    0.517792] gc2145_probe---------------22222---------------
[    0.517820] gc2145_probe---------------222221---------------
[    0.517840] gc2145_probe---------------2222211---------------
[    0.517859] fps =25
[    0.517885] gc2145_probe---------------33333---------------
[    0.517920] m01_b_gc2145 1-003c: Async registered subdev
[    0.517963] rkcif rkcif_dvp: Entity type for entity rkcif-dvp-sof was not initialized!
[    0.520001] ----------i=5
[    0.520055] ----------i=5
[    0.520081] ----------i=5
[    0.520103] ----------i=5
[    0.520120] rkcif_dvp: Async subdev notifier completed
[    0.520144] gc2145_probe---------------44444---------------
[    0.520158] gc2145 1-003c: m01_b_gc2145 1-003c sensor driver registered !!
[    0.520723] sc2210 1-0030: driver version: 00.01.06
[    0.520802] sc2210 1-0030:  Get hdr mode failed! no hdr default
[    0.521194] sc2210 1-0030: could not get sleep pinstate
[    0.521366] sc2210 1-0030: Linked as a consumer to regulator.2
[    0.521588] sc2210 1-0030: Linked as a consumer to regulator.3
[    0.521765] sc2210 1-0030: Linked as a consumer to regulator.4
[    0.521840] sc2210_initialize_controls---------------11111---------------0
[    0.521856] sc2210_initialize_controls---------------11111---------------0 74250000
[    0.528795] sc2210 1-0030: gain_mode 0b02
[    0.528862] sc2210 1-0030: Detected SC2210 sensor
[    0.528969] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: match m00_f_sc2210 1-0030:bus type 4
[    0.528998] sc2210_probe---------------11111---------------hdr_mode0
[    0.529015] sc2210_runtime_suspend---------------11111---------------
[    0.529575] Registering SWP/SWPB emulation handler
[    0.532833] Loading compiled-in X.509 certificates
[    0.535002] rga2: Driver loaded successfully ver:3.2.56726
[    0.535423] rga2: Module initialized.
[    0.556464] vendor storage:20190527 ret = 0
[    0.583776] rockchip_drm_platform_probe----------------001--------------
[    0.583799] rockchip_drm_platform_probe----------------002--------------
[    0.587533] rockchip_drm_platform_probe----------------003--------------
[    0.587655] rockchip_drm_bind----------------011--------------
[    0.587874] rockchip-drm display-subsystem: devfreq is not set
[    0.588413] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.588447] dw_mipi_dsi_bind----------------00--------------
[    0.588451] dw_mipi_dsi_bind----------------01--------------
[    0.588475] dw_mipi_dsi_bind----------------02--------------
[    0.588515] drm_of_find_panel_or_bridge  panel ret =0
[    0.588536] dw_mipi_dsi_bind----------------03--------------
[    0.588559] dw_mipi_dsi_bind----------------04--------------
[    0.588586] dw_mipi_dsi_bind----------------05--------------
[    0.588622] dw_mipi_dsi_bind----------------06--------------
[    0.588653] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb09439ac)
[    0.588696] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.588716] [drm] No driver support for vblank timestamp query.
[    0.588855] rockchip_drm_bind----------------010--------------
[    0.588861] show_loader_logo----------------011--------------
[    0.589069] setup_initial_state----------------encoder_funcs->loader_protect--------------
[    0.589102] dw_mipi_dsi_encoder_loader_protect----------------dw_mipi_dsi_encoder_loader_protect--------------c8610ecf
[    0.589125] panel_simple_loader_protect: on = 1!
[    0.589162] panel_simple_loader_protect----------------panel_simple_loader_protect--------------c8610ecf 1
[    0.589334] show_loader_logo----------------012--------------
[    0.623095] rockchip-drm display-subsystem: fb0:  frame buffer device
[    0.625846] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    0.625907] rockchip_drm_platform_probe----------------004--------------
[    0.626589] input: adc-keys as /devices/platform/adc-keys/input/input0
[    0.629753] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.629846] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.629876] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.629932] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.632639] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.632743] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.632780] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.632842] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.635229] rkcif rkcif_dvp: clear unready subdev num: 0
[    0.635300] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[    0.635325] rockchip-mipi-csi2: No link between dphy and sensor
[    0.636106] rockchip-mipi-csi2: No link between dphy and sensor
[    0.636165] rkcif_mipi_lvds: Async subdev notifier completed
[    0.637052] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    0.643243] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    0.643484] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    0.643514] cfg80211: failed to load regulatory.db
[    0.644915] rkisp rkisp-vir0: clear unready subdev num: 1
[    0.646084] rockchip-mipi-csi2: No link between dphy and sensor
[    0.646129] rockchip-mipi-csi2: No link between dphy and sensor
[    0.646155] rkisp0: Invalid mipi data type
[    0.646176] rkisp0: update sensor failed
[    0.646211] rkisp rkisp-vir1: clear unready subdev num: 1
[    0.648209] rkisp1: Async subdev notifier completed
[    0.656481] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[    0.656531] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[    0.697822] EXT4-fs (mmcblk0p6): recovery complete
[    0.699899] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    0.700006] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    0.704648] devtmpfs: mounted
[    0.706636] Freeing unused kernel memory: 1024K
[    0.707106] Run /sbin/init as init process
[    0.809372] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
NAME=Buildroot
VERSION=2018.02-rc3
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME="Buildroot 2018.02-rc3"
Starting logging: OK
/usr/bin/modetest
Populating /dev using udev: [    1.349560] udevd[117]: starting version 3.2.7
[    1.364046] udevd[117]: specified group 'kvm' unknown
[    1.407366] udevd[119]: starting eudev-3.2.7
[    1.443692] phy phy-ff4c0000.usb2-phy.1: charger = USB_SDP_CHARGER
[    1.676071] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.676204] rkcif_dvp: rkcif_update_sensor_info: stream[2] get remote sensor_sd failed!
[    1.676257] stream_cif_dvp_id2: update sensor info failed -19
[    1.682065] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.682211] rkcif_dvp: rkcif_update_sensor_info: stream[1] get remote sensor_sd failed!
[    1.682269] stream_cif_dvp_id1: update sensor info failed -19
[    1.696775] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.697003] rkcif_dvp: rkcif_update_sensor_info: stream[3] get remote sensor_sd failed!
[    1.697067] stream_cif_dvp_id3: update sensor info failed -19
[    1.706619] gc2145 1-003c: gc2145_power(2721) on(1)
[    1.707419] gc2145 1-003c: gc2145_power(2721) on(0)
[    1.717613] rockchip-mipi-csi2: No link between dphy and sensor
[    1.739508] rockchip-mipi-csi2: No link between dphy and sensor
[    1.752676] rockchip-mipi-csi2: No link between dphy and sensor
[    1.763830] rockchip-mipi-csi2: No link between dphy and sensor
[    1.776820] rockchip-mipi-csi2: No link between dphy and sensor
[    1.905146] sc2210_runtime_suspend---------------11111---------------
[    1.908468] sc2210 cmd =80685600
[    1.932940] sc2210_runtime_suspend---------------11111---------------
[    1.948900] sc2210_runtime_suspend---------------11111---------------
[    1.956071] sc2210_runtime_suspend---------------11111---------------
[    1.969380] sc2210_runtime_suspend---------------11111---------------
[    1.981011] sc2210_runtime_suspend---------------11111---------------
[    1.989942] sc2210_runtime_suspend---------------11111---------------
[    2.006310] sc2210_runtime_suspend---------------11111---------------
done
Will now mount all partitions in /etc/fstab
Note: Will auto format partitons, remove /.auto_mkfs to disable
Note: Create /.skip_fsck to skip fsck
 - The check might take a while if didn't shutdown properly!
Handling rootfs: /dev/mmcblk0p6 / ext2 rw,noauto 1
Checking /dev/mmcblk0p6(ext2)
[    2.032802] sc2210_runtime_suspend---------------11111---------------
[    2.782228] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
e2fsck 1.43.9 (8-Feb-2018)
rootfs: clean, 6951/65536 files, 171119/262144 blocks
[    2.845419] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
Handling misc: /dev/mmcblk0p2 /misc emmc defaults 0
Unsupported file system emmc for /dev/mmcblk0p2
Handling oem: /dev/mmcblk0p7 /oem ext2 defaults 2
Checking /dev/mmcblk0p7(ext2)
oem: recovering journal
oem: clean, 381/49152 files, 156117/196608 blocks
Mounting /dev/mmcblk0p7(ext2) on /oem
[    3.598795] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Handling userdata: /dev/mmcblk0p8 /userdata ext2 defaults 2
Checking /dev/mmcblk0p8(ext2)
userdata was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
DDR4, 328MHz
change to: 328MHz
change to: 528MHz
change to: 784MHz
out
unknown raw ID phN
mmc_init: -95, time 10
## Verified-boot: 0
Total: 128.450 ms
I/TC:
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
DRAM:  2 GiB
Sysmem: init
CR: M/C/I
MMC0: HS200, 200Mhz
PartType: EFI
data =7bdd58c0
adc_val =0.dtb
dtb_adc = 0
cell_name =<NULL>
len = 0
len = 92766
file->ram = 1
src = 7bdecec0
p = 08300000
end--
src = 7bdecec0
p = 08300000
1---end--
end--
----end--
HASH(c): OK
io-domain: OK
lt9211_chip_enable
id: 0x21 0x03 0xe0
lt9211_probe -
len = 512
len = 512
file->ram = 1
src = 7be03ac0
p = 7ca0a298
end--
src = 7be03ac0
p = 7ca0a298
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7be03ac0
p = 7df00000
end--
src = 7be03ac0
p = 7df00000
1---end--
end--
----end--
test 857
test 863
test 866
test 892
test 894
test:541
test 896
test 932
test 937
bus_format: 100e
lt9211_chip_enable
lt9211_init_seq
[INFO ] hact = 1920
[INFO ] vact = 1080
[INFO ] fmt = 0x0a
-----ulRtn = 74247
[INFO ] Tx Pll Lock
-----ulRtn = 125000
Start initial panel
panel_simple_enable
  apll 816000 KHz
  dpll 462000 KHz
  gpll 1188000 KHz
  cpll 500000 KHz
  hpll 1400000 KHz
## Verified-boot: 0
     Type:         Kernel Image
     Architecture: ARM
     OS:           Linux
     Hash algo:    sha256
     Architecture: ARM
     Hash algo:    sha256
------Line: 430
testttt 568
------Line: 432
OK
len = 512
len = 512
file->ram = 1
src = 7c3f28c0
p = 7ca0df60
end--
src = 7c3f28c0
p = 7ca0df60
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7c3f28c0
p = 7e4ef000
end--
src = 7c3f28c0
p = 7e4ef000
1---end--
end--
----end--
Total: 3530.603 ms
[    0.002598] Console: colour dummy device 80x30
[    0.003069] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.004027] pid_max: default: 4096 minimum: 301
[    0.004631] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.005259] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.006654] CPU: Testing write buffer coherency: ok
[    0.007480] /cpus/cpu@f00 missing clock-frequency property
[    0.008005] /cpus/cpu@f01 missing clock-frequency property
[    0.008529] /cpus/cpu@f02 missing clock-frequency property
[    0.009052] /cpus/cpu@f03 missing clock-frequency property
[    0.009612] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.010879] Setting up static identity map for 0x100000 - 0x100060
[    0.011636] rcu: Hierarchical SRCU implementation.
[    0.012731] smp: Bringing up secondary CPUs ...
[    0.014755] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.016447] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.018095] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.018231] smp: Brought up 1 node, 4 CPUs
[    0.020242] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.020826] CPU: All CPU(s) started in SVC mode.
[    0.022272] devtmpfs: initialized
[    0.046418] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.047809] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.048724] futex hash table entries: 16 (order: -2, 1024 bytes)
[    0.049525] pinctrl core: initialized pinctrl subsystem
[    0.051273] NET: Registered protocol family 16
[    0.052373] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.055180] cpuidle: using governor menu
[    0.055582] Registered FIQ tty driver
[    0.056503] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.057248] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.059991] console [pstore-1] enabled
[    0.060585] pstore: Registered ramoops as persistent store backend
[    0.061170] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[    0.108869] cryptd: max_cpu_qlen set to 1000
[    0.110149] fiq debugger fiq mode enabled
[[    0.110942] console [ttyFIQ0] enabled
[    0.111623] bootconsole [uart8250] disabled
[    0.112334] Registered fiq debugger ttyFIQ0
[    0.112994] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    0.116559] vcc_sd: supplied by vcc3v3_sys
[    0.117053] reg-fixed-voltage vdd-arm: Fixed regulator specified with variable voltages
[    0.117108] reg-fixed-voltage: probe of vdd-arm failed with error -22
[    0.117219] reg-fixed-voltage vdd-logic-npu-vepu: Fixed regulator specified with variable voltages
[    0.117260] reg-fixed-voltage: probe of vdd-logic-npu-vepu failed with error -22
[    0.118368] rk_iommu ffb00f00.iommu: version = 1
[    0.119012] rk_iommu ffb20800.iommu: version = 1
[    0.119472] rk_iommu ffb60e00.iommu: version = 1
[    0.120113] rk_iommu ffb80480.iommu: version = 1
[    0.120667] rk_iommu ffb90800.iommu: version = 1
[    0.121151] rk_iommu ffbb0f00.iommu: version = 1
[    0.122213] SCSI subsystem initialized
[    0.122541] usbcore: registered new interface driver usbfs
[    0.122633] usbcore: registered new interface driver hub
[    0.122808] usbcore: registered new device driver usb
[    0.122928] media: Linux media interface: v0.10
[    0.122999] videodev: Linux video capture interface: v2.00
[    0.123069] pps_core: LinuxPPS API ver. 1 registered
[    0.123092] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.123134] PTP clock support registered
[    0.125120] Bluetooth: Core ver 2.22
[    0.125209] NET: Registered protocol family 31
[    0.125235] Bluetooth: HCI device and connection manager initialized
[    0.125264] Bluetooth: HCI socket layer initialized
[    0.125290] Bluetooth: L2CAP socket layer initialized
[    0.125347] Bluetooth: SCO socket layer initialized
[    0.125873] rockchip-cpuinfo cpuinfo: SoC            : 11260000
[    0.125910] rockchip-cpuinfo cpuinfo: Serial         : 04a143fbbeca61df
[    0.126894] clocksource: Switched to clocksource arch_sys_counter
[    0.140824] NET: Registered protocol family 2
[    0.141807] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.141870] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.142026] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.142228] TCP: Hash tables configured (established 8192 bind 8192)
[    0.142401] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.142476] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.142711] NET: Registered protocol family 1
[    0.144618] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.147427] Initialise system trusted keyrings
[    0.147689] workingset: timestamp_bits=29 max_order=19 bucket_order=0
[    0.155118] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.157942] Key type asymmetric registered
[    0.157975] Asymmetric key parser 'x509' registered
[    0.158050] bounce: pool size: 64 pages
[    0.158119] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.158146] io scheduler noop registered
[    0.158167] io scheduler deadline registered
[    0.158344] io scheduler cfq registered (default)
[    0.158372] io scheduler mq-deadline registered
[    0.158394] io scheduler kyber registered
[    0.158555] io scheduler bfq registered
[    0.162754] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
[    0.168650] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.168807] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.169206] mpp_service mpp-srv: 4a6b4c5b4 author: sun fan 2023-09-09 version 1.0
[    0.169229] mpp_service mpp-srv: probe start
[    0.170275] iommu: Adding device ffb80000.rkvdec to group 3
[    0.170332] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[    0.170532] mpp_rkvdec ffb80000.rkvdec: probing start
[    0.171165] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[    0.171200] rkvdec_init:1190: No niu aclk reset resource define
[    0.171229] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[    0.171245] rkvdec_init:1193: No niu hclk reset resource define
[    0.171574] mpp_rkvdec ffb80000.rkvdec: probing finish
[    0.172371] iommu: Adding device ffbb0000.rkvenc to group 5
[    0.172428] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[    0.172717] mpp_rkvenc ffbb0000.rkvenc: probing start
[    0.173424] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.7
[    0.173490] mpp_rkvenc ffbb0000.rkvenc: bin=0
[    0.173602] mpp_rkvenc ffbb0000.rkvenc: leakage=2.625
[    0.173692] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[    0.173736] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[    0.174298] mpp_rkvenc ffbb0000.rkvenc: avs=0
[    0.174702] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[    0.174738] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[    0.175340] mpp_rkvenc ffbb0000.rkvenc: probing finish
[    0.176052] iommu: Adding device ffb90400.vdpu to group 4
[    0.176113] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[    0.176234] mpp_vdpu2 ffb90400.vdpu: probe device
[    0.176786] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.176833] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177111] mpp_vdpu2 ffb90400.vdpu: probing finish
[    0.177757] iommu: Adding device ffb90000.vepu to group 4
[    0.177812] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[    0.177935] mpp_vepu2 ffb90000.vepu: probe device
[    0.178431] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178470] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178729] mpp_vepu2 ffb90000.vepu: probing finish
[    0.179274] iommu: Adding device ffb20000.iep to group 1
[    0.179328] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[    0.179458] mpp-iep2 ffb20000.iep: probe device
[    0.180131] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[    0.180415] mpp-iep2 ffb20000.iep: probing finish
[    0.180689] mpp_service mpp-srv: probe success
[    0.185848] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.185892] dma-pl330 ff4e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.187997] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.188881] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.189926] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 32, base_baud = 1500000) is a 16550A
[    0.190931] ff590000.serial: ttyS4 at MMIO 0xff590000 (irq = 33, base_baud = 1500000) is a 16550A
[    0.191701] ff5a0000.serial: ttyS5 at MMIO 0xff5a0000 (irq = 34, base_baud = 1500000) is a 16550A
[    0.193703] rockchip_drm_init----------------000--------------
[    0.193829] random: fast init done
[    0.194231] random: crng init done
[    0.194779] iommu: Adding device ffb00000.vop to group 0
[    0.194837] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[    0.194924] clk: failed to reparent dclk_vop to cpll: -22
[    0.198111] rockchip_drm_init----------------001--------------
[    0.198194] rockchip_drm_platform_probe----------------001--------------
[    0.198238] rockchip_drm_platform_probe----------------002--------------
[    0.199149] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[    0.200289] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[    0.201494] rockchip_drm_platform_probe----------------003--------------
[    0.201527] rockchip_drm_bind----------------011--------------
[    0.201730] rockchip-drm display-subsystem: devfreq is not set
[    0.202211] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.202242] dw_mipi_dsi_bind----------------00--------------
[    0.202247] dw_mipi_dsi_bind----------------01--------------
[    0.202271] dw_mipi_dsi_bind----------------02--------------
[    0.202309] drm_of_find_panel_or_bridge  panel is null
[    0.202349] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
[    0.202394] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb09439ac): -517
[    0.202654] rockchip-drm display-subsystem: master bind failed: -517
[    0.203007] rockchip_drm_init----------------002--------------
[    0.207878] panel_simple_dsi_probe dsi_id =-19
[    0.207925] panel_simple_dsi_probe node--name =dsi@ffb30000
[    0.207984] drm_display_mode_from_videomode------------------------------148
[    0.208011] panel_simple_dsi_probe----------------0002--------------
[    0.208075] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply power not found, using dummy regulator
[    0.208191] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[    0.208234] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[    0.208334] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[    0.209631] zram: Added device: zram0
[    0.211701] libphy: Fixed MDIO Bus: probed
[    0.213007] PPP generic driver version 2.4.2
[    0.213257] PPP BSD Compression module registered
[    0.213284] PPP Deflate Compression module registered
[    0.213323] PPP MPPE Compression module registered
[    0.213345] NET: Registered protocol family 24
[    0.213455] usbcore: registered new interface driver asix
[    0.213539] usbcore: registered new interface driver ax88179_178a
[    0.213647] usbcore: registered new interface driver cdc_ether
[    0.213722] usbcore: registered new interface driver net1080
[    0.213799] usbcore: registered new interface driver cdc_subset
[    0.213869] usbcore: registered new interface driver zaurus
[    0.213968] usbcore: registered new interface driver cdc_ncm
[    0.215650] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[    0.221261] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.221302] ehci-platform: EHCI generic platform driver
[    0.224905] ehci-platform ffe00000.usb: EHCI Host Controller
[    0.224970] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[    0.225182] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[    0.236945] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[    0.237240] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.237286] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.237311] usb usb1: Product: EHCI Host Controller
[    0.237335] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[    0.237358] usb usb1: SerialNumber: ffe00000.usb
[    0.238124] hub 1-0:1.0: USB hub found
[    0.238199] hub 1-0:1.0: 1 port detected
[    0.238940] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.238981] ohci-platform: OHCI generic platform driver
[    0.239560] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[    0.239624] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[    0.239807] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[    0.297987] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.298024] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.298044] usb usb2: Product: Generic Platform OHCI controller
[    0.298064] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[    0.298098] usb usb2: SerialNumber: ffe10000.usb
[    0.298864] hub 2-0:1.0: USB hub found
[    0.298936] hub 2-0:1.0: 1 port detected
[    0.300637] usbcore: registered new interface driver cdc_acm
[    0.300668] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.300818] usbcore: registered new interface driver usb-storage
[    0.300965] usbcore: registered new interface driver option
[    0.301025] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.302187] i2c /dev entries driver
[    0.305435] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.305710] rtc-pcf8563 0-0051: registered as rtc0
[    0.306933] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.306965] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[    0.311512] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[    0.312878] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[    0.312932] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[    0.313067] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[    0.313170] rkcif rkcif_dvp: attach to cif hw node
[    0.313192] rkcif rkcif_dvp: rkcif wait line 0
[    0.313238] RKCIF_WORKMODE_PINGPONG
[    0.314745] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[    0.314847] rkcif rkcif_mipi_lvds: attach to cif hw node
[    0.314878] rkcif rkcif_mipi_lvds: rkcif wait line 0
[    0.314915] RKCIF_WORKMODE_PINGPONG
[    0.315947] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[    0.315982] rockchip-mipi-csi2: Async registered subdev
[    0.318370] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[    0.318400] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[    0.318733] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[    0.318782] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[    0.319114] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[    0.319345] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    0.319611] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.319647] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.319680] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.322725] rkisp rkisp-vir1: rkisp driver version: v01.06.02
[    0.322977] rkisp rkisp-vir1: No memory-region-thunderboot specified
[    0.323208] rkisp rkisp-vir1: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.323250] rkisp rkisp-vir1: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.323280] rkisp rkisp-vir1: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.327135] iommu: Adding device ffb60000.rkispp to group 2
[    0.327200] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[    0.327618] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[    0.327668] rkispp_hw ffb60000.rkispp: can't request region for resource [mem 0xffb60000-0xffb7ffff]
[    0.327930] rkispp_hw ffb60000.rkispp: failed to get cru reset
[    0.328233] rkispp rkispp-vir0: rkispp driver version: v01.06.02
[    0.330648] rkispp rkispp-vir1: rkispp driver version: v01.06.02
[    0.333326] usbcore: registered new interface driver uvcvideo
[    0.333360] USB Video Class driver (1.1.1)
[    0.333881] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.3
[    0.333934] rockchip-iodomain fe020000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    0.334058] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[    0.334182] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    0.334324] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.5
[    0.334361] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc3v3_sys
[    0.334478] rockchip-iodomain fe020000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    0.334603] rockchip-iodomain fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vcc_1v8
[    0.334737] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(1800000 uV) supplied by vcc_1v8
[    0.334868] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[    0.337727] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -7
[    0.338176] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[    0.338671] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -7
[    0.338936] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[    0.340506] Bluetooth: HCI UART driver ver 2.3
[    0.340532] Bluetooth: HCI UART protocol H4 registered
[    0.340889] cpu cpu0: bin=0
[    0.340940] cpu cpu0: leakage=3.375
[    0.340996] cpu cpu0: Failed to get reg
[    0.341028] cpu cpu0: bin-scale=5
[    0.341357] cpuidle: enable-method property 'psci' found operations
[    0.341548] cpuidle: enable-method property 'psci' found operations
[    0.341709] cpuidle: enable-method property 'psci' found operations
[    0.341859] cpuidle: enable-method property 'psci' found operations
[    0.342600] Synopsys Designware Multimedia Card Interface Driver
[    0.343609] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[    0.343694] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[    0.343723] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[    0.343819] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    0.344037] mmc_host mmc0: card is non-removable.
[    0.357062] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.370889] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[    0.370996] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[    0.371025] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[    0.371132] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    0.371319] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.6
[    0.371520] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.3
[    0.409091] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[    0.409180] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[    0.410168] mmc0: new HS200 MMC card at address 0001
[    0.413504] mmcblk0: mmc0:0001 DA4064 58.2 GiB
[    0.414891] mmcblk0boot0: mmc0:0001 DA4064 partition 1 4.00 MiB
[    0.416107] mmcblk0boot1: mmc0:0001 DA4064 partition 2 4.00 MiB
[    0.416549] mmcblk0rpmb: mmc0:0001 DA4064 partition 3 16.0 MiB, chardev (242:0)
[    0.430522]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    0.489963] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.503632] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.503741] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.503775] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.503899] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.505240] usbcore: registered new interface driver usbhid
[    0.505278] usbhid: USB HID core driver
[    0.507901] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.3
[    0.509798] rksfc_base v1.1 2016-01-08
[    0.510529] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[    0.510634] rkflash_dev_init enter
[    0.510667] sfc nor id: 0 0 0
[    0.510688] rkflash[1] is invalid
[    0.510693] rkflash_dev_init enter
[    0.510729] sfc_nand id: 0 0 0
[    0.510748] rkflash[2] is invalid
[    0.511261] NET: Registered protocol family 17
[    0.511363] NET: Registered protocol family 15
[    0.512557] Bluetooth: RFCOMM TTY layer initialized
[    0.512621] Bluetooth: RFCOMM socket layer initialized
[    0.512681] Bluetooth: RFCOMM ver 1.11
[    0.512714] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    0.512763] Bluetooth: HIDP socket layer initialized
[    0.512792] [BT_RFKILL]: Enter rfkill_rk_init
[    0.512812] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    0.513280] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    0.513384] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = USB-WiFi
[    0.513410] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    0.513432] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    0.513489] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 16 flags = 0.
[    0.513619] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    0.513645] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    0.513708] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    0.516546] flash vendor_init_thread!
[    0.516580] flash vendor storage:20170308 ret = -1
[    0.517496] gc2145 1-003c: driver version: 00.01.06
[    0.517551] gc2145_probe---------------00000---------------
[    0.517586] gc2145_probe---------------11111---------------
[    0.517638] gc2145_probe---------------22222---------------
[    0.517666] gc2145_probe---------------222221---------------
[    0.517686] gc2145_probe---------------2222211---------------
[    0.517705] fps =25
[    0.517731] gc2145_probe---------------33333---------------
[    0.517766] m01_b_gc2145 1-003c: Async registered subdev
[    0.517811] rkcif rkcif_dvp: Entity type for entity rkcif-dvp-sof was not initialized!
[    0.518774] ----------i=5
[    0.518823] ----------i=5
[    0.518851] ----------i=5
[    0.518874] ----------i=5
[    0.518901] rkcif_dvp: Async subdev notifier completed
[    0.518930] gc2145_probe---------------44444---------------
[    0.518945] gc2145 1-003c: m01_b_gc2145 1-003c sensor driver registered !!
[    0.519381] sc2210 1-0030: driver version: 00.01.06
[    0.519441] sc2210 1-0030:  Get hdr mode failed! no hdr default
[    0.519742] sc2210 1-0030: could not get sleep pinstate
[    0.519875] sc2210 1-0030: Linked as a consumer to regulator.2
[    0.519997] sc2210 1-0030: Linked as a consumer to regulator.3
[    0.520102] sc2210 1-0030: Linked as a consumer to regulator.4
[    0.520158] sc2210_initialize_controls---------------11111---------------0
[    0.520169] sc2210_initialize_controls---------------11111---------------0 74250000
[    0.527261] sc2210 1-0030: gain_mode 0b02
[    0.527385] sc2210 1-0030: Detected SC2210 sensor
[    0.527506] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: match m00_f_sc2210 1-0030:bus type 4
[    0.527553] sc2210_probe---------------11111---------------hdr_mode0
[    0.527573] sc2210_runtime_suspend---------------11111---------------
[    0.528309] Registering SWP/SWPB emulation handler
[    0.531325] Loading compiled-in X.509 certificates
[    0.533731] rga2: Driver loaded successfully ver:3.2.56726
[    0.534131] rga2: Module initialized.
[    0.578994] rockchip_drm_platform_probe----------------001--------------
[    0.579015] rockchip_drm_platform_probe----------------002--------------
[    0.582709] rockchip_drm_platform_probe----------------003--------------
[    0.582826] rockchip_drm_bind----------------011--------------
[    0.583053] rockchip-drm display-subsystem: devfreq is not set
[    0.583772] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.583837] dw_mipi_dsi_bind----------------00--------------
[    0.583841] dw_mipi_dsi_bind----------------01--------------
[    0.583870] dw_mipi_dsi_bind----------------02--------------
[    0.583923] drm_of_find_panel_or_bridge  panel ret =0
[    0.583956] dw_mipi_dsi_bind----------------03--------------
[    0.583985] dw_mipi_dsi_bind----------------04--------------
[    0.584021] dw_mipi_dsi_bind----------------05--------------
[    0.584066] dw_mipi_dsi_bind----------------06--------------
[    0.584121] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb09439ac)
[    0.584163] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.584188] [drm] No driver support for vblank timestamp query.
[    0.584352] rockchip_drm_bind----------------010--------------
[    0.584359] show_loader_logo----------------011--------------
[    0.584639] setup_initial_state----------------encoder_funcs->loader_protect--------------
[    0.584698] dw_mipi_dsi_encoder_loader_protect----------------dw_mipi_dsi_encoder_loader_protect--------------bbf3ba39
[    0.584719] panel_simple_loader_protect: on = 1!
[    0.584767] panel_simple_loader_protect----------------panel_simple_loader_protect--------------bbf3ba39 1
[    0.584988] show_loader_logo----------------012--------------
[    0.624494] rockchip-drm display-subsystem: fb0:  frame buffer device
[    0.627462] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    0.627536] rockchip_drm_platform_probe----------------004--------------
[    0.628386] input: adc-keys as /devices/platform/adc-keys/input/input0
[    0.632037] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.632174] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.632204] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.632269] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.634988] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.635139] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.635181] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.635248] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.638838] rkcif rkcif_dvp: clear unready subdev num: 0
[    0.638940] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[    0.638970] rockchip-mipi-csi2: No link between dphy and sensor
[    0.640086] vendor storage:20190527 ret = 0
[    0.640092] rockchip-mipi-csi2: No link between dphy and sensor
[    0.640108] rkcif_mipi_lvds: Async subdev notifier completed
[    0.641032] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    0.646368] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    0.646608] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    0.646639] cfg80211: failed to load regulatory.db
[    0.648264] rkisp rkisp-vir0: clear unready subdev num: 1
[    0.649855] rockchip-mipi-csi2: No link between dphy and sensor
[    0.649911] rockchip-mipi-csi2: No link between dphy and sensor
[    0.649940] rkisp0: Invalid mipi data type
[    0.649965] rkisp0: update sensor failed
[    0.650006] rkisp rkisp-vir1: clear unready subdev num: 1
[    0.651861] rkisp1: Async subdev notifier completed
[    0.654858] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[    0.654913] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[    0.660812] EXT4-fs (mmcblk0p6): recovery complete
[    0.663096] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    0.663202] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    0.666984] devtmpfs: mounted
[    0.669494] Freeing unused kernel memory: 1024K
[    0.669894] Run /sbin/init as init process
[    0.763649] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
NAME=Buildroot
VERSION=2018.02-rc3
ID=buildroot
/usr/bin/modetest
Populating /dev using udev: [    1.318479] udevd[117]: starting version 3.2.7
[    1.332775] udevd[117]: specified group 'kvm' unknown
[    1.372999] udevd[119]: starting eudev-3.2.7
[    1.443650] phy phy-ff4c0000.usb2-phy.1: charger = USB_SDP_CHARGER
[    1.649026] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.649101] rkcif_dvp: rkcif_update_sensor_info: stream[1] get remote sensor_sd failed!
[    1.649120] stream_cif_dvp_id1: update sensor info failed -19
[    1.651456] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.651517] rkcif_dvp: rkcif_update_sensor_info: stream[2] get remote sensor_sd failed!
[    1.651535] stream_cif_dvp_id2: update sensor info failed -19
[    1.658110] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.658178] rkcif_dvp: rkcif_update_sensor_info: stream[3] get remote sensor_sd failed!
[    1.658196] stream_cif_dvp_id3: update sensor info failed -19
[    1.664186] gc2145 1-003c: gc2145_power(2721) on(1)
[    1.665280] rockchip-mipi-csi2: No link between dphy and sensor
[    1.665565] gc2145 1-003c: gc2145_power(2721) on(0)
[    1.672047] rockchip-mipi-csi2: No link between dphy and sensor
[    1.715941] rockchip-mipi-csi2: No link between dphy and sensor
[    1.716486] rockchip-mipi-csi2: No link between dphy and sensor
[    1.791955] rockchip-mipi-csi2: No link between dphy and sensor
[    1.886317] sc2210_runtime_suspend---------------11111---------------
[    1.886496] sc2210 cmd =80685600
[    1.905016] sc2210_runtime_suspend---------------11111---------------
[    1.918328] sc2210_runtime_suspend---------------11111---------------
[    1.981297] sc2210_runtime_suspend---------------11111---------------
[    1.989913] sc2210_runtime_suspend---------------11111---------------
done
[    2.001379] sc2210_runtime_suspend---------------11111---------------
[    2.741362] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[    2.801894] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[    3.542173] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
userdata: 27/163840 files (0.0% non-contiguous), 149411/1048576 blocks
Mounting /dev/mmcblk0p8(ext2) on /userdata
[    5.338775] EXT4-fs (mmcblk0p8): mounting ext2 file system using the ext4 subsystem
[    5.347361] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
Handling demo: /dev/mmcblk0p10 /demo ext4 defaults 0
Mounting /dev/mmcblk0p10(ext4) on /demo
[    6.198222] EXT4-fs (mmcblk0p10): recovery complete
[    6.201036] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
Log saved to /tmp/mountall.log
Starting system message bus: done
/etc/init.d/S36load_rv1109_wifi_modules: line 45: can't create /sys/class/rfkill/rfkill1/state: nonexistent directory
load wifi modules: [    6.490880] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[    6.490936] ======== dhd_wlan_init_plat_data ========
[    6.490955] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    6.490971] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: wifi OOB pin isn't defined.
[    6.490987] dhd_wlan_init_gpio: unknown oob irqflags !
[    6.491004] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=-1, oob_irq_flags=0x410
[    6.491019] dhd_wlan_init_gpio: WL_REG_ON=-1
[    6.491033] dhd_wifi_platform_load: Enter
[    6.491086] Power-up adapter 'DHD generic adapter'
[    6.491186] wifi_platform_set_power = 1
[    6.491214] ======== PULL WL_REG_ON(-1) HIGH! ========
[    6.491231] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    6.491248] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    6.597139] [WLAN_RFKILL]: wifi turn on power [GPIO16-1]
[    6.903805] wifi_platform_bus_enumerate device present 1
[    6.903851] ======== Card detection to detect SDIO card! ========
[    6.903868] sdio: host isn't  initialization successfully.
[    9.017150] failed to power up DHD generic adapter, 1 retry left
[    9.033511] wifi_platform_set_power = 0
[    9.033608] ======== PULL WL_REG_ON(-1) LOW! ========
[    9.033628] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    9.033645] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    9.033662] wifi power off
[    9.140465] [WLAN_RFKILL]: wifi shut off power [GPIO16-0]
[    9.140515] wifi_platform_bus_enumerate device present 0
[    9.140530] ======== Card detection to remove SDIO card! ========
[    9.140544] sdio: host isn't  initialization successfully.
[    9.140687] wifi_platform_set_power = 1
[    9.140710] ======== PULL WL_REG_ON(-1) HIGH! ========
[    9.140733] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    9.140756] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    9.247130] [WLAN_RFKILL]: wifi turn on power [GPIO16-1]
[    9.553799] wifi_platform_bus_enumerate device present 1
[    9.553846] ======== Card detection to detect SDIO card! ========
[    9.553862] sdio: host isn't  initialization successfully.
[   11.577136] failed to power up DHD generic adapter, 0 retry left
[   11.593493] wifi_platform_set_power = 0
[   11.593610] ======== PULL WL_REG_ON(-1) LOW! ========
[   11.593671] [WLAN_RFKILL]: rockchip_wifi_power: 0
[   11.593688] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[   11.593711] wifi power off
[   11.700476] [WLAN_RFKILL]: wifi shut off power [GPIO16-0]
[   11.700532] wifi_platform_bus_enumerate device present 0
[   11.700548] ======== Card detection to remove SDIO card! ========
[   11.7005OK
63] sdio: host isn't  initialization successfully.
[   11.700577] failed to power up DHD generic adapter, max retry reached**
[   11.700592] unregister wifi platform drivers
[   11.700607] wifi_platform_bus_enumerate device present 0
[   11.700620] ======== Card detection to remove SDIO card! ========
[   11.700641] sdio: host isn't  initialization successfully.
[   11.700655] ======== dhd_wlan_deinit_plat_data ========
[   11.700677] dhd_module_init: Failed to load the driver, try cnt 0
[   11.700768] dhd_module_init: Failed to load driver max retry reached**
[   11.700789] dhd_module_init: Exit err=-19
Starting network: OK
Starting connman ... done.
alsactl: load_state:1735: No soundcards found...
Starting ntpd: OK
Starting QDesktop...
gpiochip0: GPIOs 0-31, parent: platform/pinctrl, gpio0:
 gpio-4   (                    |vcc_sd              ) out lo
 gpio-16  (                    |rkwifi_wlan_poweren ) out lo
gpiochip1: GPIOs 32-63, parent: platform/pinctrl, gpio1:
gpiochip2: GPIOs 64-95, parent: platform/pinctrl, gpio2:
 gpio-64  (                    |pwdn                ) out lo
 gpio-65  (                    |reset               ) out hi
gpiochip3: GPIOs 96-127, parent: platform/pinctrl, gpio3:
gpiochip4: GPIOs 128-129, parent: platform/pinctrl, gpio4:
Starting dropbear sshd: OK
Starting fcgiwrap daemon: OK
Starting nginx...
Debug: configfs_init
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0': No such file or directory
[   12.403123] file system registered
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
[   12.445839] using random self ethernet address
[   12.445898] using random host ethernet address
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mass_storage.0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/hid.usb0': No such file or directory
[   12.623782] read descriptors
[   12.623934] read strings
media get entity by name: stream_cif_mipi_id0 is null
media get entity by name: stream_cif_mipi_id1 is null
media get entity by name: stream_cif_mipi_id2 is null
media get entity by name: stream_cif_mipi_id3 is null
media get entity by name: rockchip-mipi-csi2 is null
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rockchip-mipi-dphy-rx is null
media get entity by name: stream_cif is null
[   13.019540] gc2145_enum_frame_interval---------------00000---------------0, 0
[   13.019549] file->index = 0, cfg_num =1
[   13.019621] gc2145_enum_frame_interval---------------111111---------------0, 0
[   13.019663media get entity by name: stream_cif]_dvp_id0 is null
media get enti ty by name: stream_cif_dvp_id1 gis null
media get entity by cname: stream_cif_dvp_id2 is nu2ll
media get entity by name: stream_cif_dvp_id3 is null
media get entity by name: rkcif-1lvds-subdev is null
media ge4t entity by name: rkcif-lite-5lvds-subdev is null
media get entity by name: rockchi_enum_frap-mipi-dphy-rx is null
media getm entity by name: stream_cif ies null
media get entity by na_me: rkcif-dvp-sof is null
interval---------------00000---------------1, 8198
[   13.019680] file->index = 1, cfg_num =1
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rkcif_dvp is null
media get entity by name: rkcif_lite_mipi_lvds is null
media get entity by name: rkcif_mipi_lvds is null
[   13.031835] sc2210 cmd =8eb656c0
[08:00:13.031942][CAMHW]:XCAM ERROR CamHwIsp20.cpp:973: get isp or ispp info fail, something gos wrong!
register factory : rkmpp
register factory : live555_rtsp_server
register factory : video_enc
register factory : audio_enc
register factory : video_dec
register factory : file_read_flow
register factory : file_write_flow
register factory : filter
register factory : link_flow
register factory : source_stream
register factory : muxer_flow
register factory : audio_dec
register factory : output_stream
register factory : move_detec
register factory : occlusion_detec
register factory : file_write_stream
register factory : file_read_stream
register factory : alsa_playback_stream
register factory : alsa_capture_stream
register factory : v4l2_capture_stream
register factory : v4l2_output_stream
register factory : drm_output_stream
rga_api version 1.3.0_[11] (RGA is compiling with meson base: $PRODUCT_BASE)
register factory : rkrga
register factory : through_guard
register factory : ANR
register factory : AEC
register factory : rockx_filter
register factory : nn_result_input
register factory : draw_filter
register factory : rknn
register factory : face_capture
register factory : rockface_detect
register factory : rockface_evaluate
register factory : rockface_bodydetect
register factory : rockface_recognize
insmod NPU modules: QObject::startTimer: Timers can only be used with threads started with QThread
[   13.685865] galcore: loading out-of-tree module taints kernel.
[   13.701790] galcore: npu init.
[   13.703061] galcore: start npu probe.
[   13.703326] galcore ffbc0000.npu: Linked as a consumer to regulator.7
[   13.703676] npu: platform_get_irq irq = 67
[   13.703708] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[   13.703728] Galcore version 6.4.6.5.351518
[   13.703749] Galcore options:
[   13.703764]   irqLine           = 67
[   13.703783]   registerMemBase   = 0xFFBC0000
[   13.703804]   registerMemSize   = 0x00004000
[   13.703819]   contiguousSize    = 0x00400000
[   13.703835]   contiguousBase    = 0x0
[   13.703848]   externalSize      = 0x00000000
[   13.703861]   externalBase      = 0x0
[   13.703884]   exclusiveSize     = 0x00000000
[   13.703908]   exclusiveBase     = 0x0
[   13.703932]   bankSize          = 0x00000000
[   13.703960]   fastClear         = -1
[   13.703983]   compression       = 15
[   13.703998]   powerManagement   = 1
[   13.704011]   baseAddress       = 0x00000000
[   13.704025]   physSize          = 0x00000000
[   13.704045]   recovery          = 1
[   13.704058]   stuckDump         = 0
[   13.704078]   GPU smallBatch    = 1
[   13.704095]   allMapInOne       = 1
[   13.704109]   enableNN          = 0xff
[   13.704122]   userClusterMasks  =
[   13.704126] ff,
[   13.704139] ff,
[   13.704151] ff,
[   13.704166] ff,
[   13.704178] ff,
[   13.704190] ff,
[   13.704203] ff,
[   13.704215] ff,
[   13.704227]
[   13.704247]   irqs              =
[   13.704249] 67,
[   13.704262] -1,
[   13.704274] -1,
[   13.704286] -1,
[   13.704298] -1,
[   13.704310] -1,
[   13.704323] -1,
[   13.704338] -1,
[   13.704349] -1,
[   13.704361] -1,
[   13.704374] -1,
[   13.704386]
[   13.704406]   registerBases     =
[   13.704409] 0xFFBC0000,
[   13.704422] 0x00000000,
[   13.704437] 0x00000000,
[   13.704450] 0x00000000,
[   13.704462] 0x00000000,
[   13.704475] 0x00000000,
[   13.704487] 0x00000000,
[   13.704501] 0x00000000,
[   13.704513] 0x00000000,
[   13.704525] 0x00000000,
[   13.704557] 0x00000000,
[   13.704584]
[   13.704618]   registerSizes     =
[   13.704626] 0x00004000,
[   13.704653] 0x00000000,
[   13.704679] 0x00000000,
[   13.704704] 0x00000000,
[   13.704735] 0x00000000,
[   13.704759] 0x00000000,
[   13.704779] 0x00000000,
[   13.704797] 0x00000000,
[   13.704818] 0x00000000,
[   13.704835] 0x00000000,
[   13.704853] 0x00000000,
[   13.704872]
[   13.704899]   chipIDs           =
[   13.704902] 0xFFFFFFFF,
[   13.704920] 0xFFFFFFFF,
[   13.704939] 0xFFFFFFFF,
[   13.704952] 0xFFFFFFFF,
[   13.704974] 0xFFFFFFFF,
[   13.704996] 0xFFFFFFFF,
[   13.705014] 0xFFFFFFFF,
[   13.705033] 0xFFFFFFFF,
[   13.705049] 0xFFFFFFFF,
[   13.705067] 0xFFFFFFFF,
[   13.705084] 0xFFFFFFFF,
[   13.705101]
[   13.705130]   core 0 internal sRAMBases =
[   13.705134] 0xFFFFFFFFFFFFFFFF,
[   13.705152] 0xFFFFFFFFFFFFFFFF,
[   13.705168]
[   13.705189]   core 1 internal sRAMBases =
[   13.705192] 0xFFFFFFFFFFFFFFFF,
[   13.705210] 0xFFFFFFFFFFFFFFFF,
[   13.705227]
[   13.705255]   core 2 internal sRAMBases =
[   13.705258] 0xFFFFFFFFFFFFFFFF,
[   13.705276] 0xFFFFFFFFFFFFFFFF,
[   13.705292]
[   13.705318]   core 3 internal sRAMBases =
[   13.705322] 0xFFFFFFFFFFFFFFFF,
[   13.705339] 0xFFFFFFFFFFFFFFFF,
[   13.705356]
[   13.705382]   core 4 internal sRAMBases =
[   13.705385] 0xFFFFFFFFFFFFFFFF,
[   13.705403] 0xFFFFFFFFFFFFFFFF,
[   13.705415]
[   13.705435]   core 5 internal sRAMBases =
[   13.705439] 0xFFFFFFFFFFFFFFFF,
[   13.705452] 0xFFFFFFFFFFFFFFFF,
[   13.705464]
[   13.705484]   core 6 internal sRAMBases =
[   13.705487] 0xFFFFFFFFFFFFFFFF,
[   13.705500] 0xFFFFFFFFFFFFFFFF,
[   13.705512] OK
[   13.705532]   core 7 internal sRAMBases =
[   13.705535] 0xFFFFFFFFFFFFFFFF,
[   13.705549] 0xFFFFFFFFFFFFFFFF,
[   13.705561]
[   13.705582]   core 8 internal sRAMBases =
[   13.705585] 0xFFFFFFFFFFFFFFFF,
[   13.705603] 0xFFFFFFFFFFFFFFFF,
[   13.705626]
[   13.705653]   core 9 internal sRAMBases =
[   13.705656] 0xFFFFFFFFFFFFFFFF,
[   13.705674] 0xFFFFFFFFFFFFFFFQStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmpF,/runtime-root'
[   13.705695]
[   13.705721]   core 10 internal sRAMBases =
[   13.705724] 0xFFFFFFFFFFFFFFFF,
[   13.705742] 0xFFFFFFFFFFFFFFFF,
[   13.705760]
[   13.705786]   External sRAMBases =
[   13.705790] 0xffffffffffffffff,
[   13.705808] 0xffffffffffffffff,
[   13.705820]
[   13.705852]   mmuPageTablePool  = 1
[   13.705874]   mmuDynamicMap     = 1
[   13.705891]   isrPoll           = 0x00000000
[   13.705908] Build options:
[   13.705926]   gcdGPU_TIMEOUT    = 20000
[   13.705945]   gcdGPU_2D_TIMEOUT = 4000
[   13.705962]   gcdINTERRUPT_STATISTIC = 1
[   13.713099] Galcore Info: ContiguousBase=0x7f855000 ContiguousStarting vsftpd: Size=0x400000
[   13.719015] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual address=0x400000 size=0x40000
[   13.719176] Galcore Info: MMU mapped core 0 SRAM[1] hardware virtual address=0x440000 size=0x40000
[   13.722784] galcore ffbc0000.npu: Init npu devfreq
[   13.722853] galcore ffbc0000.npu: bin=0
[   13.722912] galcore ffbc0000.npu: leakage=2.125
[   13.723308] galcore ffbc0000.npu: Failed to set pvtm_volt
[   13.723464] galcore ffbc0000.npu: Failed to get pvtm
[   13.723519] galcore ffbc0000.npu: bin-scale=23
[   13.724591] galcore ffbc0000.npu: avs=0
[   13.725301] galcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[   13.725367] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[   13.725514] galcore ffbc0000.npu: failed to find power_model node
[   13.725538] galcore ffbc0000.npu: failed to initialize power model
[   13.729377] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[   13.729492] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[   13.729535] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[   13.729604] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[   13.756642] Freeing drm_logo memory: 12148K
OK
Starting dnsmasq: [   13.770311] dwc3 ffd00000.dwc3: device reset
dnsmasq: failed to create listening socket for port 53: Address already in use
FAIL
LOG_INFO :*** update_engine: Version V1.1.4 ***.
LOG_INFO :Current Mode is recovery.
[   13.842745] dwc3 ffd00000.dwc3: device reset
[   13.842939] android_work: did not send uevent (0 0   (null))
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf...
input-event-daemon: Adding device: /dev/input/event0...
input-event-daemon: open(/dev/input/event1): No such file or directory
input-event-daemon: open(/dev/input/event2): No such file or directory
input-event-daemon: Start listening on 1 devices...
done
[root@ATK-DLRV1126:/]# test stdout
[   13.903871] android_work: sent uevent USB_STATE=CONNECTED
[   14.034510] dwc3 ffd00000.dwc3: device reset
[   14.034710] android_work: sent uevent USB_STATE=DISCONNECTED
[   14.108073] dwc3 ffd00000.dwc3: device reset
[   14.108189] android_work: did not send uevent (0 0   (null))
[   14.167193] android_work: sent uevent USB_STATE=CONNECTED
[   14.171247] configfs-gadget gadget: full-speed config #1: b
[   14.171578] android_work: sent uevent USB_STATE=CONFIGURED
start rknn server, version:1.7.0 (7880361 build: 2021-08-16 14:05:08)
I NPUTransfer: Starting NPU Transfer Server, Transfer version 2.1.0 (b5861e7@2020-11-23T11:51:07)
fontfamilies: ("Montserrat")
[   15.902407] of_dma_request_slave_channel: dma-names property of node '/serial@ff590000' missing or empty
[   15.902464] ttyS4 - failed to request DMA, use interrupt mode
[   15.902706] ttyS4 set divisor fail, quot:156 != dll,dlh:0
[   15.902921] ttyS4 set divisor fail, quot:13 != dll,dlh:0
[   15.903273] of_dma_request_slave_channel: dma-names property of node '/serial@ff5a0000' missing or empty
[   15.903306] ttyS5 - failed to request DMA, use interrupt mode
[   15.903467] ttyS5 set divisor fail, quot:156 != dll,dlh:0
[   15.903541] ttyS5 set divisor fail, quot:13 != dll,dlh:0
WARNING: Cannot find style "greywhite" - fallback: "default"
Please check the path in QCoreApplication::applicationDirPath:  "/demo"
[   18.698185] gc2145_enum_frame_interval---------------00000---------------0, 0
[   18.698195] file->index = 0, cfg_num =1
[   18.698270] gc2145_enum_frame_interval---------------111111---------------0, 0
[   18.698298] gc2145_enum_frame_interval---------------00000---------------1, 8198
[   18.698317] file->index = 1, cfg_num =1
[   18.702815] sc2210 cmd =8eb656c0
[   18.803971] gc2145 1-003c: gc2145_power(2721) on(1)
[   18.804129] ----------i=5
[   18.811863] rkcif_dvp: stream[0] start streaming
[   18.811928] ----------i=5
[   18.812871] rkcif_dvp: Allocate dummy buffer, size: 0x00065400
[   18.812957] -----multi_id = 16
[   18.812981] BT1120_CLOCK_SINGLE_EDGES
[   18.813008] rkcif_dvp: set dual edge mode(off,0x1000000)!!!
[   18.813025] RKCIF_CLK_RISING
[   18.813046] V4L2_STD_PAL
[   18.813067] V4L2_MBUS_BT656
[   18.813082] BT1120_TRANSMIT_INTERFACE
[   18.813160] -------val=10010009
[   18.813189] -------val=10010009
[   18.813209] val = 720
[   18.813232] pingpong enter:2924
[   18.813320] pingpong exit:2928
[   18.813385] gc2145 1-003c: gc2145_s_stream: on: 1, 720x576@25
[   18.813412] gc2145->streaming =0 on=1
[   19.799885] sc2210 cmd =401056c5
[   19.799954] sc2210 1-0030: set fmt: cur_mode: 1920x1080, hdr: 0
[   19.799994] sc2210 1-0030: sensor mode: 0
[   19.800571] sc2210 cmd =801056c9
[   19.829384] sc2210 cmd =801056c9
[   19.829464] sc2210 cmd =400456c6
[   19.829492] sc2210 cmd =401056c8
[   19.847334] sc2210 cmd =801056c4
[   19.955557] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: stream on:1
[   19.955643] rockchip-mipi-dphy-rx: data_rate_mbps 222
[   20.095507] sc2210 1-0030: set exposure 0x60
[   20.095566] sc2210 1-0030: recv:48 set again 0x3, again_fine 0x30, set dgain 0x0, dgain_fine 0x80
[   20.259145] rkisp1: tx stream:4 lose frame:3, isp state:0x204 frame:0
[   20.292495] rkisp1: tx stream:4 lose frame:4, isp state:0x204 frame:2
[   20.335452] sc2210 cmd =801056c9
[   20.335540] sc2210 cmd =400456c6
[   20.335568] sc2210 cmd =401056c8
qml: onGlobal_Page_final_process_btnChanged0
ButtonProcessSlot_map "fn_info_boardcast_enable" "0" -------------
[server.c][fn_info_boardcast_enable]:fn_info_boardcast_enable==========
QThread::wait: Thread tried to wait on itself
[   20.368709] sc2210 cmd =801056c9
[   20.368793] sc2210 cmd =400456c6
[   20.368825] sc2210 cmd =401056c8
[   20.402249] sc2210 cmd =801056c9
[   20.402335] sc2210 cmd =400456c6
[   20.402361] sc2210 cmd =401056c8
[   20.435425] sc2210 cmd =801056c9
[   20.435496] sc2210 cmd =400456c6
[   20.435518] sc2210 cmd =401056c8
[   20.469341] sc2210 cmd =801056c9
[   20.469427] sc2210 cmd =400456c6
[   20.469448] sc2210 cmd =401056c8
qml: global_appIndex : 1
qml: normalStartApp  --------1---------ATKCamera
[   20.502039] sc2210 cmd =801056c9
[   20.502121] sc2210 cmd =400456c6
[   20.502149] sc2210 cmd =401056c8
[   20.535305] sc2210 cmd =801056c9
[   20.535387] sc2210 cmd =400456c6
[   20.535430] sc2210 cmd =401056c8
[   20.568719] sc2210 cmd =801056c9
[   20.568791] sc2210 cmd =400456c6
[   20.568820] sc2210 cmd =401056c8
qml: 当前item是0
[   20.602116] sc2210 cmd =801056c9
[   20.602191] sc2210 cmd =400456c6
[   20.602221] sc2210 cmd =401056c8
[   20.635357] sc2210 cmd =801056c9
[   20.635463] sc2210 cmd =400456c6
[   20.635489] sc2210 cmd =401056c8
[   20.668604] sc2210 cmd =801056c9
[   20.668677] sc2210 cmd =400456c6
[   20.668774] sc2210 cmd =401056c8
[   20.701946] sc2210 cmd =801056c9
[   20.702019] sc2210 cmd =400456c6
[   20.702058] sc2210 cmd =401056c8
[   20.735290] sc2210 cmd =801056c9
[   20.735367] sc2210 cmd =400456c6
[   20.735394] sc2210 cmd =401056c8
[   20.769109] sc2210 cmd =801056c9
[   20.769235] sc2210 cmd =400456c6
[   20.769267] sc2210 cmd =401056c8
[   20.801977] sc2210 cmd =801056c9
[   20.802048] sc2210 cmd =400456c6
[   20.802096] sc2210 cmd =401056c8
[   20.835477] sc2210 cmd =801056c9
[   20.835554] sc2210 cmd =400456c6
[   20.835612] sc2210 cmd =401056c8
[   20.868634] sc2210 cmd =801056c9
[   20.868715] sc2210 cmd =400456c6
[   20.868745] sc2210 cmd =401056c8
[   20.902088] sc2210 cmd =801056c9
[   20.902160] sc2210 cmd =400456c6
[   20.902189] sc2210 cmd =401056c8
[   20.935522] sc2210 cmd =801056c9
[   20.935596] sc2210 cmd =400456c6
[   20.935623] sc2210 cmd =401056c8
[   20.968642] sc2210 cmd =801056c9
[   20.968731] sc2210 cmd =400456c6
[   20.968758] sc2210 cmd =401056c8
[   21.002118] sc2210 cmd =801056c9
[   21.002191] sc2210 cmd =400456c6
[   21.002213] sc2210 cmd =401056c8
qml: onGlobal_Page_final_process_btnChangednone
ButtonProcessSlot_map "fn_config_para_main2storage" "none" -------------
[server.c][fn_config_para_main2storage]:fn_config_para_main2storage==========////////////////
[rkipc_server][__rec_configPara_handler]:-----------__rec_configPara_handler------1----100-
[   32.057062] vcc_sd: disabling
[ 3214.835336] sc2210 cmd =801056c9
[ 3214.835404] sc2210 cmd =400456c6
[ 3214.835431] sc2210 cmd =401056c8
[ 3214.868941] sc2210 cmd =801056c9
[ 3214.869024] sc2210 cmd =400456c6
[ 3214.869062] sc2210 cmd =401056c8
[ 3214.902230] sc2210 cmd =801056c9
[ 3214.902345] sc2210 cmd =400456c6
[ 3214.902376] sc2210 cmd =401056c8
[ 3214.935446] sc2210 cmd =801056c9
[ 3214.935538] sc2210 cmd =400456c6
[ 3214.935562] sc2210 cmd =401056c8
[ 3217.002065] sc2210 cmd =801056c9
[ 3217.002140] sc2210 cmd =400456c6
[ 3217.002160] sc2210 cmd =401056c8
[ 3217.035372] sc2210 cmd =801056c9
[ 3217.035446] sc2210 cmd =400456c6
[ 3217.035474] sc2210 cmd =401056c8
[ 3217.068906] sc2210 cmd =801056c9
[ 3217.069130] sc2210 cmd =400456c6
[ 3217.069166] sc2210 cmd =401056c8
[ 3217.102082] sc2210 cmd =801056c9
[ 3217.102187] sc2210 cmd =400456c6
[ 3217.102316] sc2210 cmd =401056c8
[ 3217.135303] sc2210 cmd =801056c9
[ 3217.135419] sc2210 cmd =400456c6
[ 3217.135493] sc2210 cmd =401056c8
[ 3217.169071] sc2210 cmd =801056c9
[ 3217.169148] sc2210 cmd =400456c6
[ 3217.169179] sc2210 cmd =401056c8
[ 3217.201964] sc2210 cmd =801056c9
[ 3217.202071] sc2210 cmd =400456c6
[ 3217.202106] sc2210 cmd =401056c8
[ 3217.235570] sc2210 cmd =801056c9
[ 3217.235668] sc2210 cmd =400456c6
[ 3217.235728] sc2210 cmd =401056c8
[root@ATK-DLRV1126:/]# ls /dev/fb0
.auto_mkfs      etc/            media/          root/           tmp/
.gitkeep        home/           misc            run/            udisk/
bin/            init            mnt/            sbin/           userdata/
busybox.config  lib/            oem/            sdcard/         usr/
data/           lib32/          opt/            sys/            var/
demo/           linuxrc         proc/           system/         vendor/
dev/            lost+found/     rockchip_test/  timestamp
[root@ATK-DLRV1126:/]# ls /dev/fb0 -ll
crw-rw---- 1 root video 29, 0 Jan  1 08:00 /dev/fb0
[root@ATK-DLRV1126:/]# ls /dev/fb0qml: buttonInfocancel2
DDR Version V1.08 20210825
DDR4, 328MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc6ee75eec1-210728 #zzz (Sep 13 2021 - 10:36:14)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC error: The cmd index is 1, ret is -110
mmc_init: -95, time 9
Trying to boot from MMC1
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
## Verified-boot: 0
## Checking optee 0x08400000 (gzip @0x08600000) ... sha256(7beb6b43df...) + sha256(bae962097a...) + OK
## Checking uboot 0x00600000 (gzip @0x00800000) ... sha256(a79b29d8d6...) + sha256(b07be23f78...) + OK
## Checking fdt 0x006bd070 ... sha256(a362d022de...) + OK
Jumping to U-Boot(0x00600000) via OP-TEE(0x08400000)
Total: 130.33 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
I/TC: Next entry point address: 0x00600000
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #zhangzj (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug  4 03:30:34 UTC 2021 arm
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
U-Boot 2017.09 (May 07 2024 - 03:53:30 -0700)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM:  2 GiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 7bbf9e50 - 7bbfede0
CR: M/C/I
device_node_name:adc-keys
device_node_name:dwmmc
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
fdt_addr_r = 8300000
resource_is_empty fun:resource_is_empty line:456
test--------------------
test-33333--------------line:479
test-33333--------------line:502
test-33333--------------line:516
---------------size =12631552, offset =6317568, dev_desc->blksz = 512
data =7bdd58c0
test444444---------------276
test444444---------------279
test444444---------------281
test444444---part->start =8000--blk_off =3036----blk_num =24671------282
__fit_image_load_one 283   7bdd58c0
52 53 43 45 00 00 00 00 01 01 01 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
test444444---------------339
test-33333--------------line:522
test-33333--------------line:529
FIT: no signed, no conf required
func:resource_traverse_init_list line:717
DTB: --------1-------<NULL>
[HW-ADC]: rv1126-xygd-1080p#_saradc_ch4=0.dtb
lcd adc_record[4] = 0,adc_record[4]= 0
adc_val =0.dtb
dtb_adc = 0
   - dev=saradc, channel=4, dtb_adc=0, read=0, found=1
cell_name =<NULL>
DTB: --------2-------rv1126-xygd-1080p#_saradc_ch4=0.dtb
len = 0
len = 92766
file->ram = 1
file->rsce_base = 7bdd58c0
file->f_size = 92766
file->name =rv1126-xygd-1080p#_saradc_ch4=0.dtb
file->f_offset = 187, offset = 0, dev_desc->blksz = 512
src = 7bdecec0
d0 0d fe ed 00 01 6a 5e 00 00 00 38 00 01 34 c8 00 00 00 28
p = 08300000
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
end--
src = 7bdecec0
p = 08300000
1---end--
end--
----end--
DTB: rv1126-xygd-1080p#_saradc_ch4=0.dtb
device_node_name:crypto
HASH(c): OK
device_node_name:saradc
device_node_name:ethernet
device_node_name:gpio1
device_node_name:gpio3
device_node_name:i2c
device_node_name:decompress
device_node_name:nandc
device_node_name:usb0
device_node_name:usb2-phy
device_node_name:serial
device_node_name:sfc
device_node_name:dwc3
device_node_name:phy
device_node_name:volumeup-key
device_node_name:menu-key
device_node_name:amba
device_node_name:clock-controller
io-domain: OK
rockchip_display_probe node.np->name = route-dsi
rockchip_display_probe: panel_i2c_busnum = 3
lt9211_is_connected  lt9211 connect = 0
find connect node's handle 16
find ep_node /vop@ffb00000/port/endpoint@1
find port_node /vop@ffb00000/port
find port_parent_node /vop@ffb00000
load_mipi2lvds_driver: lt9211@2d
I2c3 speed: 400000Hz
lt9211_parse_dt mipi-format=2 mipi-bpp=24 test-pattern=false
lt9211_ConvertBoard_power_off
lt9211_ConvertBoard_power_on
lt9211_chip_shutdown
lt9211_chip_enable
id: 0x21 0x03 0xe0
lt9211_detect successful
lt9211_probe : lt9211 is connected!
lt9211_probe -
load_mipi2lvds_driver: lt9211@2d : ret=0
lt9211_is_connected  lt9211 connect = 1
panel_simple_dsi_of_get_desc_data t1=1 t2=500 t3=200 t4=1 t5=1000
test:-------------------------------2362
test:2364 dsi@ffb30000.0
Can't get crtc id, default set to id = 0
Could not find baseparameter partition
Model: Rockchip RV1126 38x38 V10 EMMC DDR3 Board
len = 512
len = 512
file->ram = 1
file->f_size = 6220854
file->f_offset = 369, offset = 0, dev_desc->blksz = 512
src = 7be03ac0
42 4d 36 ec 5e 00 cf 20 00 00 36 00 00 00 28 00 00 00 80 07
p = 7ca0a298
end--
src = 7be03ac0
p = 7ca0a298
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7be03ac0
p = 7df00000
end--
src = 7be03ac0
p = 7df00000
1---end--
end--
----end--
Rockchip UBOOT DRM driver version: v1.0.1
test 857
test 863
test 866
test 892
test 894
test:541
timing = display-timings
lt9211_set_videomode - clk: 148500000 hact: 1920 hfp: 88 hs: 44 hbp: 148 vact: 1080  vfp: 4 vs: 5 vbp: 36
display_get_timing_from_dts hactive = 1920 vactive = 1080 pixelclock = 148500 flags =0xa
Using display timing dts
test 896
test 932
test 937
dsi@ffb30000:  detailed mode clock 148500 kHz, flags[a]
    H: 1920 2008 2052 2200
    V: 1080 1084 1089 1125
bus_format: 100e
final DSI-Link bandwidth: 990 Mbps x 4
in panel_simple_prepare 1
in panel_simple_prepare 2
lt9211_bridge_enable
lt9211_chip_enable
lt9211_init_seq
[INFO ] MIPI Input PortA
[INFO ] Mipi DSI Input
[INFO ] hact = 1920
[INFO ] vact = 1080
[INFO ] fmt = 0x0a
[INFO ] pa_lpn = 0x00
[INFO ] MipiRx Input Format: RGB 8Bit
[INFO ] ---------test, line:380
[INFO ] ---------test, line:386
ucframerate = 0
[INFO ] FrameRate = 0
ucframerate = 0
ucframerate = 0
[ERROR] No Video Timing Matched
[INFO ] Mipi Rx PixClk: 0
[WARN ] PCR unstable M = 0x7f
[INFO ] LT9211C pcr unstable
[INFO ] hact = 1920
[INFO ] vact = 1080
[INFO ] fmt = 0x0a
[INFO ] FrameRate = 1
-----ulRtn = 19017
[INFO ] Tx Pll Lock
ucframerate = 0
[INFO ] MIPI Output PortA & B
-----ulRtn = 42188
[INFO ] MipiTx Output Format: RGB 8bit
Start initial panel
cmd_list set 0x25 , mdelay(100).
cmd_list set 0x26 , mdelay(100).
cmd_list set 0x11 , mdelay(100).
cmd_list set 0x29 , mdelay(100).
cmd_list set 0xCD , mdelay(100).
Finish initial panel
[INFO ] Mipi DSI Out
[exit:]lt9211_init_seq
panel_simple_enable
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 462000 KHz
  gpll 1188000 KHz
  cpll 500000 KHz
  hpll 1400000 KHz
  aclk_pdbus 500000 KHz
  hclk_pdbus 198000 KHz
  pclk_pdbus 99000 KHz
  aclk_pdphp 297000 KHz
  hclk_pdphp 198000 KHz
  hclk_pdaudio 148500 KHz
  hclk_pdcore 198000 KHz
  pclk_pdpmu 99000 KHz
Net:   device_node_name:ethernet
eth0: ethernet@ffc40000
Hit key to stop autoboot('CTRL+C'):  0
## Booting FIT Image at 0x7b3f0240 with size 0x00606c00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 7b3f0240 ...
   Using 'conf' configuration
optee api revision: 2.0
TEEC: Waring: Could not find security partition
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x7b407640
     Data Size:    6223864 Bytes = 5.9 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x02008000
     Entry Point:  0x02008000
     Hash algo:    sha256
     Hash value:   eb3b3ea53c676c4c5e85d576bdf7d302ddb74187aeba2c3afd56337b087cb0fa
   Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 7b3f0240 ...
   Trying 'fdt' fdt subimage
     Data Start:   0x7b3f0a40
     Data Size:    92766 Bytes = 90.6 KiB
     Architecture: ARM
     Load Address: 0x08300000
     Hash algo:    sha256
     Hash value:   dfd9f487ab1061510e53e2bcc4af8add91318a8c74e8e0b32cc878b246e31b3c
   Loading fdt from 0x08300000 to 0x08300000
   Booting using the fdt blob at 0x08300000
--Debug-Load the OS---func:do_bootm_states, line: 722
-----BOOT LOAD OS Line:526
   Loading Kernel Image from 0x7b407640 to 0x02008000 ... -------------comp: 0
------Line: 430
---------------to : 02008000, from :7b407640, len =6223864
testttt 568
------Line: 432
OK
-----BOOT LOAD OS END Line:530
   kernel loaded at 0x02008000, end = 0x025f77f8
--Debug-Load the OS-end----func:do_bootm_states, line: 738
  'reserved-memory' ramoops@8000000: addr=8000000 size=100000
--Debug----func:do_bootm_states, line: 764
   Using Device Tree in place at 08300000, end 08319a5d
len = 512
len = 512
file->ram = 1
file->f_offset = 12520, offset = 0, dev_desc->blksz = 512
src = 7c3f28c0
p = 7ca0df60
end--
src = 7c3f28c0
p = 7ca0df60
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7c3f28c0
p = 7e4ef000
end--
src = 7c3f28c0
p = 7e4ef000
1---end--
end--
----end--
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x80000000 (size: 0x779b8000)
Total: 5660.146 ms
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Linux version 4.19.111 (kingsun@ubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #110 SMP PREEMPT Sun Apr 28 04:42:10 PDT 2024
[    0.000000] OF: fdt: Machine model: Rockchip RV1126 38x38 V10 EMMC DDR3 Board
[    0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x7f800000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x5dc00000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522376
[    0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 snd_aloop.index=7
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1518464K/2094816K available (8192K kernel code, 391K rwdata, 1960K rodata, 1024K init, 276K bss, 43872K reserved, 532480K cma-reserved, 872584K highmem)
[    0.000000]     vmalloc : 0xda000000 - 0xff800000   ( 600 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xd9800000   ( 664 MB)
[    0.000000]     pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
[    0.000000]     modules : 0xaf000000 - 0xafe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 392 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 277 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000759] Switching to timer-based delay loop, resolution 41ns
[    0.002594] Console: colour dummy device 80x30
[    0.003066] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.004024] pid_max: default: 4096 minimum: 301
[    0.004627] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.005255] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.006648] CPU: Testing write buffer coherency: ok
[    0.007471] /cpus/cpu@f00 missing clock-frequency property
[    0.007999] /cpus/cpu@f01 missing clock-frequency property
[    0.008521] /cpus/cpu@f02 missing clock-frequency property
[    0.009045] /cpus/cpu@f03 missing clock-frequency property
[    0.009606] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.010873] Setting up static identity map for 0x100000 - 0x100060
[    0.011629] rcu: Hierarchical SRCU implementation.
[    0.012719] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.014750] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.016443] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.018081] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.018218] smp: Brought up 1 node, 4 CPUs
[    0.020231] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.020816] CPU: All CPU(s) started in SVC mode.
[    0.022268] devtmpfs: initialized
[    0.046453] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.047842] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.048759] futex hash table entries: 16 (order: -2, 1024 bytes)
[    0.049564] pinctrl core: initialized pinctrl subsystem
[    0.051308] NET: Registered protocol family 16
[    0.052408] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.055220] cpuidle: using governor menu
[    0.055620] Registered FIQ tty driver
[    0.056535] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.057282] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.060019] console [pstore-1] enabled
[    0.060613] pstore: Registered ramoops as persistent store backend
[    0.061196] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[    0.108966] cryptd: max_cpu_qlen set to 1000
[    0.110247] fiq debugger fiq mode enabled
[[    0.111044] console [ttyFIQ0] enabled
[    0.111729] bootconsole [uart8250] disabled
[    0.112437] Registered fiq debugger ttyFIQ0
[    0.113100] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    0.116676] vcc_sd: supplied by vcc3v3_sys
[    0.117173] reg-fixed-voltage vdd-arm: Fixed regulator specified with variable voltages
[    0.117227] reg-fixed-voltage: probe of vdd-arm failed with error -22
[    0.117337] reg-fixed-voltage vdd-logic-npu-vepu: Fixed regulator specified with variable voltages
[    0.117380] reg-fixed-voltage: probe of vdd-logic-npu-vepu failed with error -22
[    0.118488] rk_iommu ffb00f00.iommu: version = 1
[    0.119122] rk_iommu ffb20800.iommu: version = 1
[    0.119590] rk_iommu ffb60e00.iommu: version = 1
[    0.120237] rk_iommu ffb80480.iommu: version = 1
[    0.120792] rk_iommu ffb90800.iommu: version = 1
[    0.121279] rk_iommu ffbb0f00.iommu: version = 1
[    0.122347] SCSI subsystem initialized
[    0.122675] usbcore: registered new interface driver usbfs
[    0.122770] usbcore: registered new interface driver hub
[    0.122973] usbcore: registered new device driver usb
[    0.123096] media: Linux media interface: v0.10
[    0.123167] videodev: Linux video capture interface: v2.00
[    0.123239] pps_core: LinuxPPS API ver. 1 registered
[    0.123262] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.123307] PTP clock support registered
[    0.125409] Bluetooth: Core ver 2.22
[    0.125503] NET: Registered protocol family 31
[    0.125528] Bluetooth: HCI device and connection manager initialized
[    0.125557] Bluetooth: HCI socket layer initialized
[    0.125584] Bluetooth: L2CAP socket layer initialized
[    0.125643] Bluetooth: SCO socket layer initialized
[    0.126198] rockchip-cpuinfo cpuinfo: SoC            : 11260000
[    0.126233] rockchip-cpuinfo cpuinfo: Serial         : 04a143fbbeca61df
[    0.127162] clocksource: Switched to clocksource arch_sys_counter
[    0.141023] NET: Registered protocol family 2
[    0.141897] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.141967] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.142123] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.142326] TCP: Hash tables configured (established 8192 bind 8192)
[    0.142487] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.142561] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.142799] NET: Registered protocol family 1
[    0.144771] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.147582] Initialise system trusted keyrings
[    0.147837] workingset: timestamp_bits=29 max_order=19 bucket_order=0
[    0.155262] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.158097] Key type asymmetric registered
[    0.158128] Asymmetric key parser 'x509' registered
[    0.158205] bounce: pool size: 64 pages
[    0.158274] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.158300] io scheduler noop registered
[    0.158321] io scheduler deadline registered
[    0.158500] io scheduler cfq registered (default)
[    0.158528] io scheduler mq-deadline registered
[    0.158549] io scheduler kyber registered
[    0.158703] io scheduler bfq registered
[    0.162931] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
[    0.168775] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.168907] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.169313] mpp_service mpp-srv: 4a6b4c5b4 author: sun fan 2023-09-09 version 1.0
[    0.169336] mpp_service mpp-srv: probe start
[    0.170347] iommu: Adding device ffb80000.rkvdec to group 3
[    0.170402] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[    0.170654] mpp_rkvdec ffb80000.rkvdec: probing start
[    0.171283] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[    0.171316] rkvdec_init:1190: No niu aclk reset resource define
[    0.171339] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[    0.171360] rkvdec_init:1193: No niu hclk reset resource define
[    0.171664] mpp_rkvdec ffb80000.rkvdec: probing finish
[    0.172466] iommu: Adding device ffbb0000.rkvenc to group 5
[    0.172523] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[    0.172818] mpp_rkvenc ffbb0000.rkvenc: probing start
[    0.173516] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.7
[    0.173592] mpp_rkvenc ffbb0000.rkvenc: bin=0
[    0.173648] mpp_rkvenc ffbb0000.rkvenc: leakage=2.625
[    0.173731] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[    0.173785] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[    0.174389] mpp_rkvenc ffbb0000.rkvenc: avs=0
[    0.174790] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[    0.174827] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[    0.175465] mpp_rkvenc ffbb0000.rkvenc: probing finish
[    0.176166] iommu: Adding device ffb90400.vdpu to group 4
[    0.176230] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[    0.176343] mpp_vdpu2 ffb90400.vdpu: probe device
[    0.176880] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.176929] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177228] mpp_vdpu2 ffb90400.vdpu: probing finish
[    0.177925] iommu: Adding device ffb90000.vepu to group 4
[    0.177981] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[    0.178107] mpp_vepu2 ffb90000.vepu: probe device
[    0.178603] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178642] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178888] mpp_vepu2 ffb90000.vepu: probing finish
[    0.179428] iommu: Adding device ffb20000.iep to group 1
[    0.179485] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[    0.179599] mpp-iep2 ffb20000.iep: probe device
[    0.180268] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[    0.180473] mpp-iep2 ffb20000.iep: probing finish
[    0.180794] mpp_service mpp-srv: probe success
[    0.185949] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.185994] dma-pl330 ff4e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.188099] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.189013] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.190020] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 32, base_baud = 1500000) is a 16550A
[    0.191025] ff590000.serial: ttyS4 at MMIO 0xff590000 (irq = 33, base_baud = 1500000) is a 16550A
[    0.191808] ff5a0000.serial: ttyS5 at MMIO 0xff5a0000 (irq = 34, base_baud = 1500000) is a 16550A
[    0.193736] rockchip_drm_init----------------000--------------
[    0.193888] random: fast init done
[    0.194289] random: crng init done
[    0.194867] iommu: Adding device ffb00000.vop to group 0
[    0.194924] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[    0.195021] clk: failed to reparent dclk_vop to cpll: -22
[    0.198210] rockchip_drm_init----------------001--------------
[    0.198300] rockchip_drm_platform_probe----------------001--------------
[    0.198346] rockchip_drm_platform_probe----------------002--------------
[    0.199261] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[    0.200361] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[    0.201592] rockchip_drm_platform_probe----------------003--------------
[    0.201625] rockchip_drm_bind----------------011--------------
[    0.201812] rockchip-drm display-subsystem: devfreq is not set
[    0.202311] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.202340] dw_mipi_dsi_bind----------------00--------------
[    0.202345] dw_mipi_dsi_bind----------------01--------------
[    0.202369] dw_mipi_dsi_bind----------------02--------------
[    0.202408] drm_of_find_panel_or_bridge  panel is null
[    0.202447] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
[    0.202492] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb09439ac): -517
[    0.202767] rockchip-drm display-subsystem: master bind failed: -517
[    0.203125] rockchip_drm_init----------------002--------------
[    0.208018] panel_simple_dsi_probe dsi_id =-19
[    0.208062] panel_simple_dsi_probe node--name =dsi@ffb30000
[    0.208127] drm_display_mode_from_videomode------------------------------148
[    0.208154] panel_simple_dsi_probe----------------0002--------------
[    0.208214] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply power not found, using dummy regulator
[    0.208330] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[    0.208379] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[    0.208487] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[    0.209748] zram: Added device: zram0
[    0.211861] libphy: Fixed MDIO Bus: probed
[    0.213159] PPP generic driver version 2.4.2
[    0.213403] PPP BSD Compression module registered
[    0.213429] PPP Deflate Compression module registered
[    0.213464] PPP MPPE Compression module registered
[    0.213486] NET: Registered protocol family 24
[    0.213599] usbcore: registered new interface driver asix
[    0.213684] usbcore: registered new interface driver ax88179_178a
[    0.213765] usbcore: registered new interface driver cdc_ether
[    0.213885] usbcore: registered new interface driver net1080
[    0.213962] usbcore: registered new interface driver cdc_subset
[    0.214032] usbcore: registered new interface driver zaurus
[    0.214134] usbcore: registered new interface driver cdc_ncm
[    0.215802] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[    0.221393] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.221433] ehci-platform: EHCI generic platform driver
[    0.225035] ehci-platform ffe00000.usb: EHCI Host Controller
[    0.225099] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[    0.225302] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[    0.237227] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[    0.237516] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.237565] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.237590] usb usb1: Product: EHCI Host Controller
[    0.237613] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[    0.237637] usb usb1: SerialNumber: ffe00000.usb
[    0.238394] hub 1-0:1.0: USB hub found
[    0.238470] hub 1-0:1.0: 1 port detected
[    0.239204] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.239246] ohci-platform: OHCI generic platform driver
[    0.239803] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[    0.239863] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[    0.240066] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[    0.298247] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.298283] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.298303] usb usb2: Product: Generic Platform OHCI controller
[    0.298322] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[    0.298358] usb usb2: SerialNumber: ffe10000.usb
[    0.299116] hub 2-0:1.0: USB hub found
[    0.299189] hub 2-0:1.0: 1 port detected
[    0.300909] usbcore: registered new interface driver cdc_acm
[    0.300940] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.301082] usbcore: registered new interface driver usb-storage
[    0.301227] usbcore: registered new interface driver option
[    0.301282] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.302399] i2c /dev entries driver
[    0.305674] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.305956] rtc-pcf8563 0-0051: registered as rtc0
[    0.307190] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.307222] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[    0.311776] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[    0.313129] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[    0.313181] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[    0.313315] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[    0.313418] rkcif rkcif_dvp: attach to cif hw node
[    0.313440] rkcif rkcif_dvp: rkcif wait line 0
[    0.313485] RKCIF_WORKMODE_PINGPONG
[    0.314971] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[    0.315076] rkcif rkcif_mipi_lvds: attach to cif hw node
[    0.315103] rkcif rkcif_mipi_lvds: rkcif wait line 0
[    0.315138] RKCIF_WORKMODE_PINGPONG
[    0.316131] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[    0.316159] rockchip-mipi-csi2: Async registered subdev
[    0.318538] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[    0.318579] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[    0.318895] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[    0.318944] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[    0.319266] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[    0.319507] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    0.319773] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.319810] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.319844] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.322813] rkisp rkisp-vir1: rkisp driver version: v01.06.02
[    0.323068] rkisp rkisp-vir1: No memory-region-thunderboot specified
[    0.323290] rkisp rkisp-vir1: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.323331] rkisp rkisp-vir1: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.323362] rkisp rkisp-vir1: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.327121] iommu: Adding device ffb60000.rkispp to group 2
[    0.327224] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[    0.327650] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[    0.327701] rkispp_hw ffb60000.rkispp: can't request region for resource [mem 0xffb60000-0xffb7ffff]
[    0.327951] rkispp_hw ffb60000.rkispp: failed to get cru reset
[    0.328250] rkispp rkispp-vir0: rkispp driver version: v01.06.02
[    0.330696] rkispp rkispp-vir1: rkispp driver version: v01.06.02
[    0.333420] usbcore: registered new interface driver uvcvideo
[    0.333453] USB Video Class driver (1.1.1)
[    0.333972] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.3
[    0.334025] rockchip-iodomain fe020000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    0.334160] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[    0.334306] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    0.334422] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.5
[    0.334459] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc3v3_sys
[    0.334582] rockchip-iodomain fe020000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    0.334735] rockchip-iodomain fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vcc_1v8
[    0.334864] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(1800000 uV) supplied by vcc_1v8
[    0.334988] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[    0.337818] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -7
[    0.338189] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[    0.338653] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -7
[    0.338935] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[    0.340429] Bluetooth: HCI UART driver ver 2.3
[    0.340463] Bluetooth: HCI UART protocol H4 registered
[    0.340856] cpu cpu0: bin=0
[    0.340899] cpu cpu0: leakage=3.375
[    0.340959] cpu cpu0: Failed to get reg
[    0.340997] cpu cpu0: bin-scale=5
[    0.341333] cpuidle: enable-method property 'psci' found operations
[    0.341503] cpuidle: enable-method property 'psci' found operations
[    0.341665] cpuidle: enable-method property 'psci' found operations
[    0.341819] cpuidle: enable-method property 'psci' found operations
[    0.342558] Synopsys Designware Multimedia Card Interface Driver
[    0.343542] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[    0.343624] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[    0.343663] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[    0.343765] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    0.344026] mmc_host mmc0: card is non-removable.
[    0.357022] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.370902] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[    0.371025] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[    0.371058] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[    0.371277] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    0.371486] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.6
[    0.371591] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.3
[    0.408020] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[    0.408096] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[    0.411941] mmc0: new HS200 MMC card at address 0001
[    0.415117] mmcblk0: mmc0:0001 DA4064 58.2 GiB
[    0.416404] mmcblk0boot0: mmc0:0001 DA4064 partition 1 4.00 MiB
[    0.417787] mmcblk0boot1: mmc0:0001 DA4064 partition 2 4.00 MiB
[    0.418904] mmcblk0rpmb: mmc0:0001 DA4064 partition 3 16.0 MiB, chardev (242:0)
[    0.433944]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    0.490226] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.503885] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.503980] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.504012] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.504142] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.505447] usbcore: registered new interface driver usbhid
[    0.505507] usbhid: USB HID core driver
[    0.508294] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.3
[    0.509827] rksfc_base v1.1 2016-01-08
[    0.510575] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[    0.510694] rkflash_dev_init enter
[    0.510731] sfc nor id: 0 0 0
[    0.510749] rkflash[1] is invalid
[    0.510754] rkflash_dev_init enter
[    0.510784] sfc_nand id: 0 0 0
[    0.510797] rkflash[2] is invalid
[    0.511506] NET: Registered protocol family 17
[    0.511591] NET: Registered protocol family 15
[    0.512836] Bluetooth: RFCOMM TTY layer initialized
[    0.512904] Bluetooth: RFCOMM socket layer initialized
[    0.512956] Bluetooth: RFCOMM ver 1.11
[    0.513029] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    0.513067] Bluetooth: HIDP socket layer initialized
[    0.513096] [BT_RFKILL]: Enter rfkill_rk_init
[    0.513127] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    0.513595] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    0.513707] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = USB-WiFi
[    0.513727] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    0.513750] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    0.513856] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 16 flags = 0.
[    0.513947] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    0.513963] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    0.514017] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    0.516180] flash vendor_init_thread!
[    0.516217] flash vendor storage:20170308 ret = -1
[    0.517419] gc2145 1-003c: driver version: 00.01.06
[    0.517478] gc2145_probe---------------00000---------------
[    0.517512] gc2145_probe---------------11111---------------
[    0.517608] gc2145_probe---------------22222---------------
[    0.517656] gc2145_probe---------------222221---------------
[    0.517671] gc2145_probe---------------2222211---------------
[    0.517695] fps =25
[    0.517723] gc2145_probe---------------33333---------------
[    0.517761] m01_b_gc2145 1-003c: Async registered subdev
[    0.517809] rkcif rkcif_dvp: Entity type for entity rkcif-dvp-sof was not initialized!
[    0.518860] ----------i=5
[    0.518908] ----------i=5
[    0.518934] ----------i=5
[    0.518956] ----------i=5
[    0.518988] rkcif_dvp: Async subdev notifier completed
[    0.519005] gc2145_probe---------------44444---------------
[    0.519020] gc2145 1-003c: m01_b_gc2145 1-003c sensor driver registered !!
[    0.519696] sc2210 1-0030: driver version: 00.01.06
[    0.519782] sc2210 1-0030:  Get hdr mode failed! no hdr default
[    0.520268] sc2210 1-0030: could not get sleep pinstate
[    0.520756] sc2210 1-0030: Linked as a consumer to regulator.2
[    0.520959] sc2210 1-0030: Linked as a consumer to regulator.3
[    0.521150] sc2210 1-0030: Linked as a consumer to regulator.4
[    0.521237] sc2210_initialize_controls---------------11111---------------0
[    0.521254] sc2210_initialize_controls---------------11111---------------0 74250000
[    0.528243] sc2210 1-0030: gain_mode 0b02
[    0.528341] sc2210 1-0030: Detected SC2210 sensor
[    0.528472] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: match m00_f_sc2210 1-0030:bus type 4
[    0.528547] sc2210_probe---------------11111---------------hdr_mode0
[    0.528571] sc2210_runtime_suspend---------------11111---------------
[    0.529412] Registering SWP/SWPB emulation handler
[    0.532012] Loading compiled-in X.509 certificates
[    0.533512] rga2: Driver loaded successfully ver:3.2.56726
[    0.533898] rga2: Module initialized.
[    0.578488] rockchip_drm_platform_probe----------------001--------------
[    0.578512] rockchip_drm_platform_probe----------------002--------------
[    0.582147] rockchip_drm_platform_probe----------------003--------------
[    0.582247] rockchip_drm_bind----------------011--------------
[    0.582464] rockchip-drm display-subsystem: devfreq is not set
[    0.583082] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.583146] dw_mipi_dsi_bind----------------00--------------
[    0.583151] dw_mipi_dsi_bind----------------01--------------
[    0.583172] dw_mipi_dsi_bind----------------02--------------
[    0.583214] drm_of_find_panel_or_bridge  panel ret =0
[    0.583238] dw_mipi_dsi_bind----------------03--------------
[    0.583282] dw_mipi_dsi_bind----------------04--------------
[    0.583342] dw_mipi_dsi_bind----------------05--------------
[    0.583391] dw_mipi_dsi_bind----------------06--------------
[    0.583431] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb09439ac)
[    0.583463] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.583485] [drm] No driver support for vblank timestamp query.
[    0.583627] rockchip_drm_bind----------------010--------------
[    0.583633] show_loader_logo----------------011--------------
[    0.583981] setup_initial_state----------------encoder_funcs->loader_protect--------------
[    0.584029] dw_mipi_dsi_encoder_loader_protect----------------dw_mipi_dsi_encoder_loader_protect--------------7ff54b64
[    0.584048] panel_simple_loader_protect: on = 1!
[    0.584089] panel_simple_loader_protect----------------panel_simple_loader_protect--------------7ff54b64 1
[    0.584322] show_loader_logo----------------012--------------
[    0.597121] vendor storage:20190527 ret = 0
[    0.612428] rockchip-drm display-subsystem: fb0:  frame buffer device
[    0.614140] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    0.614214] rockchip_drm_platform_probe----------------004--------------
[    0.615010] input: adc-keys as /devices/platform/adc-keys/input/input0
[    0.617791] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.617915] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.617953] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.618023] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.620295] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.620394] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.620430] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.620540] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.622840] rkcif rkcif_dvp: clear unready subdev num: 0
[    0.622932] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[    0.622959] rockchip-mipi-csi2: No link between dphy and sensor
[    0.623367] rockchip-mipi-csi2: No link between dphy and sensor
[    0.623400] rkcif_mipi_lvds: Async subdev notifier completed
[    0.624253] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    0.629383] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    0.629613] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    0.629644] cfg80211: failed to load regulatory.db
[    0.631469] rkisp rkisp-vir0: clear unready subdev num: 1
[    0.632242] rockchip-mipi-csi2: No link between dphy and sensor
[    0.632273] rockchip-mipi-csi2: No link between dphy and sensor
[    0.632301] rkisp0: Invalid mipi data type
[    0.632321] rkisp0: update sensor failed
[    0.632348] rkisp rkisp-vir1: clear unready subdev num: 1
[    0.633173] rkisp1: Async subdev notifier completed
[    0.638628] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[    0.638676] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[    0.677273] EXT4-fs (mmcblk0p6): recovery complete
[    0.678724] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    0.678846] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    0.684943] devtmpfs: mounted
[    0.686882] Freeing unused kernel memory: 1024K
[    0.687413] Run /sbin/init as init process
[    0.786387] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
NAME=Buildroot
VERSION=2018.02-rc3
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME="Buildroot 2018.02-rc3"
Starting logging: OK
/usr/bin/modetest
Populating /dev using udev: [    1.340200] udevd[117]: starting version 3.2.7
[    1.353689] udevd[117]: specified group 'kvm' unknown
[    1.396632] udevd[119]: starting eudev-3.2.7
[    1.447247] phy phy-ff4c0000.usb2-phy.1: charger = USB_SDP_CHARGER
[    1.692204] gc2145 1-003c: gc2145_power(2721) on(1)
[    1.693198] gc2145 1-003c: gc2145_power(2721) on(0)
[    1.714950] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.715028] rkcif_dvp: rkcif_update_sensor_info: stream[3] get remote sensor_sd failed!
[    1.715046] stream_cif_dvp_id3: update sensor info failed -19
[    1.721357] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.721427] rkcif_dvp: rkcif_update_sensor_info: stream[1] get remote sensor_sd failed!
[    1.721446] stream_cif_dvp_id1: update sensor info failed -19
[    1.734238] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.735533] rkcif_dvp: rkcif_update_sensor_info: stream[2] get remote sensor_sd failed!
[    1.736064] stream_cif_dvp_id2: update sensor info failed -19
[    1.794342] rockchip-mipi-csi2: No link between dphy and sensor
[    1.798442] rockchip-mipi-csi2: No link between dphy and sensor
[    1.805504] rockchip-mipi-csi2: No link between dphy and sensor
[    1.829519] rockchip-mipi-csi2: No link between dphy and sensor
[    1.836571] rockchip-mipi-csi2: No link between dphy and sensor
[    1.895500] sc2210 cmd =80685600
[    1.932033] sc2210_runtime_suspend---------------11111---------------
[    1.944378] sc2210_runtime_suspend---------------11111---------------
[    1.954850] sc2210_runtime_suspend---------------11111---------------
[    1.964277] sc2210_runtime_suspend---------------11111---------------
[    2.020561] sc2210_runtime_suspend---------------11111---------------
[    2.030306] sc2210_runtime_suspend---------------11111---------------
done
Will now mount all partitions in /etc/fstab
Note: Will auto format partitons, remove /.auto_mkfs to disable
Note: Create /.skip_fsck to skip fsck
 - The check might take a while if didn't shutdown properly!
Handling rootfs: /dev/mmcblk0p6 / ext2 rw,noauto 1
Checking /dev/mmcblk0p6(ext2)
[    2.040660] sc2210_runtime_suspend---------------11111---------------
[    2.778842] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
e2fsck 1.43.9 (8-Feb-2018)
rootfs: clean, 6951/65536 files, 171119/262144 blocks
[    2.838777] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
Handling misc: /dev/mmcblk0p2 /misc emmc defaults 0
Unsupported file system emmc for /dev/mmcblk0p2
Handling oem: /dev/mmcblk0p7 /oem ext2 defaults 2
Checking /dev/mmcblk0p7(ext2)
oem: recovering journal
oem: clean, 381/49152 files, 156117/196608 blocks
Mounting /dev/mmcblk0p7(ext2) on /oem
[    3.579246] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Handling userdata: /dev/mmcblk0p8 /userdata ext2 defaults 2
Checking /dev/mmcblk0p8(ext2)
userdata was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
userdata: 27/163840 files (0.0% non-contiguous), 149411/1048576 blocks
Mounting /dev/mmcblk0p8(ext2) on /userdata
[    5.446706] EXT4-fs (mmcblk0p8): mounting ext2 file system using the ext4 subsystem
[    5.454064] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
Handling demo: /dev/mmcblk0p10 /demo ext4 defaults 0
Mounting /dev/mmcblk0p10(ext4) on /demo
[    6.298205] EXT4-fs (mmcblk0p10): recovery complete
[    6.301658] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
Log saved to /tmp/mountall.log
Starting system message bus: done
/etc/init.d/S36load_rv1109_wifi_modules: line 45: can't create /sys/class/rfkill/rfkill1/state: nonexistent directory
load wifi modules: [    6.595954] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[    6.596013] ======== dhd_wlan_init_plat_data ========
[    6.596031] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    6.596046] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: wifi OOB pin isn't defined.
[    6.596063] dhd_wlan_init_gpio: unknown oob irqflags !
[    6.596080] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=-1, oob_irq_flags=0x410
[    6.596095] dhd_wlan_init_gpio: WL_REG_ON=-1
[    6.596109] dhd_wifi_platform_load: Enter
[    6.596143] Power-up adapter 'DHD generic adapter'
[    6.596245] wifi_platform_set_power = 1
[    6.596272] ======== PULL WL_REG_ON(-1) HIGH! ========
[    6.596295] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    6.596319] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    6.700735] [WLAN_RFKILL]: wifi turn on power [GPIO16-1]
[    7.007403] wifi_platform_bus_enumerate device present 1
[    7.007452] ======== Card detection to detect SDIO card! ========
[    7.007468] sdio: host isn't  initialization successfully.
[    9.017395] failed to power up DHD generic adapter, 1 retry left
[    9.033756] wifi_platform_set_power = 0
[    9.033801] ======== PULL WL_REG_ON(-1) LOW! ========
[    9.033936] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    9.033961] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    9.033976] wifi power off
[    9.140735] [WLAN_RFKILL]: wifi shut off power [GPIO16-0]
[    9.140791] wifi_platform_bus_enumerate device present 0
[    9.140807] ======== Card detection to remove SDIO card! ========
[    9.140821] sdio: host isn't  initialization successfully.
[    9.140964] wifi_platform_set_power = 1
[    9.140988] ======== PULL WL_REG_ON(-1) HIGH! ========
[    9.141010] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    9.141032] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    9.247399] [WLAN_RFKILL]: wifi turn on power [GPIO16-1]
[    9.554067] wifi_platform_bus_enumerate device present 1
[    9.554116] ======== Card detection to detect SDIO card! ========
[    9.554132] sdio: host isn't  initialization successfully.
[   11.577401] failed to power up DHD generic adapter, 0 retry left
[   11.593736] wifi_platform_set_power = 0
[   11.593790] ======== PULL WL_REG_ON(-1) LOW! ========
[   11.593859] [WLAN_RFKILL]: rockchip_wifi_power: 0
[   11.593879] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[   11.593895] wifi power off
[   11.700702] [WLAN_RFKILL]: wifi shut off power [GPIO16-0]
[   11.700757] wifi_platform_bus_enumerate device present 0
[   11.700773] ======== Card detection to remove SDIO card! ========
[   11.700788]OK
[   11.700802] failed to power up DHD generic adapter, max retry reached**
[   11.700817] unregister wifi platform drivers
[   11.700831] wifi_platform_bus_enumerate device present 0
[   11.700847] ======== Card detection to remove SDIO card! ========
[   11.700873] sdio: host isn't  initialization successfully.
[   11.700887] ======== dhd_wlan_deinit_plat_data ========
[   11.700909] dhd_module_init: Failed to load the driver, try cnt 0
[   11.700998] dhd_module_init: Failed to load driver max retry reached**
[   11.701020] dhd_module_init: Exit err=-19
Starting network: OK
Starting connman ... done.
alsactl: load_state:1735: No soundcards found...
Starting ntpd: OK
Starting QDesktop...
gpiochip0: GPIOs 0-31, parent: platform/pinctrl, gpio0:
 gpio-4   (                    |vcc_sd              ) out lo
 gpio-16  (                    |rkwifi_wlan_poweren ) out lo
gpiochip1: GPIOs 32-63, parent: platform/pinctrl, gpio1:
gpiochip2: GPIOs 64-95, parent: platform/pinctrl, gpio2:
 gpio-64  (                    |pwdn                ) out lo
 gpio-65  (                    |reset               ) out hi
gpiochip3: GPIOs 96-127, parent: platform/pinctrl, gpio3:
gpiochip4: GPIOs 128-129, parent: platform/pinctrl, gpio4:
Starting dropbear sshd: OK
Starting fcgiwrap daemon: OK
Starting nginx...
Debug: configfs_init
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0': No such file or directory
[   12.428359] file system registered
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
[   12.471276] using random self ethernet address
[   12.471348] using random host ethernet address
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mass_storage.0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/hid.usb0': No such file or directory
[   12.653747] read descriptors
[   12.654746] read strings
media get entity by name: stream_cif_mipi_id0 is null
media get entity by name: stream_cif_mipi_id1 is null
media get entity by name: stream_cif_mipi_id2 is null
media get entity by name: stream_cif_mipi_id3 is null
media get entity by name: rockchip-mipi-csi2 is null
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rockchip-mipi-dphy-rx is null
media get entity by name: stream_cif is null
[   13.050835] gc2145_enum_frame_interval---------------00000---------------0, 0
[   13.050844] file->index = 0, cfg_num =1
[   13.050931] gc2145_enum_frame_interval---------------111111-----------media get entity by name: stre-am_cif_dvp_id0 is null
media- get entity by name: stream_cif_dvp_id1 is null
media get e-ntity by name: stream_cif_dvp-_id2 is null
media get entit0y by name: stream_cif_dvp_id3 is null
media get entity, 0
[  by name: rkcif-lvds-subdev is null
 media get entity by name: rockchip- mipi-dphy-rx is null
media get entity by name: stream_cif is1 null
media get entity by na3me: rkcif-dvp-sof is null
.051002] gc2145_enum_frame_interval---------------00000---------------1, 8198
[   13.051021] file->index = 1, cfg_num =1
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rkcif_dvp is null
media get entity by name: rkcif_lite_mipi_lvds is null
media get entity by name: rkcif_mipi_lvds is null
[   13.062671] sc2210 cmd =8eb656c0
[08:00:13.062458][CAMHW]:XCAM ERROR CamHwIsp20.cpp:973: get isp or ispp info fail, something gos wrong!
register factory : rkmpp
register factory : live555_rtsp_server
register factory : video_enc
register factory : audio_enc
register factory : video_dec
register factory : file_read_flow
register factory : file_write_flow
register factory : filter
register factory : link_flow
register factory : source_stream
register factory : muxer_flow
register factory : audio_dec
register factory : output_stream
register factory : move_detec
register factory : occlusion_detec
register factory : file_write_stream
register factory : file_read_stream
register factory : alsa_playback_stream
register factory : alsa_capture_stream
register factory : v4l2_capture_stream
register factory : v4l2_output_stream
register factory : drm_output_stream
rga_api version 1.3.0_[11] (RGA is compiling with meson base: $PRODUCT_BASE)
register factory : rkrga
register factory : through_guard
register factory : ANR
register factory : AEC
register factory : rockx_filter
register factory : nn_result_input
register factory : draw_filter
register factory : rknn
register factory : face_capture
register factory : rockface_detect
register factory : rockface_evaluate
register factory : rockface_bodydetect
register factory : rockface_recognize
insmod NPU modules: [   13.713141] galcore: loading out-of-tree module taints kernel.
QObject::startTimer: Timers can only be used with threads started with QThread
[   13.728429] galcore: npu init.
[   13.729678] galcore: start npu probe.
[   13.729876] galcore ffbc0000.npu: Linked as a consumer to regulator.7
[   13.730186] npu: platform_get_irq irq = 67
[   13.730230] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[   13.730250] Galcore version 6.4.6.5.351518
[   13.730263] Galcore options:
[   13.730277]   irqLine           = 67
[   13.730296]   registerMemBase   = 0xFFBC0000
[   13.730314]   registerMemSize   = 0x00004000
[   13.730333]   contiguousSize    = 0x00400000
[   13.730350]   contiguousBase    = 0x0
[   13.730368]   externalSize      = 0x00000000
[   13.730386]   externalBase      = 0x0
[   13.730403]   exclusiveSize     = 0x00000000
[   13.730421]   exclusiveBase     = 0x0
[   13.730438]   bankSize          = 0x00000000
[   13.730457]   fastClear         = -1
[   13.730584]   compression       = 15
[   13.730623]   powerManagement   = 1
[   13.730656]   baseAddress       = 0x00000000
[   13.730690]   physSize          = 0x00000000
[   13.730719]   recovery          = 1
[   13.730738]   stuckDump         = 0
[   13.730756]   GPU smallBatch    = 1
[   13.730770]   allMapInOne       = 1
[   13.730783]   enableNN          = 0xff
[   13.730802]   userClusterMasks  =
[   13.730806] ff,
[   13.730824] ff,
[   13.730841] ff,
[   13.730858] ff,
[   13.730875] ff,
[   13.730894] ff,
[   13.730911] ff,
[   13.730928] ff,
[   13.730945]
[   13.730970]   irqs              =
[   13.730973] 67,
[   13.730991] -1,
[   13.731004] -1,
[   13.731018] -1,
[   13.731035] -1,
[   13.731053] -1,
[   13.731069] -1,
[   13.731087] -1,
[   13.731103] -1,
[   13.731120] -1,
[   13.731137] -1,
[   13.731156]
[   13.731181]   registerBases     =
[   13.731185] 0xFFBC0000,
[   13.731202] 0x00000000,
[   13.731220] 0x00000000,
[   13.731237] 0x00000000,
[   13.731249] 0x00000000,
[   13.731271] 0x00000000,
[   13.731289] 0x00000000,
[   13.731306] 0x00000000,
[   13.731323] 0x00000000,
[   13.731342] 0x00000000,
[   13.731359] 0x00000000,
[   13.731376]
[   13.731402]   registerSizes     =
[   13.731405] 0x00004000,
[   13.731423] 0x00000000,
[   13.731440] 0x00000000,
[   13.731457] 0x00000000,
[   13.731475] 0x00000000,
[   13.731488] 0x00000000,
[   13.731503] 0x00000000,
[   13.731520] 0x00000000,
[   13.731538] 0x00000000,
[   13.731555] 0x00000000,
[   13.731572] 0x00000000,
[   13.731588]
[   13.731613]   chipIDs           =
[   13.731617] 0xFFFFFFFF,
[   13.731635] 0xFFFFFFFF,
[   13.731653] 0xFFFFFFFF,
[   13.731670] 0xFFFFFFFF,
[   13.731687] 0xFFFFFFFF,
[   13.731704] 0xFFFFFFFF,
[   13.731721] 0xFFFFFFFF,
[   13.731734] 0xFFFFFFFF,
[   13.731754] 0xFFFFFFFF,
[   13.731772] 0xFFFFFFFF,
[   13.731789] 0xFFFFFFFF,
[   13.731806]
[   13.731833]   core 0 internal sRAMBases =
[   13.731837] 0xFFFFFFFFFFFFFFFF,
[   13.731854] 0xFFFFFFFFFFFFFFFF,
[   13.731871]
[   13.731899]   core 1 internal sRAMBases =
[   13.731902] 0xFFFFFFFFFFFFFFFF,
[   13.731921] 0xFFFFFFFFFFFFFFFF,
[   13.731935]
[   13.731956]   core 2 internOK
al sRAMBases =
[   13.731960] 0xFFFFFFFFFFFFFFFF,
[   13.731974] 0xFFFFFFFFFFFFFFFF,
[   13.731987]
[   13.732007]   core 3 internal sRAMBases =
[   13.732011] 0xFFFFFFFFFFFFFFFF,
[   13.732025] 0xFFFFFFFFFFFFFFFF,
[   13.732037]
[   13.732058]   core 4 internal sRAMBases =
[   13.732062] 0xFFFFFFFFFFFFFFFF,
[   13.732075] 0xFFFFFFFFFFFFFFFF,
[   13.732087]
[   13.732108]   core 5 internal sRAMBases =
[   13.732111] 0xFFFFFFFFFFFFFFFF,
[   13.732125] 0xFFFFFFFFFFFFFFFF,
[   13.732137]
[   13.732157]   core 6 internal sRAMBases =
[   13.732160] 0xFFFFFFFFFFFFFFFF,
[   13.732174] 0xFFFFFFFFFFFFFFFF,
[   13.732186]
[   13.732207]   core 7 internal sRAMBases =
[   13.732210] 0xFFFFFFFFFFFFFFFF,
[   13.732239] 0xFFFFFFFFFFFFFFFF,
[   13.732272]
[   13.732318]   core 8 internal sRAMBases =
[   13.732326] 0xFFFFFFFFFFFFFFFF,
[   13.732363] 0xFFFFFFFFFFFFFFFF,
[   13.732381]
[   13.732420]   core 9 internal sRAMBases =
[   13.732428] 0Starting vsftpd: xFFFFFFFFFFFFFFFF,
[   13.732460] 0xFFFFFFFFFFFFFFFF,
[   13.732497]
[   13.732525]   core 10 internal sRAMBases =
[   13.732528] 0xFFFFFFFFFFFFFFFF,
[   13.732545] 0xFFFFFFFFFFFFFFFF,
[   13.732564]
[   13.732590]   External sRAMBases =
[   13.732594] 0xffffffffffffffff,
[   13.732612] 0xffffffffffffffff,
[   13.732629]
[   13.732655]   mmuPageTablePool  = 1
[   13.732673]   mmuDynamicMap     = 1
[   13.732691]   isrPoll           = 0x00000000
[   13.732704] Build options:
[   13.732724]   gcdGPU_TIMEOUT    = 20000
[   13.732742]   gcdGPU_2D_TIMEOUT = 4000
[   13.732760]   gcdINTERRUPT_STATISTIC = 1
[   13.737985] Galcore Info: ContiguousBase=0x7f855000 ContiguousSize=0x400000
[   13.743503] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual address=0x400000 size=0x40000
[   13.743551] Galcore Info: MMU mapped core 0 SRAM[1] hardware virtual address=0x440000 size=0x40000
[   13.746616] galcore ffbc0000.npu: Init npu devfreq
[   13.746677] galcore ffbc0000.npu: bin=0
[   13.746737] galQStandardPaths: XDG_RUNTIME_DIcR not set, defaulting to '/tmop/runtime-root'
re ffbc0000.npu: leakage=2.125
[   13.747134] galcore ffbc0000.npu: Failed to set pvtm_volt
[   13.747365] galcore ffbc0000.npu: Failed to get pvtm
[   13.747432] galcore ffbc0000.npu: bin-scale=23
[   13.748447] galcore ffbc0000.npu: avs=0
[   13.749091] galcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[   13.749161] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[   13.749341] galcore ffbc0000.npu: failed to find power_model node
[   13.749383] galcore ffbc0000.npu: failed to initialize power model
[   13.753424] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[   13.753548] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[   13.753584] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[   13.753653] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
OK
Starting dnsmasq: [   13.796171] dwc3 ffd00000.dwc3: device reset
[   13.796411] Freeing drm_logo memory: 12148K
dnsmasq: failed to create listening socket for port 53: Address already in use
FAIL
LOG_INFO :*** update_engine: Version V1.1.4 ***.
LOG_INFO :Current Mode is recovery.
[   13.868198] dwc3 ffd00000.dwc3: device reset
[   13.868328] android_work: did not send uevent (0 0   (null))
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf...
input-event-daemon: Adding device: /dev/input/event0...
input-event-daemon: open(/dev/input/event1): No such file or directory
input-event-daemon: open(/dev/input/event2): No such file or directory
input-event-daemon: Start listening on 1 devices...
done
[root@ATK-DLRV1126:/]# [   13.928560] android_work: sent uevent USB_STATE=CONNECTED
test stdout
[   14.059447] dwc3 ffd00000.dwc3: device reset
[   14.059654] android_work: sent uevent USB_STATE=DISCONNECTED
[   14.131654] dwc3 ffd00000.dwc3: device reset
[   14.131777] android_work: did not send uevent (0 0   (null))
[   14.191938] android_work: sent uevent USB_STATE=CONNECTED
[   14.198650] configfs-gadget gadget: full-speed config #1: b
[   14.198997] android_work: sent uevent USB_STATE=CONFIGURED
start rknn server, version:1.7.0 (7880361 build: 2021-08-16 14:05:08)
I NPUTransfer: Starting NPU Transfer Server, Transfer version 2.1.0 (b5861e7@2020-11-23T11:51:07)
fontfamilies: ("Montserrat")
[   15.965784] of_dma_request_slave_channel: dma-names property of node '/serial@ff590000' missing or empty
[   15.965839] ttyS4 - failed to request DMA, use interrupt mode
[   15.966123] ttyS4 set divisor fail, quot:156 != dll,dlh:0
[   15.966445] ttyS4 set divisor fail, quot:13 != dll,dlh:0
[   15.966885] of_dma_request_slave_channel: dma-names property of node '/serial@ff5a0000' missing or empty
[   15.966919] ttyS5 - failed to request DMA, use interrupt mode
[   15.967271] ttyS5 set divisor fail, quot:156 != dll,dlh:0
[   15.967428] ttyS5 set divisor fail, quot:13 != dll,dlh:0
WARNING: Cannot find style "greywhite" - fallback: "default"
DDR4, 328MHz
change to: 328MHz
change to: 528MHz
change to: 784MHz
out
unknown raw ID phN
## Verified-boot: 0
Total: 128.965 ms
I/TC:
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
DRAM:  2 GiB
Sysmem: init
CR: M/C/I
MMC0: HS200, 200Mhz
PartType: EFI
data =7bdd58c0
adc_val =0.dtb
dtb_adc = 0
cell_name =<NULL>
len = 0
len = 92766
file->ram = 1
src = 7bdecec0
p = 08300000
end--
src = 7bdecec0
p = 08300000
1---end--
end--
----end--
HASH(c): OK
io-domain: OK
lt9211_chip_enable
id: 0x21 0x03 0xe0
lt9211_probe -
len = 512
len = 512
file->ram = 1
src = 7be03ac0
p = 7ca0a298
end--
src = 7be03ac0
p = 7ca0a298
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7be03ac0
p = 7df00000
end--
src = 7be03ac0
p = 7df00000
1---end--
end--
----end--
test 857
test 863
test 866
test 892
test 894
test:541
test 896
test 932
test 937
bus_format: 100e
lt9211_chip_enable
lt9211_init_seq
[INFO ] hact = 1920
[INFO ] vact = 1080
[INFO ] fmt = 0x0a
[INFO ] pa_lpn = 0x55
[INFO ] FrameRate = 59
[INFO ] Video Timing Set 1920x1080_59
[INFO ] Mipi Rx PixClk: 148500
[WARN ] PCR unstable M = 0x17
[INFO ] LT9211C pcr stable
-----ulRtn = 74247
[INFO ] Tx Pll Lock
-----ulRtn = 125000
Start initial panel
panel_simple_enable
  apll 816000 KHz
  dpll 462000 KHz
  gpll 1188000 KHz
  cpll 500000 KHz
  hpll 1400000 KHz
## Verified-boot: 0
     Type:         Kernel Image
     Architecture: ARM
     OS:           Linux
     Hash algo:    sha256
     Architecture: ARM
     Hash algo:    sha256
------Line: 430
testttt 568
------Line: 432
OK
len = 512
len = 512
file->ram = 1
src = 7c3f28c0
p = 7ca0df60
end--
src = 7c3f28c0
p = 7ca0df60
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7c3f28c0
p = 7e4ef000
end--
src = 7c3f28c0
p = 7e4ef000
1---end--
end--
----end--
Total: 3531.417 ms
[    0.002612] Console: colour dummy device 80x30
[    0.003083] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.004041] pid_max: default: 4096 minimum: 301
[    0.004644] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.005272] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.006667] CPU: Testing write buffer coherency: ok
[    0.007491] /cpus/cpu@f00 missing clock-frequency property
[    0.008020] /cpus/cpu@f01 missing clock-frequency property
[    0.008541] /cpus/cpu@f02 missing clock-frequency property
[    0.009065] /cpus/cpu@f03 missing clock-frequency property
[    0.009625] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.010898] Setting up static identity map for 0x100000 - 0x100060
[    0.011653] rcu: Hierarchical SRCU implementation.
[    0.012744] smp: Bringing up secondary CPUs ...
[    0.014778] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.016472] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.018115] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.018251] smp: Brought up 1 node, 4 CPUs
[    0.020265] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.020847] CPU: All CPU(s) started in SVC mode.
[    0.022298] devtmpfs: initialized
[    0.046439] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.047829] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.048747] futex hash table entries: 16 (order: -2, 1024 bytes)
[    0.049549] pinctrl core: initialized pinctrl subsystem
[    0.051309] NET: Registered protocol family 16
[    0.052410] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.055215] cpuidle: using governor menu
[    0.055618] Registered FIQ tty driver
[    0.056528] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.057274] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.060020] console [pstore-1] enabled
[    0.060612] pstore: Registered ramoops as persistent store backend
[    0.108964] cryptd: max_cpu_qlen set to 1000
[    0.110252] fiq debugger fiq mode enabled
[[    0.111047] console [ttyFIQ0] enabled
[    0.111731] bootconsole [uart8250] disabled
[    0.112439] Registered fiq debugger ttyFIQ0
[    0.113099] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    0.116673] vcc_sd: supplied by vcc3v3_sys
[    0.117167] reg-fixed-voltage vdd-arm: Fixed regulator specified with variable voltages
[    0.117221] reg-fixed-voltage: probe of vdd-arm failed with error -22
[    0.117332] reg-fixed-voltage vdd-logic-npu-vepu: Fixed regulator specified with variable voltages
[    0.117375] reg-fixed-voltage: probe of vdd-logic-npu-vepu failed with error -22
[    0.118485] rk_iommu ffb00f00.iommu: version = 1
[    0.119125] rk_iommu ffb20800.iommu: version = 1
[    0.119592] rk_iommu ffb60e00.iommu: version = 1
[    0.120236] rk_iommu ffb80480.iommu: version = 1
[    0.120790] rk_iommu ffb90800.iommu: version = 1
[    0.121278] rk_iommu ffbb0f00.iommu: version = 1
[    0.122355] SCSI subsystem initialized
[    0.122685] usbcore: registered new interface driver usbfs
[    0.122778] usbcore: registered new interface driver hub
[    0.122982] usbcore: registered new device driver usb
[    0.123106] media: Linux media interface: v0.10
[    0.123177] videodev: Linux video capture interface: v2.00
[    0.123247] pps_core: LinuxPPS API ver. 1 registered
[    0.123269] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.123313] PTP clock support registered
[    0.125405] Bluetooth: Core ver 2.22
[    0.125496] NET: Registered protocol family 31
[    0.125520] Bluetooth: HCI device and connection manager initialized
[    0.125549] Bluetooth: HCI socket layer initialized
[    0.125575] Bluetooth: L2CAP socket layer initialized
[    0.125635] Bluetooth: SCO socket layer initialized
[    0.126174] rockchip-cpuinfo cpuinfo: SoC            : 11260000
[    0.126208] rockchip-cpuinfo cpuinfo: Serial         : 04a143fbbeca61df
[    0.127141] clocksource: Switched to clocksource arch_sys_counter
[    0.140984] NET: Registered protocol family 2
[    0.141863] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.141932] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.142090] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.142294] TCP: Hash tables configured (established 8192 bind 8192)
[    0.142454] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.142528] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.142765] NET: Registered protocol family 1
[    0.144733] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.147545] Initialise system trusted keyrings
[    0.147802] workingset: timestamp_bits=29 max_order=19 bucket_order=0
[    0.155234] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.158064] Key type asymmetric registered
[    0.158097] Asymmetric key parser 'x509' registered
[    0.158173] bounce: pool size: 64 pages
[    0.158240] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.158267] io scheduler noop registered
[    0.158288] io scheduler deadline registered
[    0.158465] io scheduler cfq registered (default)
[    0.158493] io scheduler mq-deadline registered
[    0.158514] io scheduler kyber registered
[    0.158668] io scheduler bfq registered
[    0.162902] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
[    0.168746] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.168878] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.169288] mpp_service mpp-srv: 4a6b4c5b4 author: sun fan 2023-09-09 version 1.0
[    0.169313] mpp_service mpp-srv: probe start
[    0.170342] iommu: Adding device ffb80000.rkvdec to group 3
[    0.170399] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[    0.170657] mpp_rkvdec ffb80000.rkvdec: probing start
[    0.171297] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[    0.171329] rkvdec_init:1190: No niu aclk reset resource define
[    0.171359] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[    0.171380] rkvdec_init:1193: No niu hclk reset resource define
[    0.171702] mpp_rkvdec ffb80000.rkvdec: probing finish
[    0.172490] iommu: Adding device ffbb0000.rkvenc to group 5
[    0.172551] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[    0.172843] mpp_rkvenc ffbb0000.rkvenc: probing start
[    0.173551] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.7
[    0.173628] mpp_rkvenc ffbb0000.rkvenc: bin=0
[    0.173683] mpp_rkvenc ffbb0000.rkvenc: leakage=2.625
[    0.173759] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[    0.173867] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[    0.174436] mpp_rkvenc ffbb0000.rkvenc: avs=0
[    0.174828] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[    0.174866] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[    0.175502] mpp_rkvenc ffbb0000.rkvenc: probing finish
[    0.176263] iommu: Adding device ffb90400.vdpu to group 4
[    0.176320] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[    0.176432] mpp_vdpu2 ffb90400.vdpu: probe device
[    0.176974] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177023] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177284] mpp_vdpu2 ffb90400.vdpu: probing finish
[    0.177935] iommu: Adding device ffb90000.vepu to group 4
[    0.177990] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[    0.178113] mpp_vepu2 ffb90000.vepu: probe device
[    0.178614] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178655] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178912] mpp_vepu2 ffb90000.vepu: probing finish
[    0.179447] iommu: Adding device ffb20000.iep to group 1
[    0.179503] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[    0.179632] mpp-iep2 ffb20000.iep: probe device
[    0.180293] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[    0.180576] mpp-iep2 ffb20000.iep: probing finish
[    0.180850] mpp_service mpp-srv: probe success
[    0.186024] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.186056] dma-pl330 ff4e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.188145] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.189075] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.190089] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 32, base_baud = 1500000) is a 16550A
[    0.191138] ff590000.serial: ttyS4 at MMIO 0xff590000 (irq = 33, base_baud = 1500000) is a 16550A
[    0.191919] ff5a0000.serial: ttyS5 at MMIO 0xff5a0000 (irq = 34, base_baud = 1500000) is a 16550A
[    0.193913] rockchip_drm_init----------------000--------------
[    0.194043] random: fast init done
[    0.194450] random: crng init done
[    0.195000] iommu: Adding device ffb00000.vop to group 0
[    0.195059] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[    0.195148] clk: failed to reparent dclk_vop to cpll: -22
[    0.198311] rockchip_drm_init----------------001--------------
[    0.198392] rockchip_drm_platform_probe----------------001--------------
[    0.198436] rockchip_drm_platform_probe----------------002--------------
[    0.199348] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[    0.200448] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[    0.201674] rockchip_drm_platform_probe----------------003--------------
[    0.201706] rockchip_drm_bind----------------011--------------
[    0.201891] rockchip-drm display-subsystem: devfreq is not set
[    0.202380] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.202412] dw_mipi_dsi_bind----------------00--------------
[    0.202416] dw_mipi_dsi_bind----------------01--------------
[    0.202441] dw_mipi_dsi_bind----------------02--------------
[    0.202478] drm_of_find_panel_or_bridge  panel is null
[    0.202511] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
[    0.202555] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb09439ac): -517
[    0.202823] rockchip-drm display-subsystem: master bind failed: -517
[    0.203175] rockchip_drm_init----------------002--------------
[    0.208006] panel_simple_dsi_probe dsi_id =-19
[    0.208034] panel_simple_dsi_probe node--name =dsi@ffb30000
[    0.208092] drm_display_mode_from_videomode------------------------------148
[    0.208120] panel_simple_dsi_probe----------------0002--------------
[    0.208181] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply power not found, using dummy regulator
[    0.208304] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[    0.208353] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[    0.208481] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[    0.209735] zram: Added device: zram0
[    0.211821] libphy: Fixed MDIO Bus: probed
[    0.213122] PPP generic driver version 2.4.2
[    0.213351] PPP BSD Compression module registered
[    0.213378] PPP Deflate Compression module registered
[    0.213412] PPP MPPE Compression module registered
[    0.213435] NET: Registered protocol family 24
[    0.213560] usbcore: registered new interface driver asix
[    0.213647] usbcore: registered new interface driver ax88179_178a
[    0.213719] usbcore: registered new interface driver cdc_ether
[    0.213833] usbcore: registered new interface driver net1080
[    0.213912] usbcore: registered new interface driver cdc_subset
[    0.213982] usbcore: registered new interface driver zaurus
[    0.214080] usbcore: registered new interface driver cdc_ncm
[    0.215739] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[    0.221341] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.221380] ehci-platform: EHCI generic platform driver
[    0.224981] ehci-platform ffe00000.usb: EHCI Host Controller
[    0.225049] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[    0.225252] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[    0.237208] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[    0.237511] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.237558] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.237583] usb usb1: Product: EHCI Host Controller
[    0.237607] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[    0.237630] usb usb1: SerialNumber: ffe00000.usb
[    0.238414] hub 1-0:1.0: USB hub found
[    0.238489] hub 1-0:1.0: 1 port detected
[    0.239220] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.239264] ohci-platform: OHCI generic platform driver
[    0.239815] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[    0.239874] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[    0.240060] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[    0.298221] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.298257] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.298276] usb usb2: Product: Generic Platform OHCI controller
[    0.298296] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[    0.298335] usb usb2: SerialNumber: ffe10000.usb
[    0.299085] hub 2-0:1.0: USB hub found
[    0.299164] hub 2-0:1.0: 1 port detected
[    0.300906] usbcore: registered new interface driver cdc_acm
[    0.300938] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.301081] usbcore: registered new interface driver usb-storage
[    0.301236] usbcore: registered new interface driver option
[    0.301298] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.302444] i2c /dev entries driver
[    0.305664] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.305941] rtc-pcf8563 0-0051: registered as rtc0
[    0.307166] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.307197] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[    0.311719] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[    0.313077] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[    0.313129] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[    0.313262] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[    0.313370] rkcif rkcif_dvp: attach to cif hw node
[    0.313392] rkcif rkcif_dvp: rkcif wait line 0
[    0.313433] RKCIF_WORKMODE_PINGPONG
[    0.314972] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[    0.315074] rkcif rkcif_mipi_lvds: attach to cif hw node
[    0.315098] rkcif rkcif_mipi_lvds: rkcif wait line 0
[    0.315128] RKCIF_WORKMODE_PINGPONG
[    0.316160] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[    0.316194] rockchip-mipi-csi2: Async registered subdev
[    0.318576] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[    0.318616] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[    0.318938] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[    0.318986] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[    0.319307] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[    0.319546] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    0.319787] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.319831] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.319863] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.322918] rkisp rkisp-vir1: rkisp driver version: v01.06.02
[    0.323173] rkisp rkisp-vir1: No memory-region-thunderboot specified
[    0.323399] rkisp rkisp-vir1: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.323440] rkisp rkisp-vir1: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.323473] rkisp rkisp-vir1: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.327197] iommu: Adding device ffb60000.rkispp to group 2
[    0.327261] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[    0.327677] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[    0.327727] rkispp_hw ffb60000.rkispp: can't request region for resource [mem 0xffb60000-0xffb7ffff]
[    0.327980] rkispp_hw ffb60000.rkispp: failed to get cru reset
[    0.328286] rkispp rkispp-vir0: rkispp driver version: v01.06.02
[    0.330705] rkispp rkispp-vir1: rkispp driver version: v01.06.02
[    0.333447] usbcore: registered new interface driver uvcvideo
[    0.333482] USB Video Class driver (1.1.1)
[    0.334009] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.3
[    0.334062] rockchip-iodomain fe020000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    0.334208] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[    0.334322] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    0.334438] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.5
[    0.334482] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc3v3_sys
[    0.334624] rockchip-iodomain fe020000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    0.334746] rockchip-iodomain fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vcc_1v8
[    0.334872] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(1800000 uV) supplied by vcc_1v8
[    0.335018] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[    0.337858] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -7
[    0.338211] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[    0.338691] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -7
[    0.338958] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[    0.340409] Bluetooth: HCI UART driver ver 2.3
[    0.340447] Bluetooth: HCI UART protocol H4 registered
[    0.341639] cpu cpu0: bin=0
[    0.341698] cpu cpu0: leakage=3.375
[    0.341753] cpu cpu0: Failed to get reg
[    0.341791] cpu cpu0: bin-scale=5
[    0.342113] cpuidle: enable-method property 'psci' found operations
[    0.342297] cpuidle: enable-method property 'psci' found operations
[    0.342460] cpuidle: enable-method property 'psci' found operations
[    0.342611] cpuidle: enable-method property 'psci' found operations
[    0.343336] Synopsys Designware Multimedia Card Interface Driver
[    0.344329] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[    0.344403] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[    0.344440] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[    0.344544] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    0.344764] mmc_host mmc0: card is non-removable.
[    0.357804] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.371618] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[    0.371723] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[    0.371752] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[    0.371850] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    0.372073] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.6
[    0.372208] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.3
[    0.408899] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[    0.408970] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[    0.413266] mmc0: new HS200 MMC card at address 0001
[    0.416864] mmcblk0: mmc0:0001 DA4064 58.2 GiB
[    0.418257] mmcblk0boot0: mmc0:0001 DA4064 partition 1 4.00 MiB
[    0.419577] mmcblk0boot1: mmc0:0001 DA4064 partition 2 4.00 MiB
[    0.420720] mmcblk0rpmb: mmc0:0001 DA4064 partition 3 16.0 MiB, chardev (242:0)
[    0.435185]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    0.490195] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.503892] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.503990] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.504027] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.504258] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.505581] usbcore: registered new interface driver usbhid
[    0.505618] usbhid: USB HID core driver
[    0.508382] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.3
[    0.510302] rksfc_base v1.1 2016-01-08
[    0.511046] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[    0.511151] rkflash_dev_init enter
[    0.511184] sfc nor id: 0 0 0
[    0.511205] rkflash[1] is invalid
[    0.511209] rkflash_dev_init enter
[    0.511246] sfc_nand id: 0 0 0
[    0.511265] rkflash[2] is invalid
[    0.511834] NET: Registered protocol family 17
[    0.511909] NET: Registered protocol family 15
[    0.513630] Bluetooth: RFCOMM TTY layer initialized
[    0.513694] Bluetooth: RFCOMM socket layer initialized
[    0.513764] Bluetooth: RFCOMM ver 1.11
[    0.513849] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    0.513903] Bluetooth: HIDP socket layer initialized
[    0.513937] [BT_RFKILL]: Enter rfkill_rk_init
[    0.513960] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    0.514458] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    0.514610] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = USB-WiFi
[    0.514630] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    0.514646] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    0.514714] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 16 flags = 0.
[    0.514800] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    0.514822] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    0.514885] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    0.517369] flash vendor_init_thread!
[    0.517418] flash vendor storage:20170308 ret = -1
[    0.518612] gc2145 1-003c: driver version: 00.01.06
[    0.518663] gc2145_probe---------------00000---------------
[    0.518698] gc2145_probe---------------11111---------------
[    0.518756] gc2145_probe---------------22222---------------
[    0.518781] gc2145_probe---------------222221---------------
[    0.518802] gc2145_probe---------------2222211---------------
[    0.518817] fps =25
[    0.518848] gc2145_probe---------------33333---------------
[    0.518881] m01_b_gc2145 1-003c: Async registered subdev
[    0.518924] rkcif rkcif_dvp: Entity type for entity rkcif-dvp-sof was not initialized!
[    0.520245] ----------i=5
[    0.520299] ----------i=5
[    0.520364] ----------i=5
[    0.520406] ----------i=5
[    0.520430] rkcif_dvp: Async subdev notifier completed
[    0.520566] gc2145_probe---------------44444---------------
[    0.520586] gc2145 1-003c: m01_b_gc2145 1-003c sensor driver registered !!
[    0.521176] sc2210 1-0030: driver version: 00.01.06
[    0.521260] sc2210 1-0030:  Get hdr mode failed! no hdr default
[    0.521721] sc2210 1-0030: could not get sleep pinstate
[    0.522005] sc2210 1-0030: Linked as a consumer to regulator.2
[    0.522194] sc2210 1-0030: Linked as a consumer to regulator.3
[    0.522375] sc2210 1-0030: Linked as a consumer to regulator.4
[    0.522492] sc2210_initialize_controls---------------11111---------------0
[    0.522504] sc2210_initialize_controls---------------11111---------------0 74250000
[    0.529292] sc2210 1-0030: gain_mode 0b02
[    0.529349] sc2210 1-0030: Detected SC2210 sensor
[    0.529528] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: match m00_f_sc2210 1-0030:bus type 4
[    0.529555] sc2210_probe---------------11111---------------hdr_mode0
[    0.529597] sc2210_runtime_suspend---------------11111---------------
[    0.530349] Registering SWP/SWPB emulation handler
[    0.535405] Loading compiled-in X.509 certificates
[    0.537742] rga2: Driver loaded successfully ver:3.2.56726
[    0.538454] rga2: Module initialized.
[    0.563605] vendor storage:20190527 ret = 0
[    0.587514] rockchip_drm_platform_probe----------------001--------------
[    0.587535] rockchip_drm_platform_probe----------------002--------------
[    0.591131] rockchip_drm_platform_probe----------------003--------------
[    0.591241] rockchip_drm_bind----------------011--------------
[    0.591433] rockchip-drm display-subsystem: devfreq is not set
[    0.591952] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.591982] dw_mipi_dsi_bind----------------00--------------
[    0.591987] dw_mipi_dsi_bind----------------01--------------
[    0.592011] dw_mipi_dsi_bind----------------02--------------
[    0.592051] drm_of_find_panel_or_bridge  panel ret =0
[    0.592066] dw_mipi_dsi_bind----------------03--------------
[    0.592100] dw_mipi_dsi_bind----------------04--------------
[    0.592128] dw_mipi_dsi_bind----------------05--------------
[    0.592166] dw_mipi_dsi_bind----------------06--------------
[    0.592196] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb09439ac)
[    0.592232] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.592252] [drm] No driver support for vblank timestamp query.
[    0.592373] rockchip_drm_bind----------------010--------------
[    0.592377] show_loader_logo----------------011--------------
[    0.592587] setup_initial_state----------------encoder_funcs->loader_protect--------------
[    0.592622] dw_mipi_dsi_encoder_loader_protect----------------dw_mipi_dsi_encoder_loader_protect--------------21e85335
[    0.592644] panel_simple_loader_protect: on = 1!
[    0.592680] panel_simple_loader_protect----------------panel_simple_loader_protect--------------21e85335 1
[    0.592853] show_loader_logo----------------012--------------
[    0.623556] rockchip-drm display-subsystem: fb0:  frame buffer device
[    0.626019] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    0.626079] rockchip_drm_platform_probe----------------004--------------
[    0.626761] input: adc-keys as /devices/platform/adc-keys/input/input0
[    0.629731] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.629819] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.629848] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.629918] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.632091] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.632180] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.632220] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.632283] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.634355] rkcif rkcif_dvp: clear unready subdev num: 0
[    0.634444] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[    0.634471] rockchip-mipi-csi2: No link between dphy and sensor
[    0.635543] rockchip-mipi-csi2: No link between dphy and sensor
[    0.635605] rkcif_mipi_lvds: Async subdev notifier completed
[    0.636408] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    0.643020] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    0.643281] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    0.643310] cfg80211: failed to load regulatory.db
[    0.645164] rkisp rkisp-vir0: clear unready subdev num: 1
[    0.646401] rockchip-mipi-csi2: No link between dphy and sensor
[    0.646447] rockchip-mipi-csi2: No link between dphy and sensor
[    0.646473] rkisp0: Invalid mipi data type
[    0.646494] rkisp0: update sensor failed
[    0.646527] rkisp rkisp-vir1: clear unready subdev num: 1
[    0.648465] rkisp1: Async subdev notifier completed
[    0.656825] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[    0.656871] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[    0.673510] EXT4-fs (mmcblk0p6): recovery complete
[    0.676516] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    0.676622] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    0.681266] devtmpfs: mounted
[    0.683395] Freeing unused kernel memory: 1024K
[    0.683888] Run /sbin/init as init process
[    0.782878] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[    1.0057" ▒DDR Version V1.08 20210825
DDR4, 328MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc6ee75eec1-210728 #zzz (Sep 13 2021 - 10:36:14)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC error: The cmd index is 1, ret is -110
mmc_init: -95, time 9
Trying to boot from MMC1
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
## Verified-boot: 0
## Checking optee 0x08400000 (gzip @0x08600000) ... sha256(7beb6b43df...) + sha256(bae962097a...) + OK
## Checking uboot 0x00600000 (gzip @0x00800000) ... sha256(a79b29d8d6...) + sha256(b07be23f78...) + OK
## Checking fdt 0x006bd070 ... sha256(a362d022de...) + OK
Jumping to U-Boot(0x00600000) via OP-TEE(0x08400000)
Total: 128.869 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
I/TC: Next entry point address: 0x00600000
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #zhangzj (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug  4 03:30:34 UTC 2021 arm
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
U-Boot 2017.09 (May 07 2024 - 03:53:30 -0700)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM:  2 GiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 7bbf9e50 - 7bbfede0
CR: M/C/I
device_node_name:adc-keys
device_node_name:dwmmc
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
fdt_addr_r = 8300000
resource_is_empty fun:resource_is_empty line:456
test--------------------
test-33333--------------line:479
test-33333--------------line:502
test-33333--------------line:516
---------------size =12631552, offset =6317568, dev_desc->blksz = 512
data =7bdd58c0
test444444---------------276
test444444---------------279
test444444---------------281
test444444---part->start =8000--blk_off =3036----blk_num =24671------282
__fit_image_load_one 283   7bdd58c0
52 53 43 45 00 00 00 00 01 01 01 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
test444444---------------339
test-33333--------------line:522
test-33333--------------line:529
FIT: no signed, no conf required
func:resource_traverse_init_list line:717
DTB: --------1-------<NULL>
[HW-ADC]: rv1126-xygd-1080p#_saradc_ch4=0.dtb
lcd adc_record[4] = 0,adc_record[4]= 0
adc_val =0.dtb
dtb_adc = 0
   - dev=saradc, channel=4, dtb_adc=0, read=0, found=1
cell_name =<NULL>
DTB: --------2-------rv1126-xygd-1080p#_saradc_ch4=0.dtb
len = 0
len = 92766
file->ram = 1
file->rsce_base = 7bdd58c0
file->f_size = 92766
file->name =rv1126-xygd-1080p#_saradc_ch4=0.dtb
file->f_offset = 187, offset = 0, dev_desc->blksz = 512
src = 7bdecec0
d0 0d fe ed 00 01 6a 5e 00 00 00 38 00 01 34 c8 00 00 00 28
p = 08300000
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
end--
src = 7bdecec0
p = 08300000
1---end--
end--
----end--
DTB: rv1126-xygd-1080p#_saradc_ch4=0.dtb
device_node_name:crypto
HASH(c): OK
device_node_name:saradc
device_node_name:ethernet
device_node_name:gpio1
device_node_name:gpio3
device_node_name:i2c
device_node_name:decompress
device_node_name:nandc
device_node_name:usb0
device_node_name:usb2-phy
device_node_name:serial
device_node_name:sfc
device_node_name:dwc3
device_node_name:phy
device_node_name:volumeup-key
device_node_name:menu-key
device_node_name:amba
device_node_name:clock-controller
io-domain: OK
rockchip_display_probe node.np->name = route-dsi
rockchip_display_probe: panel_i2c_busnum = 3
lt9211_is_connected  lt9211 connect = 0
find connect node's handle 16
find ep_node /vop@ffb00000/port/endpoint@1
find port_node /vop@ffb00000/port
find port_parent_node /vop@ffb00000
load_mipi2lvds_driver: lt9211@2d
I2c3 speed: 400000Hz
lt9211_parse_dt mipi-format=2 mipi-bpp=24 test-pattern=false
lt9211_ConvertBoard_power_off
lt9211_ConvertBoard_power_on
lt9211_chip_shutdown
lt9211_chip_enable
id: 0x21 0x03 0xe0
lt9211_detect successful
lt9211_probe : lt9211 is connected!
lt9211_probe -
load_mipi2lvds_driver: lt9211@2d : ret=0
lt9211_is_connected  lt9211 connect = 1
panel_simple_dsi_of_get_desc_data t1=1 t2=500 t3=200 t4=1 t5=1000
test:-------------------------------2362
test:2364 dsi@ffb30000.0
Can't get crtc id, default set to id = 0
Could not find baseparameter partition
Model: Rockchip RV1126 38x38 V10 EMMC DDR3 Board
len = 512
len = 512
file->ram = 1
file->f_size = 6220854
file->f_offset = 369, offset = 0, dev_desc->blksz = 512
src = 7be03ac0
42 4d 36 ec 5e 00 cf 20 00 00 36 00 00 00 28 00 00 00 80 07
p = 7ca0a298
end--
src = 7be03ac0
p = 7ca0a298
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7be03ac0
p = 7df00000
end--
src = 7be03ac0
p = 7df00000
1---end--
end--
----end--
Rockchip UBOOT DRM driver version: v1.0.1
test 857
test 863
test 866
test 892
test 894
test:541
timing = display-timings
lt9211_set_videomode - clk: 148500000 hact: 1920 hfp: 88 hs: 44 hbp: 148 vact: 1080  vfp: 4 vs: 5 vbp: 36
display_get_timing_from_dts hactive = 1920 vactive = 1080 pixelclock = 148500 flags =0xa
Using display timing dts
test 896
test 932
test 937
dsi@ffb30000:  detailed mode clock 148500 kHz, flags[a]
    H: 1920 2008 2052 2200
    V: 1080 1084 1089 1125
bus_format: 100e
final DSI-Link bandwidth: 990 Mbps x 4
in panel_simple_prepare 1
in panel_simple_prepare 2
lt9211_bridge_enable
lt9211_chip_enable
lt9211_init_seq
[INFO ] MIPI Input PortA
[INFO ] Mipi DSI Input
[INFO ] hact = 1920
[INFO ] vact = 1080
[INFO ] fmt = 0x0a
[INFO ] MipiRx Input Format: RGB 8Bit
[INFO ] ---------test, line:380
[INFO ] ---------test, line:386
-----ulRtn = 74247
[INFO ] Tx Pll Lock
[INFO ] MIPI Output PortA & B
-----ulRtn = 125000
[INFO ] MipiTx Output Format: RGB 8bit
Start initial panel
cmd_list set 0x25 , mdelay(100).
cmd_list set 0x26 , mdelay(100).
cmd_list set 0x11 , mdelay(100).
cmd_list set 0x29 , mdelay(100).
cmd_list set 0xCD , mdelay(100).
Finish initial panel
[INFO ] Mipi DSI Out
[exit:]lt9211_init_seq
panel_simple_enable
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 462000 KHz
  gpll 1188000 KHz
  cpll 500000 KHz
  hpll 1400000 KHz
  aclk_pdbus 500000 KHz
  hclk_pdbus 198000 KHz
  pclk_pdbus 99000 KHz
  aclk_pdphp 297000 KHz
  hclk_pdphp 198000 KHz
  hclk_pdaudio 148500 KHz
  hclk_pdcore 198000 KHz
  pclk_pdpmu 99000 KHz
Net:   device_node_name:ethernet
eth0: ethernet@ffc40000
Hit key to stop autoboot('CTRL+C'):  0
## Booting FIT Image at 0x7b3f0240 with size 0x00606c00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 7b3f0240 ...
   Using 'conf' configuration
optee api revision: 2.0
TEEC: Waring: Could not find security partition
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x7b407640
     Data Size:    6223864 Bytes = 5.9 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x02008000
     Entry Point:  0x02008000
     Hash algo:    sha256
     Hash value:   eb3b3ea53c676c4c5e85d576bdf7d302ddb74187aeba2c3afd56337b087cb0fa
   Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 7b3f0240 ...
   Trying 'fdt' fdt subimage
     Data Start:   0x7b3f0a40
     Data Size:    92766 Bytes = 90.6 KiB
     Architecture: ARM
     Load Address: 0x08300000
     Hash algo:    sha256
     Hash value:   dfd9f487ab1061510e53e2bcc4af8add91318a8c74e8e0b32cc878b246e31b3c
   Loading fdt from 0x08300000 to 0x08300000
   Booting using the fdt blob at 0x08300000
--Debug-Load the OS---func:do_bootm_states, line: 722
-----BOOT LOAD OS Line:526
   Loading Kernel Image from 0x7b407640 to 0x02008000 ... -------------comp: 0
------Line: 430
---------------to : 02008000, from :7b407640, len =6223864
testttt 568
------Line: 432
OK
-----BOOT LOAD OS END Line:530
   kernel loaded at 0x02008000, end = 0x025f77f8
--Debug-Load the OS-end----func:do_bootm_states, line: 738
  'reserved-memory' ramoops@8000000: addr=8000000 size=100000
--Debug----func:do_bootm_states, line: 764
   Using Device Tree in place at 08300000, end 08319a5d
len = 512
len = 512
file->ram = 1
file->f_offset = 12520, offset = 0, dev_desc->blksz = 512
src = 7c3f28c0
p = 7ca0df60
end--
src = 7c3f28c0
p = 7ca0df60
1---end--
end--
----end--
len = 6220854
len = 6220854
file->ram = 1
src = 7c3f28c0
p = 7e4ef000
end--
src = 7c3f28c0
p = 7e4ef000
1---end--
end--
----end--
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x80000000 (size: 0x779b8000)
Total: 3533.163 ms
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Linux version 4.19.111 (kingsun@ubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #110 SMP PREEMPT Sun Apr 28 04:42:10 PDT 2024
[    0.000000] OF: fdt: Machine model: Rockchip RV1126 38x38 V10 EMMC DDR3 Board
[    0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x7f800000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x5dc00000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522376
[    0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 snd_aloop.index=7
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1518464K/2094816K available (8192K kernel code, 391K rwdata, 1960K rodata, 1024K init, 276K bss, 43872K reserved, 532480K cma-reserved, 872584K highmem)
[    0.000000]     vmalloc : 0xda000000 - 0xff800000   ( 600 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xd9800000   ( 664 MB)
[    0.000000]     pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
[    0.000000]     modules : 0xaf000000 - 0xafe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 392 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 277 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000760] Switching to timer-based delay loop, resolution 41ns
[    0.002596] Console: colour dummy device 80x30
[    0.003068] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.004027] pid_max: default: 4096 minimum: 301
[    0.004628] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.005256] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.006654] CPU: Testing write buffer coherency: ok
[    0.007477] /cpus/cpu@f00 missing clock-frequency property
[    0.008003] /cpus/cpu@f01 missing clock-frequency property
[    0.008526] /cpus/cpu@f02 missing clock-frequency property
[    0.009050] /cpus/cpu@f03 missing clock-frequency property
[    0.009612] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.010875] Setting up static identity map for 0x100000 - 0x100060
[    0.011629] rcu: Hierarchical SRCU implementation.
[    0.012724] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.014754] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.016435] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.018090] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.018225] smp: Brought up 1 node, 4 CPUs
[    0.020236] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.020820] CPU: All CPU(s) started in SVC mode.
[    0.022260] devtmpfs: initialized
[    0.046423] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.047821] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.048738] futex hash table entries: 16 (order: -2, 1024 bytes)
[    0.049543] pinctrl core: initialized pinctrl subsystem
[    0.051287] NET: Registered protocol family 16
[    0.052390] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.055192] cpuidle: using governor menu
[    0.055593] Registered FIQ tty driver
[    0.056506] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.057252] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.059991] console [pstore-1] enabled
[    0.060593] pstore: Registered ramoops as persistent store backend
[    0.061178] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[    0.108958] cryptd: max_cpu_qlen set to 1000
[    0.110239] fiq debugger fiq mode enabled
[[    0.111033] console [ttyFIQ0] enabled
[    0.111717] bootconsole [uart8250] disabled
[    0.112427] Registered fiq debugger ttyFIQ0
[    0.113085] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    0.116669] vcc_sd: supplied by vcc3v3_sys
[    0.117172] reg-fixed-voltage vdd-arm: Fixed regulator specified with variable voltages
[    0.117225] reg-fixed-voltage: probe of vdd-arm failed with error -22
[    0.117336] reg-fixed-voltage vdd-logic-npu-vepu: Fixed regulator specified with variable voltages
[    0.117379] reg-fixed-voltage: probe of vdd-logic-npu-vepu failed with error -22
[    0.118486] rk_iommu ffb00f00.iommu: version = 1
[    0.119130] rk_iommu ffb20800.iommu: version = 1
[    0.119599] rk_iommu ffb60e00.iommu: version = 1
[    0.120780] rk_iommu ffb90800.iommu: version = 1
[    0.121263] rk_iommu ffbb0f00.iommu: version = 1
[    0.122336] SCSI subsystem initialized
[    0.122664] usbcore: registered new interface driver usbfs
[    0.122758] usbcore: registered new interface driver hub
[    0.122935] usbcore: registered new device driver usb
[    0.123055] media: Linux media interface: v0.10
[    0.123127] videodev: Linux video capture interface: v2.00
[    0.123197] pps_core: LinuxPPS API ver. 1 registered
[    0.123220] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.123263] PTP clock support registered
[    0.125256] Bluetooth: Core ver 2.22
[    0.125346] NET: Registered protocol family 31
[    0.125372] Bluetooth: HCI device and connection manager initialized
[    0.125401] Bluetooth: HCI socket layer initialized
[    0.125427] Bluetooth: L2CAP socket layer initialized
[    0.125486] Bluetooth: SCO socket layer initialized
[    0.126014] rockchip-cpuinfo cpuinfo: SoC            : 11260000
[    0.126050] rockchip-cpuinfo cpuinfo: Serial         : 04a143fbbeca61df
[    0.127013] clocksource: Switched to clocksource arch_sys_counter
[    0.141033] NET: Registered protocol family 2
[    0.142017] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.142083] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.142240] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.142442] TCP: Hash tables configured (established 8192 bind 8192)
[    0.142619] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.142696] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.142935] NET: Registered protocol family 1
[    0.144852] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.147673] Initialise system trusted keyrings
[    0.147930] workingset: timestamp_bits=29 max_order=19 bucket_order=0
[    0.155343] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.158173] Key type asymmetric registered
[    0.158206] Asymmetric key parser 'x509' registered
[    0.158282] bounce: pool size: 64 pages
[    0.158351] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.158377] io scheduler noop registered
[    0.158398] io scheduler deadline registered
[    0.158573] io scheduler cfq registered (default)
[    0.158602] io scheduler mq-deadline registered
[    0.158624] io scheduler kyber registered
[    0.158786] io scheduler bfq registered
[    0.162979] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
[    0.168839] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.168996] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.169392] mpp_service mpp-srv: 4a6b4c5b4 author: sun fan 2023-09-09 version 1.0
[    0.169417] mpp_service mpp-srv: probe start
[    0.170479] iommu: Adding device ffb80000.rkvdec to group 3
[    0.170534] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[    0.170734] mpp_rkvdec ffb80000.rkvdec: probing start
[    0.171355] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[    0.171380] rkvdec_init:1190: No niu aclk reset resource define
[    0.171415] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[    0.171437] rkvdec_init:1193: No niu hclk reset resource define
[    0.171761] mpp_rkvdec ffb80000.rkvdec: probing finish
[    0.172559] iommu: Adding device ffbb0000.rkvenc to group 5
[    0.172618] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[    0.172913] mpp_rkvenc ffbb0000.rkvenc: probing start
[    0.173601] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.7
[    0.173727] mpp_rkvenc ffbb0000.rkvenc: bin=0
[    0.173792] mpp_rkvenc ffbb0000.rkvenc: leakage=2.625
[    0.173879] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[    0.173930] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[    0.174493] mpp_rkvenc ffbb0000.rkvenc: avs=0
[    0.174885] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[    0.174922] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[    0.175547] mpp_rkvenc ffbb0000.rkvenc: probing finish
[    0.176295] iommu: Adding device ffb90400.vdpu to group 4
[    0.176345] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[    0.176461] mpp_vdpu2 ffb90400.vdpu: probe device
[    0.177092] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177141] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.177389] mpp_vdpu2 ffb90400.vdpu: probing finish
[    0.178041] iommu: Adding device ffb90000.vepu to group 4
[    0.178097] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[    0.178220] mpp_vepu2 ffb90000.vepu: probe device
[    0.178712] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.178753] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.179019] mpp_vepu2 ffb90000.vepu: probing finish
[    0.179569] iommu: Adding device ffb20000.iep to group 1
[    0.179624] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[    0.179737] mpp-iep2 ffb20000.iep: probe device
[    0.180469] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[    0.180672] mpp-iep2 ffb20000.iep: probing finish
[    0.180963] mpp_service mpp-srv: probe success
[    0.186111] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.186153] dma-pl330 ff4e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.188263] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.189179] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.190196] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 32, base_baud = 1500000) is a 16550A
[    0.191207] ff590000.serial: ttyS4 at MMIO 0xff590000 (irq = 33, base_baud = 1500000) is a 16550A
[    0.191969] ff5a0000.serial: ttyS5 at MMIO 0xff5a0000 (irq = 34, base_baud = 1500000) is a 16550A
[    0.193958] rockchip_drm_init----------------000--------------
[    0.194103] random: fast init done
[    0.194506] random: crng init done
[    0.195064] iommu: Adding device ffb00000.vop to group 0
[    0.195123] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[    0.195214] clk: failed to reparent dclk_vop to cpll: -22
[    0.198406] rockchip_drm_init----------------001--------------
[    0.198499] rockchip_drm_platform_probe----------------001--------------
[    0.198542] rockchip_drm_platform_probe----------------002--------------
[    0.199454] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[    0.200614] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[    0.201811] rockchip_drm_platform_probe----------------003--------------
[    0.201843] rockchip_drm_bind----------------011--------------
[    0.202043] rockchip-drm display-subsystem: devfreq is not set
[    0.202521] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.202555] dw_mipi_dsi_bind----------------00--------------
[    0.202559] dw_mipi_dsi_bind----------------01--------------
[    0.202584] dw_mipi_dsi_bind----------------02--------------
[    0.202624] drm_of_find_panel_or_bridge  panel is null
[    0.202663] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
[    0.202707] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb09439ac): -517
[    0.202971] rockchip-drm display-subsystem: master bind failed: -517
[    0.203322] rockchip_drm_init----------------002--------------
[    0.208192] panel_simple_dsi_probe dsi_id =-19
[    0.208241] panel_simple_dsi_probe node--name =dsi@ffb30000
[    0.208300] drm_display_mode_from_videomode------------------------------148
[    0.208326] panel_simple_dsi_probe----------------0002--------------
[    0.208390] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply power not found, using dummy regulator
[    0.208507] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[    0.208552] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[    0.208652] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[    0.209919] zram: Added device: zram0
[    0.211983] libphy: Fixed MDIO Bus: probed
[    0.213288] PPP generic driver version 2.4.2
[    0.213530] PPP BSD Compression module registered
[    0.213559] PPP Deflate Compression module registered
[    0.213599] PPP MPPE Compression module registered
[    0.213617] NET: Registered protocol family 24
[    0.213784] usbcore: registered new interface driver asix
[    0.213873] usbcore: registered new interface driver ax88179_178a
[    0.213945] usbcore: registered new interface driver cdc_ether
[    0.214016] usbcore: registered new interface driver net1080
[    0.214085] usbcore: registered new interface driver cdc_subset
[    0.214147] usbcore: registered new interface driver zaurus
[    0.214251] usbcore: registered new interface driver cdc_ncm
[    0.215914] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[    0.221514] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.221551] ehci-platform: EHCI generic platform driver
[    0.225154] ehci-platform ffe00000.usb: EHCI Host Controller
[    0.225220] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[    0.225433] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[    0.237081] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[    0.237371] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.237398] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.237425] usb usb1: Product: EHCI Host Controller
[    0.237449] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[    0.237472] usb usb1: SerialNumber: ffe00000.usb
[    0.238231] hub 1-0:1.0: USB hub found
[    0.238305] hub 1-0:1.0: 1 port detected
[    0.239043] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.239091] ohci-platform: OHCI generic platform driver
[    0.239649] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[    0.239710] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[    0.239912] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[    0.298099] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.298136] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.298155] usb usb2: Product: Generic Platform OHCI controller
[    0.298176] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[    0.298215] usb usb2: SerialNumber: ffe10000.usb
[    0.298971] hub 2-0:1.0: USB hub found
[    0.299044] hub 2-0:1.0: 1 port detected
[    0.300779] usbcore: registered new interface driver cdc_acm
[    0.300811] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.300954] usbcore: registered new interface driver usb-storage
[    0.301122] usbcore: registered new interface driver option
[    0.301183] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.302293] i2c /dev entries driver
[    0.305539] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.305808] rtc-pcf8563 0-0051: registered as rtc0
[    0.307039] rtc-pcf8563 0-0051: low voltage detected, date/time is not reliable.
[    0.307072] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[    0.311616] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[    0.312984] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[    0.313036] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[    0.313187] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[    0.313292] rkcif rkcif_dvp: attach to cif hw node
[    0.313324] rkcif rkcif_dvp: rkcif wait line 0
[    0.313365] RKCIF_WORKMODE_PINGPONG
[    0.314842] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[    0.314942] rkcif rkcif_mipi_lvds: attach to cif hw node
[    0.314970] rkcif rkcif_mipi_lvds: rkcif wait line 0
[    0.315006] RKCIF_WORKMODE_PINGPONG
[    0.316006] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[    0.316039] rockchip-mipi-csi2: Async registered subdev
[    0.318429] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[    0.318459] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[    0.318783] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[    0.318833] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[    0.319158] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[    0.319396] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    0.319652] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.319688] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.319720] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.322658] rkisp rkisp-vir1: rkisp driver version: v01.06.02
[    0.322911] rkisp rkisp-vir1: No memory-region-thunderboot specified
[    0.323135] rkisp rkisp-vir1: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.323177] rkisp rkisp-vir1: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.323208] rkisp rkisp-vir1: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.327098] iommu: Adding device ffb60000.rkispp to group 2
[    0.327161] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[    0.327585] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[    0.327635] rkispp_hw ffb60000.rkispp: can't request region for resource [mem 0xffb60000-0xffb7ffff]
[    0.327899] rkispp_hw ffb60000.rkispp: failed to get cru reset
[    0.328208] rkispp rkispp-vir0: rkispp driver version: v01.06.02
[    0.330669] rkispp rkispp-vir1: rkispp driver version: v01.06.02
[    0.333357] usbcore: registered new interface driver uvcvideo
[    0.333390] USB Video Class driver (1.1.1)
[    0.333913] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.3
[    0.333966] rockchip-iodomain fe020000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8
[    0.334091] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[    0.334217] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    0.334362] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.5
[    0.334408] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc3v3_sys
[    0.334530] rockchip-iodomain fe020000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    0.334652] rockchip-iodomain fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vcc_1v8
[    0.334791] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(1800000 uV) supplied by vcc_1v8
[    0.334921] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[    0.337761] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -7
[    0.338177] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[    0.338657] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -7
[    0.338965] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[    0.341597] Bluetooth: HCI UART driver ver 2.3
[    0.341623] Bluetooth: HCI UART protocol H4 registered
[    0.341977] cpu cpu0: bin=0
[    0.342028] cpu cpu0: leakage=3.375
[    0.342084] cpu cpu0: Failed to get reg
[    0.342115] cpu cpu0: bin-scale=5
[    0.342450] cpuidle: enable-method property 'psci' found operations
[    0.342632] cpuidle: enable-method property 'psci' found operations
[    0.342789] cpuidle: enable-method property 'psci' found operations
[    0.342953] cpuidle: enable-method property 'psci' found operations
[    0.343744] Synopsys Designware Multimedia Card Interface Driver
[    0.344715] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[    0.344800] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[    0.344834] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[    0.344939] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    0.345158] mmc_host mmc0: card is non-removable.
[    0.358182] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.371891] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[    0.371985] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[    0.372014] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[    0.372111] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    0.372248] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.6
[    0.372418] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.3
[    0.408776] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[    0.408866] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[    0.409884] mmc0: new HS200 MMC card at address 0001
[    0.413111] mmcblk0: mmc0:0001 DA4064 58.2 GiB
[    0.414553] mmcblk0boot0: mmc0:0001 DA4064 partition 1 4.00 MiB
[    0.415835] mmcblk0boot1: mmc0:0001 DA4064 partition 2 4.00 MiB
[    0.416970] mmcblk0rpmb: mmc0:0001 DA4064 partition 3 16.0 MiB, chardev (242:0)
[    0.430854]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    0.490079] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.503766] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.503859] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.503892] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.504002] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.505215] usbcore: registered new interface driver usbhid
[    0.505244] usbhid: USB HID core driver
[    0.508002] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.3
[    0.510180] rksfc_base v1.1 2016-01-08
[    0.510907] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[    0.511011] rkflash_dev_init enter
[    0.511044] sfc nor id: 0 0 0
[    0.511065] rkflash[1] is invalid
[    0.511069] rkflash_dev_init enter
[    0.511106] sfc_nand id: 0 0 0
[    0.511125] rkflash[2] is invalid
[    0.511711] NET: Registered protocol family 17
[    0.511814] NET: Registered protocol family 15
[    0.513357] Bluetooth: RFCOMM TTY layer initialized
[    0.513414] Bluetooth: RFCOMM socket layer initialized
[    0.513472] Bluetooth: RFCOMM ver 1.11
[    0.513507] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    0.513542] Bluetooth: HIDP socket layer initialized
[    0.513570] [BT_RFKILL]: Enter rfkill_rk_init
[    0.513589] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    0.514117] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    0.514212] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = USB-WiFi
[    0.514243] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    0.514265] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    0.514329] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 16 flags = 0.
[    0.514414] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    0.514436] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    0.514497] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    0.517702] flash vendor_init_thread!
[    0.517747] flash vendor storage:20170308 ret = -1
[    0.518900] gc2145 1-003c: driver version: 00.01.06
[    0.518951] gc2145_probe---------------00000---------------
[    0.518985] gc2145_probe---------------11111---------------
[    0.519052] gc2145_probe---------------22222---------------
[    0.519078] gc2145_probe---------------222221---------------
[    0.519098] gc2145_probe---------------2222211---------------
[    0.519117] fps =25
[    0.519143] gc2145_probe---------------33333---------------
[    0.519177] m01_b_gc2145 1-003c: Async registered subdev
[    0.519223] rkcif rkcif_dvp: Entity type for entity rkcif-dvp-sof was not initialized!
[    0.520215] ----------i=5
[    0.520263] ----------i=5
[    0.520289] ----------i=5
[    0.520316] ----------i=5
[    0.520448] rkcif_dvp: Async subdev notifier completed
[    0.520480] gc2145_probe---------------44444---------------
[    0.520495] gc2145 1-003c: m01_b_gc2145 1-003c sensor driver registered !!
[    0.521256] sc2210 1-0030: driver version: 00.01.06
[    0.521325] sc2210 1-0030:  Get hdr mode failed! no hdr default
[    0.521788] sc2210 1-0030: could not get sleep pinstate
[    0.522009] sc2210 1-0030: Linked as a consumer to regulator.2
[    0.522198] sc2210 1-0030: Linked as a consumer to regulator.3
[    0.522383] sc2210 1-0030: Linked as a consumer to regulator.4
[    0.522487] sc2210_initialize_controls---------------11111---------------0
[    0.522501] sc2210_initialize_controls---------------11111---------------0 74250000
[    0.528476] sc2210 1-0030: gain_mode 0b02
[    0.528556] sc2210 1-0030: Detected SC2210 sensor
[    0.528712] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: match m00_f_sc2210 1-0030:bus type 4
[    0.528759] sc2210_probe---------------11111---------------hdr_mode0
[    0.528775] sc2210_runtime_suspend---------------11111---------------
[    0.529569] Registering SWP/SWPB emulation handler
[    0.533049] Loading compiled-in X.509 certificates
[    0.536332] rga2: Driver loaded successfully ver:3.2.56726
[    0.536742] rga2: Module initialized.
[    0.584732] vendor storage:20190527 ret = 0
[    0.592120] rockchip_drm_platform_probe----------------001--------------
[    0.592140] rockchip_drm_platform_probe----------------002--------------
[    0.595794] rockchip_drm_platform_probe----------------003--------------
[    0.595893] rockchip_drm_bind----------------011--------------
[    0.596097] rockchip-drm display-subsystem: devfreq is not set
[    0.596612] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093d278)
[    0.596642] dw_mipi_dsi_bind----------------00--------------
[    0.596647] dw_mipi_dsi_bind----------------01--------------
[    0.596671] dw_mipi_dsi_bind----------------02--------------
[    0.596710] drm_of_find_panel_or_bridge  panel ret =0
[    0.596730] dw_mipi_dsi_bind----------------03--------------
[    0.596759] dw_mipi_dsi_bind----------------04--------------
[    0.596786] dw_mipi_dsi_bind----------------05--------------
[    0.596822] dw_mipi_dsi_bind----------------06--------------
[    0.596852] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb09439ac)
[    0.596888] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.596907] [drm] No driver support for vblank timestamp query.
[    0.597081] rockchip_drm_bind----------------010--------------
[    0.597086] show_loader_logo----------------011--------------
[    0.597358] setup_initial_state----------------encoder_funcs->loader_protect--------------
[    0.597430] dw_mipi_dsi_encoder_loader_protect----------------dw_mipi_dsi_encoder_loader_protect--------------b5383acf
[    0.597449] panel_simple_loader_protect: on = 1!
[    0.597515] panel_simple_loader_protect----------------panel_simple_loader_protect--------------b5383acf 1
[    0.597728] show_loader_logo----------------012--------------
[    0.622156] rockchip-drm display-subsystem: fb0:  frame buffer device
[    0.624745] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    0.624802] rockchip_drm_platform_probe----------------004--------------
[    0.625490] input: adc-keys as /devices/platform/adc-keys/input/input0
[    0.628154] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.628261] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.628291] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.628349] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.630265] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.630321] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.630406] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.630459] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.632810] rkcif rkcif_dvp: clear unready subdev num: 0
[    0.632912] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[    0.632946] rockchip-mipi-csi2: No link between dphy and sensor
[    0.634059] rockchip-mipi-csi2: No link between dphy and sensor
[    0.634130] rkcif_mipi_lvds: Async subdev notifier completed
[    0.634940] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    0.641750] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    0.642018] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    0.642048] cfg80211: failed to load regulatory.db
[    0.643216] rkisp rkisp-vir0: clear unready subdev num: 1
[    0.645696] rockchip-mipi-csi2: No link between dphy and sensor
[    0.645757] rockchip-mipi-csi2: No link between dphy and sensor
[    0.645784] rkisp0: Invalid mipi data type
[    0.645813] rkisp0: update sensor failed
[    0.645840] rkisp rkisp-vir1: clear unready subdev num: 1
[    0.646738] rkisp1: Async subdev notifier completed
[    0.649105] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[    0.649150] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[    0.657229] EXT4-fs (mmcblk0p6): recovery complete
[    0.658279] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    0.658381] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    0.660570] devtmpfs: mounted
[    0.662897] Freeing unused kernel memory: 1024K
[    0.663327] Run /sbin/init as init process
[    0.756674] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
NAME=Buildroot
VERSION=2018.02-rc3
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME="Buildroot 2018.02-rc3"
Starting logging: OK
/usr/bin/modetest
Populating /dev using udev: [    1.301277] udevd[118]: starting version 3.2.7
[    1.314813] udevd[118]: specified group 'kvm' unknown
[    1.350607] udevd[119]: starting eudev-3.2.7
[    1.443764] phy phy-ff4c0000.usb2-phy.1: charger = USB_SDP_CHARGER
[    1.607615] gc2145 1-003c: gc2145_power(2721) on(1)
[    1.609037] gc2145 1-003c: gc2145_power(2721) on(0)
[    1.621328] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.621410] rkcif_dvp: rkcif_update_sensor_info: stream[2] get remote sensor_sd failed!
[    1.621428] stream_cif_dvp_id2: update sensor info failed -19
[    1.628491] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.628537] rkcif_dvp: rkcif_update_sensor_info: stream[3] get remote sensor_sd failed!
[    1.628556] stream_cif_dvp_id3: update sensor info failed -19
[    1.631981] rkcif_dvp: get_remote_sensor: remote pad is null
[    1.632019] rkcif_dvp: rkcif_update_sensor_info: stream[1] get remote sensor_sd failed!
[    1.632036] stream_cif_dvp_id1: update sensor info failed -19
[    1.640821] rockchip-mipi-csi2: No link between dphy and sensor
[    1.677575] rockchip-mipi-csi2: No link between dphy and sensor
[    1.684696] rockchip-mipi-csi2: No link between dphy and sensor
[    1.690765] rockchip-mipi-csi2: No link between dphy and sensor
[    1.724068] rockchip-mipi-csi2: No link between dphy and sensor
[    1.836922] sc2210 cmd =80685600
[    1.866231] sc2210_runtime_suspend---------------11111---------------
[    1.876578] sc2210_runtime_suspend---------------11111---------------
[    1.886534] sc2210_runtime_suspend---------------11111---------------
[    1.913160] sc2210_runtime_suspend---------------11111---------------
[    1.959491] sc2210_runtime_suspend---------------11111---------------
[    1.969741] sc2210_runtime_suspend---------------11111---------------
done
Will now mount all partitions in /etc/fstab
Note: Will auto format partitons, remove /.auto_mkfs to disable
Note: Create /.skip_fsck to skip fsck
 - The check might take a while if didn't shutdown properly!
Handling rootfs: /dev/mmcblk0p6 / ext2 rw,noauto 1
Checking /dev/mmcblk0p6(ext2)
[    1.979925] sc2210_runtime_suspend---------------11111---------------
[    2.731514] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
e2fsck 1.43.9 (8-Feb-2018)
rootfs: clean, 6951/65536 files, 171119/262144 blocks
[    2.790685] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
Handling misc: /dev/mmcblk0p2 /misc emmc defaults 0
Unsupported file system emmc for /dev/mmcblk0p2
Handling oem: /dev/mmcblk0p7 /oem ext2 defaults 2
Checking /dev/mmcblk0p7(ext2)
oem: recovering journal
oem: clean, 381/49152 files, 156117/196608 blocks
Mounting /dev/mmcblk0p7(ext2) on /oem
[    3.548644] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Handling userdata: /dev/mmcblk0p8 /userdata ext2 defaults 2
Checking /dev/mmcblk0p8(ext2)
userdata was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
userdata: 27/163840 files (0.0% non-contiguous), 149411/1048576 blocks
Mounting /dev/mmcblk0p8(ext2) on /userdata
[    5.399893] EXT4-fs (mmcblk0p8): mounting ext2 file system using the ext4 subsystem
[    5.413919] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
Handling demo: /dev/mmcblk0p10 /demo ext4 defaults 0
Mounting /dev/mmcblk0p10(ext4) on /demo
[    6.267886] EXT4-fs (mmcblk0p10): recovery complete
[    6.270998] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
Log saved to /tmp/mountall.log
Starting system message bus: done
/etc/init.d/S36load_rv1109_wifi_modules: line 45: can't create /sys/class/rfkill/rfkill1/state: nonexistent directory
load wifi modules: [    6.583260] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[    6.583315] ======== dhd_wlan_init_plat_data ========
[    6.583332] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    6.583347] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: wifi OOB pin isn't defined.
[    6.583361] dhd_wlan_init_gpio: unknown oob irqflags !
[    6.583378] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=-1, oob_irq_flags=0x410
[    6.583392] dhd_wlan_init_gpio: WL_REG_ON=-1
[    6.583421] dhd_wifi_platform_load: Enter
[    6.583437] Power-up adapter 'DHD generic adapter'
[    6.583550] wifi_platform_set_power = 1
[    6.583575] ======== PULL WL_REG_ON(-1) HIGH! ========
[    6.583596] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    6.583616] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    6.687265] [WLAN_RFKILL]: wifi turn on power [GPIO16-1]
[    6.993921] wifi_platform_bus_enumerate device present 1
[    6.993968] ======== Card detection to detect SDIO card! ========
[    6.993985] sdio: host isn't  initialization successfully.
[    9.017307] failed to power up DHD generic adapter, 1 retry left
[    9.033723] wifi_platform_set_power = 0
[    9.033775] ======== PULL WL_REG_ON(-1) LOW! ========
[    9.033793] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    9.033810] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    9.033824] wifi power off
[    9.140592] [WLAN_RFKILL]: wifi shut off power [GPIO16-0]
[    9.140644] wifi_platform_bus_enumerate device present 0
[    9.140660] ======== Card detection to remove SDIO card! ========
[    9.140674] sdio: host isn't  initialization successfully.
[    9.140816] wifi_platform_set_power = 1
[    9.140840] ======== PULL WL_REG_ON(-1) HIGH! ========
[    9.140862] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    9.140885] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    9.247259] [WLAN_RFKILL]: wifi turn on power [GPIO16-1]
[    9.553924] wifi_platform_bus_enumerate device present 1
[    9.553973] ======== Card detection to detect SDIO card! ========
[    9.553989] sdio: host isn't  initialization successfully.
[   11.577268] failed to power up DHD generic adapter, 0 retry left
[   11.593627] wifi_platform_set_power = 0
[   11.593731] ======== PULL WL_REG_ON(-1) LOW! ========
[   11.593751] [WLAN_RFKILL]: rockchip_wifi_power: 0
[   11.593769] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[   11.593783] wifi power off
[   11.700591] [WLAN_RFKILL]: wifi shut off power [GPIO16-0]
[   11.700644] wifi_platform_bus_enumerate device present 0
[   11.700659] ======== Card detection to remove SDIO card! ========
[   11.700OK
[   11.700688] failed to power up DHD generic adapter, max retry reached**
[   11.700703] unregister wifi platform drivers
[   11.700718] wifi_platform_bus_enumerate device present 0
[   11.700730] ======== Card detection to remove SDIO card! ========
[   11.700756] sdio: host isn't  initialization successfully.
[   11.700771] ======== dhd_wlan_deinit_plat_data ========
[   11.700793] dhd_module_init: Failed to load the driver, try cnt 0
[   11.700883] dhd_module_init: Failed to load driver max retry reached**
[   11.700904] dhd_module_init: Exit err=-19
Starting network: OK
Starting connman ... done.
alsactl: load_state:1735: No soundcards found...
Starting ntpd: OK
Starting QDesktop...
gpiochip0: GPIOs 0-31, parent: platform/pinctrl, gpio0:
 gpio-4   (                    |vcc_sd              ) out lo
 gpio-16  (                    |rkwifi_wlan_poweren ) out lo
gpiochip1: GPIOs 32-63, parent: platform/pinctrl, gpio1:
gpiochip2: GPIOs 64-95, parent: platform/pinctrl, gpio2:
 gpio-64  (                    |pwdn                ) out lo
 gpio-65  (                    |reset               ) out hi
gpiochip3: GPIOs 96-127, parent: platform/pinctrl, gpio3:
gpiochip4: GPIOs 128-129, parent: platform/pinctrl, gpio4:
Starting dropbear sshd: OK
Starting fcgiwrap daemon: OK
Starting nginx...
Debug: configfs_init
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0': No such file or directory
[   12.416370] file system registered
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
[   12.461665] using random self ethernet address
[   12.461727] using random host ethernet address
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mass_storage.0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/hid.usb0': No such file or directory
[   12.639788] read descriptors
[   12.639874] read strings
media get entity by name: stream_cif_mipi_id0 is null
media get entity by name: stream_cif_mipi_id1 is null
media get entity by name: stream_cif_mipi_id2 is null
media get entity by name: stream_cif_mipi_id3 is null
media get entity by name: rockchip-mipi-csi2 is null
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rockchip-mipi-dphy-rx is null
media get entity by name: stream_cif is null
[   13.052982] gc2145_enum_frame_interval---------------00000---------------0, 0
[   13.052992] file->index = 0, cfg_num =1
media get entity by name: stream_citerval---------------111111---------------0, 0
                                   f_dvp_id0 is null
media get e[tity by name: stream_cif_dvp_i d1 is null
media get entity by name: stream_cif_dvp_id2 is null
media get entity by name: stream_cif_dvp_id3 is null
 media get entity by name: rkc if-lvds-subdev is null
media1 get entity by name: rkcif-li3te-lvds-subdev is null
media get .entity by name: rockchip-mipi-dphy-rx0 is null
media get entity by nam5e: stream_cif is null
media get entity by name: rkcif-dvp-sof is3 null
108] gc2145_enum_frame_interval---------------00000---------------1, 8198
[   13.053126] file->index = 1, cfg_num =1
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rkcif_dvp is null
media get entity by name: rkcif_lite_mipi_lvds is null
media get entity by name: rkcif_mipi_lvds is null
[   13.065217] sc2210 cmd =8eb656c0
[08:00:13.065059][CAMHW]:XCAM ERROR CamHwIsp20.cpp:973: get isp or ispp info fail, something gos wrong!
register factory : rkmpp
register factory : live555_rtsp_server
register factory : video_enc
register factory : audio_enc
register factory : video_dec
register factory : file_read_flow
register factory : file_write_flow
register factory : filter
register factory : link_flow
register factory : source_stream
register factory : muxer_flow
register factory : audio_dec
register factory : output_stream
register factory : move_detec
register factory : occlusion_detec
register factory : file_write_stream
register factory : file_read_stream
register factory : alsa_playback_stream
register factory : alsa_capture_stream
register factory : v4l2_capture_stream
register factory : v4l2_output_stream
register factory : drm_output_stream
rga_api version 1.3.0_[11] (RGA is compiling with meson base: $PRODUCT_BASE)
register factory : rkrga
register factory : through_guard
register factory : ANR
register factory : AEC
register factory : rockx_filter
register factory : nn_result_input
register factory : draw_filter
register factory : rknn
register factory : face_capture
register factory : rockface_detect
register factory : rockface_evaluate
register factory : rockface_bodydetect
register factory : rockface_recognize
QObject::startTimer: Timers can only be used with threads started with QThread
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
[   13.488721] Freeing drm_logo memory: 12148K
test stdout
insmod NPU modules: [   13.706097] galcore: loading out-of-tree module taints kernel.
[   13.721572] galcore: npu init.
[   13.722888] galcore: start npu probe.
[   13.723140] galcore ffbc0000.npu: Linked as a consumer to regulator.7
[   13.723413] npu: platform_get_irq irq = 67
[   13.723446] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[   13.723465] Galcore version 6.4.6.5.351518
[   13.723482] Galcore options:
[   13.723502]   irqLine           = 67
[   13.723520]   registerMemBase   = 0xFFBC0000
[   13.723538]   registerMemSize   = 0x00004000
[   13.723557]   contiguousSize    = 0x00400000
[   13.723574]   contiguousBase    = 0x0
[   13.723592]   externalSize      = 0x00000000
[   13.723609]   externalBase      = 0x0
[   13.723627]   exclusiveSize     = 0x00000000
[   13.723645]   exclusiveBase     = 0x0
[   13.723760]   bankSize          = 0x00000000
[   13.723794]   fastClear         = -1
[   13.723823]   compression       = 15
[   13.723856]   powerManagement   = 1
[   13.723889]   baseAddress       = 0x00000000
[   13.723912]   physSize          = 0x00000000
[   13.723930]   recovery          = 1
[   13.723947]   stuckDump         = 0
[   13.723961]   GPU smallBatch    = 1
[   13.723974]   allMapInOne       = 1
[   13.723992]   enableNN          = 0xff
[   13.724011]   userClusterMasks  =
[   13.724015] ff,
[   13.724033] ff,
[   13.724051] ff,
[   13.724070] ff,
[   13.724087] ff,
[   13.724106] ff,
[   13.724123] ff,
[   13.724141] ff,
[   13.724157]
[   13.724185]   irqs              =
[   13.724188] 67,
[   13.724201] -1,
[   13.724222] -1,
[   13.724242] -1,
[   13.724259] -1,
[   13.724278] -1,
[   13.724295] -1,
[   13.724313] -1,
[   13.724330] -1,
[   13.724348] -1,
[   13.724365] -1,
[   13.724382]
[   13.724410]   registerBases     =
[   13.724414] 0xFFBC0000,
[   13.724431] 0x00000000,
[   13.724444] 0x00000000,
[   13.724464] 0x00000000,
[   13.724482] 0x00000000,
[   13.724500] 0x00000000,
[   13.724519] 0x00000000,
[   13.724536] 0x00000000,
[   13.724554] 0x00000000,
[   13.724574] 0x00000000,
[   13.724591] 0x00000000,
[   13.724609]
[   13.724636]   registerSizes     =
[   13.724640] 0x00004000,
[   13.724657] 0x00000000,
[   13.724684] 0x00000000,
[   13.724717] 0x00000000,
[   13.724749] 0x00000000,
[   13.724781] 0x00000000,
[   13.724821] 0x00000000,
[   13.724864] 0x00000000,
[   13.724896] 0x00000000,
[   13.724915] 0x00000000,
[   13.724928] 0x00000000,
[   13.724945]
[   13.724973]   chipIDs           =
[   13.724977] 0xFFFFFFFF,
[   13.724995] 0xFFFFFFFF,
[   13.725013] 0xFFFFFFFF,
[   13.725031] 0xFFFFFFFF,
[   13.725049] 0xFFFFFFFF,
[   13.725069] 0xFFFFFFFF,
[   13.725089] 0xFFFFFFFF,
[   13.725107] 0xFFFFFFFF,
[   13.725125] 0xFFFFFFFF,
[   13.725142] 0xFFFFFFFF,
[   13.725158] 0xFFFFFFFF,
[   13.725173]
[   13.725209]   core 0 internal sRAMBases =
[   13.725213] 0xFFFFFFFFFFFFFFFF,
[   13.725232] 0xFFFFFFFFFFFFFFFF,
[   13.725253]
[   13.725281]OK
   core 1 internal sRAMBases =
[   13.725285] 0xFFFFFFFFFFFFFFFF,
[   13.725303] 0xFFFFFFFFFFFFFFFF,
[   13.725321]
[   13.725348]   core 2 internal sRAMBases =
[   13.725352] 0xFFFFFFFFFFFFFFFF,
[   13.725372] 0xFFFFFFFFFFFFFFFF,
[   13.725392]
[   13.725414]   core 3 internal sRAMBases =
[   13.725418] 0xFFFFFFFFFFFFFFFF,
[   13.725431] 0xFFFFFFFFFFFFFFFF,
[   13.725443]
[   13.725465]   core 4 internal sRAMBases =
[   13.725468] 0xFFFFFFFFFFFFFFFF,
[   13.725481] 0xFFFFFFFFFFFFFFFF,
[   13.725495]
[   13.725515]   core 5 internal sRAMBases =
[   13.725518] 0xFFFFFFFFFFFFFFFF,
[   13.725532] 0xFFFFFFFFFFFFFFFF,
[   13.725543]
[   13.725566]   core 6 internal sRAMBases =
[   13.725569] 0xFFFFFFFFFFFFFFFF,
[   13.725583] 0xFFFFFFFFFFFFFFFF,
[   13.725596]
[   13.725616]   core 7 internal sRAMBases =
[   13.725620] 0xFFFFFFFFFFFFFFFF,
[   13.725635] 0xFFFFFFFFFFFFFFFF,
[   13.725647]
[   13.725670]   core 8 internal sRAMBases =
[   13.725673] 0xFFFFFFFFFFFFFFFF,
[   13.725686] 0xFFFFFFFFFFFFFFFF,
[   13.725700]
[   13.725720]   core 9 internal sRAMBases =
[   13.725723] 0xFFFFFFFFFFFFFFFF,
[   13.725738] 0xFFFFFFFFFFFFFFFF,
[   13.725750]
[   13.725771]   core 10 internal sRAMBases =
[   13.725774] 0xFFFFFFFFFFFFFFFF,
[   13.725787] 0xFFFFFFFFFFFFFFFF,
[   13.725799]
[   13.725818]   External sRAMBases =
[   13.725822] 0xffffffffffffffff,
[   13.725835] 0xffffffffffffffff,
[   13.725847]
[   13.725867]   mmuPageTablePool  = 1
[   13.725880]   mmuDynamicMap     = 1Starting vsftpd:
[   13.725893]   isrPoll           = 0x00000000
[   13.725907] Build options:
[   13.725919]   gcdGPU_TIMEOUT    = 20000
[   13.725932]   gcdGPU_2D_TIMEOUT = 4000
[   13.725945]   gcdINTERRUPT_STATISTIC = 1
[   13.731296] Galcore Info: ContiguousBase=0x7f855000 ContiguousSize=0x400000
[   13.736604] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual address=0x400000 size=0x40000
[   13.736660] Galcore Info: MMU mapped core 0 SRAM[1] hardware virtual address=0x440000 size=0x40000
[   13.739674] galcore ffbc0000.npu: Init npu devfreq
[   13.739740] galcore ffbc0000.npu: bin=0
[   13.739793] galcore ffbc0000.npu: leakage=2.125
[   13.740168] galcore ffbc0000.npu: Failed to set pvtm_volt
[   13.740391] galcore ffbc0000.npu: Failed to get pvtm
[   13.740462] galcore ffbc0000.npu: bin-scale=23
[   13.741463] galcore ffbc0000.npu: avs=0
[   13.742107] galcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[   13.742170] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[   13.742329] galcore ffbc0000.npu: failed to find power_model node
[   13.742361] galcore ffbc0000.npu: failed to initialize power model
[   13.747394] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[   13.747514] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[   13.747552] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[   13.747615] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
OK
Starting dnsmasq: [   13.789947] dwc3 ffd00000.dwc3: device reset
dnsmasq: failed to create listening socket for port 53: Address already in use
FAIL
LOG_INFO :*** update_engine: Version V1.1.4 ***.
LOG_INFO :Current Mode is recovery.
[   13.862631] dwc3 ffd00000.dwc3: device reset
[   13.862753] android_work: did not send uevent (0 0   (null))
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf...
input-event-daemon: Adding device: /dev/input/event0...
input-event-daemon: open(/dev/input/event1): No such file or directory
input-event-daemon: open(/dev/input/event2): No such file or directory
input-event-daemon: Start listening on 1 devices...
done
[root@ATK-DLRV1126:/]# [   13.921799] android_work: sent uevent USB_STATE=CONNECTED
[   14.053078] dwc3 ffd00000.dwc3: device reset
[   14.053300] android_work: sent uevent USB_STATE=DISCONNECTED
[   14.121569] dwc3 ffd00000.dwc3: device reset
[   14.121727] android_work: did not send uevent (0 0   (null))
[   14.178355] android_work: sent uevent USB_STATE=CONNECTED
[   14.182399] configfs-gadget gadget: full-speed config #1: b
[   14.182695] android_work: sent uevent USB_STATE=CONFIGURED
start rknn server, version:1.7.0 (7880361 build: 2021-08-16 14:05:08)
I NPUTransfer: Starting NPU Transfer Server, Transfer version 2.1.0 (b5861e7@2020-11-23T11:51:07)
fontfamilies: ("Montserrat")
[   15.661468] of_dma_request_slave_channel: dma-names property of node '/serial@ff590000' missing or empty
[   15.661545] ttyS4 - failed to request DMA, use interrupt mode
[   15.661833] ttyS4 set divisor fail, quot:156 != dll,dlh:0
[   15.662179] ttyS4 set divisor fail, quot:13 != dll,dlh:0
[   15.662660] of_dma_request_slave_channel: dma-names property of node '/serial@ff5a0000' missing or empty
[   15.662697] ttyS5 - failed to request DMA, use interrupt mode
[   15.662916] ttyS5 set divisor fail, quot:156 != dll,dlh:0
[   15.662998] ttyS5 set divisor fail, quot:13 != dll,dlh:0
WARNING: Cannot find style "greywhite" - fallback: "default"
Please check the path in QCoreApplication::applicationDirPath:  "/demo"
[   18.446593] gc2145_enum_frame_interval---------------00000---------------0, 0
[   18.446604] file->index = 0, cfg_num =1
[   18.446689] gc2145_enum_frame_interval---------------111111---------------0, 0
[   18.446719] gc2145_enum_frame_interval---------------00000---------------1, 8198
[   18.446738] file->index = 1, cfg_num =1
[   18.451425] sc2210 cmd =8eb656c0
[   18.552843] gc2145 1-003c: gc2145_power(2721) on(1)
[   18.552971] ----------i=5
[   18.560886] rkcif_dvp: stream[0] start streaming
[   18.560968] ----------i=5
[   18.561566] rkcif_dvp: Allocate dummy buffer, size: 0x00065400
[   18.561637] -----multi_id = 16
[   18.561660] BT1120_CLOCK_SINGLE_EDGES
[   18.561687] rkcif_dvp: set dual edge mode(off,0x1000000)!!!
[   18.561705] RKCIF_CLK_RISING
[   18.561724] V4L2_STD_PAL
[   18.561744] V4L2_MBUS_BT656
[   18.561766] BT1120_TRANSMIT_INTERFACE
[   18.561782] -------val=10010009
[   18.561795] -------val=10010009
[   18.561808] val = 720
[   18.561824] pingpong enter:2924
[   18.561848] pingpong exit:2928
[   18.562126] gc2145 1-003c: gc2145_s_stream: on: 1, 720x576@25
[   18.562158] gc2145->streaming =0 on=1
[   19.553133] sc2210 cmd =401056c5
[   19.553199] sc2210 1-0030: set fmt: cur_mode: 1920x1080, hdr: 0
[   19.553234] sc2210 1-0030: sensor mode: 0
[   19.553770] sc2210 cmd =801056c9
[   19.583836] sc2210 cmd =801056c9
[   19.583932] sc2210 cmd =400456c6
[   19.583978] sc2210 cmd =401056c8
[   19.601599] sc2210 cmd =801056c4
[   19.707056] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: stream on:1
[   19.707134] rockchip-mipi-dphy-rx: data_rate_mbps 222
[   19.851753] sc2210 1-0030: set exposure 0x60
[   19.851819] sc2210 1-0030: recv:48 set again 0x3, again_fine 0x30, set dgain 0x0, dgain_fine 0x80
[   20.015505] rkisp1: tx stream:4 lose frame:3, isp state:0x204 frame:0
[   20.048859] rkisp1: tx stream:4 lose frame:4, isp state:0x204 frame:3
[   20.058461] sc2210 cmd =801056c9
[   20.058629] sc2210 cmd =400456c6
[   20.058683] sc2210 cmd =401056c8
[   20.091663] sc2210 cmd =801056c9
[   20.091759] sc2210 cmd =400456c6
[   20.091784] sc2210 cmd =401056c8
qml: onGlobal_Page_final_process_btnChanged0
ButtonProcessSlot_map "fn_info_boardcast_enable" "0" -------------
[server.c][fn_info_boardcast_enable]:fn_info_boardcast_enable==========
QThread::wait: Thread tried to wait on itself
[   20.125018] sc2210 cmd =801056c9
[   20.125088] sc2210 cmd =400456c6
[   20.125120] sc2210 cmd =401056c8
[   20.158229] sc2210 cmd =801056c9
[   20.158311] sc2210 cmd =400456c6
[   20.158359] sc2210 cmd =401056c8
[   20.191625] sc2210 cmd =801056c9
[   20.191843] sc2210 cmd =400456c6
[   20.191913] sc2210 cmd =401056c8
[   20.224899] sc2210 cmd =801056c9
[   20.224980] sc2210 cmd =400456c6
[   20.225040] sc2210 cmd =401056c8
[   20.258317] sc2210 cmd =801056c9
[   20.258420] sc2210 cmd =400456c6
[   20.258451] sc2210 cmd =401056c8
qml: global_appIndex : 1
qml: normalStartApp  --------1---------ATKCamera
[   20.291984] sc2210 cmd =801056c9
[   20.292056] sc2210 cmd =400456c6
[   20.292085] sc2210 cmd =401056c8
[   20.325234] sc2210 cmd =801056c9
[   20.325313] sc2210 cmd =400456c6
[   20.325346] sc2210 cmd =401056c8
[   20.358316] sc2210 cmd =801056c9
[   20.358413] sc2210 cmd =400456c6
[   20.358446] sc2210 cmd =401056c8
[   20.391747] sc2210 cmd =801056c9
qml: 当前item是0
[   20.391821] sc2210 cmd =400456c6
[   20.391852] sc2210 cmd =401056c8
[   20.425262] sc2210 cmd =801056c9
[   20.425342] sc2210 cmd =400456c6
[   20.425368] sc2210 cmd =401056c8
[   20.458494] sc2210 cmd =801056c9
[   20.458630] sc2210 cmd =400456c6
[   20.458661] sc2210 cmd =401056c8
[   20.491693] sc2210 cmd =801056c9
[   20.491760] sc2210 cmd =400456c6
[   20.491786] sc2210 cmd =401056c8
[   20.524957] sc2210 cmd =801056c9
[   20.525040] sc2210 cmd =400456c6
[   20.525080] sc2210 cmd =401056c8
[   20.558533] sc2210 cmd =801056c9
[   20.558610] sc2210 cmd =400456c6
[   20.558640] sc2210 cmd =401056c8
[   20.591744] sc2210 cmd =801056c9
[   20.591819] sc2210 cmd =400456c6
[   20.591851] sc2210 cmd =401056c8
[   20.625270] sc2210 cmd =801056c9
[   20.625426] sc2210 cmd =400456c6
[   20.625454] sc2210 cmd =401056c8
[   20.658418] sc2210 cmd =801056c9
[   20.658485] sc2210 cmd =400456c6
[   20.658511] sc2210 cmd =401056c8
[   20.691587] sc2210 cmd =801056c9
[   20.691716] sc2210 cmd =400456c6
[   20.691747] sc2210 cmd =401056c8
[   20.724918] sc2210 cmd =801056c9
[   20.724988] sc2210 cmd =400456c6
[   20.725016] sc2210 cmd =401056c8
[   20.758504] sc2210 cmd =801056c9
[   20.758619] sc2210 cmd =400456c6
[   20.758655] sc2210 cmd =401056c8
[   20.792103] sc2210 cmd =801056c9
[   20.792169] sc2210 cmd =400456c6
[   20.792196] sc2210 cmd =401056c8
[   20.825181] sc2210 cmd =801056c9
[   20.825249] sc2210 cmd =400456c6
[   20.825275] sc2210 cmd =401056c8
[   20.858627] sc2210 cmd =801056c9
[   20.858704] sc2210 cmd =400456c6
[   20.858732] sc2210 cmd =401056c8
qml: onGlobal_Page_final_process_btnChangednone
ButtonProcessSlot_map "fn_config_para_main2storage" "none" -------------
[server.c][fn_config_para_main2storage]:fn_config_para_main2storage==========////////////////
[   20.891603] sc2210 cmd =801056c9
[rkipc_server][__rec_configPara_handler]:-----------__rec_configPara_handler------1----100-
[   20.891684] sc2210 cmd =400456c6
[   20.891714] sc2210 cmd =401056c8
[   20.925003] sc2210 cmd =801056c9
[   20.925076] sc2210 cmd =400456c6
[   20.925104] sc2210 cmd =401056c8
[root@ATK-DLRV1126:/]# [   32.058544] vcc_sd: disabling
