楼主 # 2021-12-17 09:42:27
kwongwo
已发帖子: 37
第二批 新唐NUC980 开箱
板子很漂亮,画的很美
启动了一下,openwrt的固件, 没有 root密码,里面没法玩,不知道 杨叔 会不会给密码我们直接玩一下.
就看看LOG
U-Boot 2016.11-g4680eed (Aug 12 2021 - 11:00:18 +0800)
CPU: NUC980
Board: NUC980
DRAM:  64 MiB
NAND:  128 MiB
NUC980 IBR 20180813
Boot from NAND
DDR-OK
NAND boot!D dow#S
CPU: NUC980
Board: NUC980
DRAM:  64 MiB
NAND:  128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   emac
Warning: emac (eth0) using random MAC address - 7e:a4:bf:c0:cd:30
NAND read: device 0 offset 0x200000, size 0x760000
 7733248 bytes read: OK
## Booting kernel from Legacy Image at 00007fc0 ...
   Image Name:   OpenWrt ARM 4.4.194
   Data Size:    3038889 Bytes = 2.9 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
Starti  0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.4.194 (zf@debian9) (gcc version 5.4.0 (LEDE GCC 5.4.0 r0-f446e8e) ) #0 PREEMPT Sat May 9 15:23:54 2020
[    0.000000] Machine model: Nuvoton NUC980 IOT-GateWay Version: 0.1
[    0.000000] Kernel command line: noinitrd ubi.mtd=2 root=ubi0:rootfs rw rootfstype=ubifs console=ttyS0,115200n8 rdinit=/sbin/init mem=64M mtdparts=nand0:0x200000@0x0(u-boot),0x1400000@0x200000(kernel),-(rootfs)
[    0.000000] Memory: 57992K/65536K available (4366K kernel code, 301K rwdata, 1656K rodata, 184K init, 244K bss, 7544K reserved, 0K cma-reserved)
[    0.000000]       .text : 0xc0008000 - 0xc05e9f04   (6024 kB)
[    0.000000]       .init : 0xc05ea000 - 0xc0618000   ( 184 kB)
[    0.000000]       .data : 0xc0618000 - 0xc06636c4   ( 302 kB)
[    0.000000]        .bss : 0xc06636c4 - 0xc06a07e0   ( 245 kB)
[    0.000000] NR_IRQS:545
[    0.000000] clocksource: nuc980-timer5: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 62215505635 ns
[    0.000033] sched_clock: 24 bits at 120kHz, resolution 8333ns, wraps every 69905062489ns
[    0.000733] Console: colour dummy device 80x30
[    0.195441] console [ttyS0] enabled
[    0.198924] Calibrating delay loop... 148.88 BogoMIPS (lpj=744448)
[    0.272783] pid_max: default: 32768 minimum: 301
[    0.277641] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.284333] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.293458] CPU: Testing write buffer coherency: ok
[    0.299416] Setting up static identity map for 0x8400 - 0x843c
[    0.351174] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.361958] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.368558] pinctrl core: initialized pinctrl subsystem
[    0.375983] NET: Registered protocol family 16
[    0.383008] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.397366] <DT> nuc980_dt_device_init +
[    0.455041] <DT> nuc980_dt_device_init -
[    0.462208] pinctrl-nuc980 apb:pinctrl@b0000000: initialized NUC980 pinctrl driver
[    0.597591] SCSI subsystem initialized
[    0.608833] usbcore: registered new interface driver usbfs
[    0.616399] usbcore: registered new interface driver hub
[    0.623266] usbcore: registered new device driver usb
[    0.638091] clocksource: Switched to clocksource nuc980-timer5
[    0.729416] NET: Registered protocol family 2
[    0.737358] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.745016] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.751841] TCP: Hash tables configured (established 1024 bind 1024)
[    0.758649] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.764499] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.771691] NET: Registered protocol family 1
[    0.777208] RPC: Registered named UNIX socket transport module.
[    0.783308] RPC: Registered udp transport module.
[    0.787966] RPC: Registered tcp transport module.
[    0.792766] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.800174] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.812808] Crashlog allocated RAM at address 0x3f00000
[    0.896899] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.981549] io scheduler noop registered (default)
[    0.990074] nuc980_gpio_probe - pdev = b0004000.gpio
[    0.998724] nuc980_dma_probe - pdev = b0008000.dma
[    1.025066] nuc980-dma b0008000.dma: NUC980 DMA ready
[    1.569958] b0070000.serial: ttyS0 at I/O 0xf0070000 (irq = 36, base_baud = 750000) is a NUC980
[    1.581899] b0071000.serial: ttyS1 at I/O 0xf0071000 (irq = 37, base_baud = 9375000) is a NUC980
[    1.592949] b0072000.serial: ttyS2 at I/O 0xf0072000 (irq = 38, base_baud = 9375000) is a NUC980
[    1.604208] b0073000.serial: ttyS3 at I/O 0xf0073000 (irq = 43, base_baud = 9375000) is a NUC980
[    1.615608] b0074000.serial: ttyS4 at I/O 0xf0074000 (irq = 39, base_baud = 9375000) is a NUC980
[    1.627008] b0075000.serial: ttyS5 at I/O 0xf0075000 (irq = 44, base_baud = 9375000) is a NUC980
[    1.638466] b0076000.serial: ttyS6 at I/O 0xf0076000 (irq = 40, base_baud = 9375000) is a NUC980
[    1.650033] b0077000.serial: ttyS7 at I/O 0xf0077000 (irq = 45, base_baud = 9375000) is a NUC980
[    1.660999] b0078000.serial: ttyS8 at I/O 0xf0078000 (irq = 41, base_baud = 9375000) is a NUC980
[    1.678616] nuc980 mtd nand driver version: 20180301
[    1.684991] nand: device found, Manufacturer ID: 0xec, Chip ID: 0xf1
[    1.692499] nand: Samsung NAND 128MiB 3,3V 8-bit
[    1.697099] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    1.704908] nand: SMRA size 64, 60
[    1.709083] Bad block table found at page 65472, version 0x01
[    1.715116] Bad block table found at page 65408, version 0x01
[    1.721899] 3 cmdlinepart partitions found on MTD device nand0
[    1.727699] Creating 3 MTD partitions on "nand0":
[    1.732699] 0x000000000000-0x000000200000 : "u-boot"
[    1.743849] 0x000000200000-0x000001600000 : "kernel"
[    1.755691] 0x000001600000-0x000008000000 : "rootfs"
[    1.767533] mtd: device 2 (rootfs) set to be root filesystem
[    1.774858] mtdsplit: no squashfs found in "rootfs"
[    1.780274] fmi-sm: registered successfully! mtdid=nand0
[    1.787141] RX nuc980_qspi0_probe: dma0chan0 module removed
[    1.793574] TX nuc980_qspi0_probe: dma0chan1 module removed
[    1.803649] RX nuc980_spi1_probe: dma0chan2 module removed
[    1.810349] TX nuc980_spi1_probe: dma0chan3 module removed
[    1.825616] vcan: Virtual CAN interface driver
[    1.831691] slcan: serial line CAN interface driver
[    1.836533] slcan: 10 dynamic interface channels.
[    1.841849] CAN device driver interface
[    1.851341] nuc980-can1 b00a1000.can: nuc980_can1_platform device registered (regs=f00a1000, irq=59)
[    1.871099] libphy: nuc980_rmii0: probed
[    1.880099] PPP generic driver version 2.4.2
[    1.886949] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.895191] nuc980-ehci b0015000.usbh_ehci: Nuvoton NUC980 EHCI Host Controller
[    1.903158] nuc980-ehci b0015000.usbh_ehci: new USB bus registered, assigned bus number 1
[    1.912291] nuc980-ehci b0015000.usbh_ehci: irq 23, io mem 0xb0015000
[    1.938249] nuc980-ehci b0015000.usbh_ehci: USB 2.0 started, EHCI 0.95
[    1.945566] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.952474] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.959774] usb usb1: Product: Nuvoton NUC980 EHCI Host Controller
[    1.965908] usb usb1: Manufacturer: Linux 4.4.194 ehci_hcd
[    1.971474] usb usb1: SerialNumber: b0015000.usbh_ehci
[    1.978666] pinctrl-nuc980 apb:pinctrl@b0000000: pin PE10 already requested by b0015000.usbh_ehci; cannot claim for usb1
[    1.989999] pinctrl-nuc980 apb:pinctrl@b0000000: pin-74 (usb1) status -22
[    1.996783] pinctrl-nuc980 apb:pinctrl@b0000000: could not request pin 74 (PE10) from group usbh-ppwr-ovc  on device apb:pinctrl@b0000000
[    2.009324] usb usb1: Error applying setting, reverse things back
[    2.016766] hub 1-0:1.0: USB hub found
[    2.021224] hub 1-0:1.0: 2 ports detected
[    2.027299] ehci-platform: EHCI generic platform driver
[    2.034099] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.041691] usb_hcd_nuc980_probe, id = -1, name: b0017000.usbh_ohci, 0
[    2.048808] nuc980-ohci b0017000.usbh_ohci: Nuvoton NUC980 OHCI Host Controller
[    2.056216] nuc980-ohci b0017000.usbh_ohci: new USB bus registered, assigned bus number 2
[    2.064908] nuc980-ohci b0017000.usbh_ohci: irq 24, io mem 0xb0017000
[    2.130991] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.137766] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.145083] usb usb2: Product: Nuvoton NUC980 OHCI Host Controller
[    2.151333] usb usb2: Manufacturer: Linux 4.4.194 ohci_hcd
[    2.156783] usb usb2: SerialNumber: nuc980-ohci
[    2.164358] hub 2-0:1.0: USB hub found
[    2.168983] hub 2-0:1.0: 8 ports detected
[    2.176316] ohci-platform: OHCI generic platform driver
[    2.183966] usbcore: registered new interface driver usb-storage
[    2.192199] usbcore: registered new interface driver usbserial
[    2.199716] usbcore: registered new interface driver option
[    2.206391] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.222258] do_sha - sha last has no data!
[    2.226341] alg: hash: Test 1 failed for nuc980-sha1
[    2.231558] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.237958] 00000010: 00 00 00 00
[    2.242458] do_sha - sha last has no data!
[    2.246533] alg: hash: Test 1 failed for nuc980-sha224
[    2.251916] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.258558] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00
[    2.264641] do_sha - sha last has no data!
[    2.269891] alg: hash: Test 1 failed for nuc980-sha256
[    2.274999] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.281658] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.289041] do_sha - sha last has no data!
[    2.293124] alg: hash: Test 1 failed for nuc980-sha384
[    2.298491] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.304891] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.311549] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.318924] do_sha - sha last has no data!
[    2.322999] alg: hash: Test 1 failed for nuc980-sha512
[    2.328383] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.334783] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.341424] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.347824] 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    2.355141] alg: No test for hmac-sha1 (nuc980-hmac-sha1)
[    2.361374] alg: No test for hmac-sha224 (nuc980-hmac-sha224)
[    2.367716] alg: No test for hmac-sha256 (nuc980-hmac-sha256)
[    2.374333] alg: No test for hmac-sha384 (nuc980-hmac-sha384)
[    2.380958] alg: No test for hmac-sha512 (nuc980-hmac-sha512)
[    2.386774] NUC980 Crypto engine enabled.
[    2.410174] usbcore: registered new interface driver usbhid
[    2.415699] usbhid: USB HID core driver
[    2.434249] NET: Registered protocol family 10
[    2.444066] NET: Registered protocol family 17
[    2.449316] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    2.462383] can: controller area network core (rev 20120528 abi 9)
[    2.469166] NET: Registered protocol family 29
[    2.473708] can: raw protocol (rev 20120528)
[    2.477958] can: broadcast manager protocol (rev 20120528 t)
[    2.483908] can: netlink gateway (rev 20130117) max_hops=1
[    2.490891] 8021q: 802.1Q VLAN Support v1.8
[    2.506408] ubi0: attaching mtd2
[    2.871774] ubi0: scanning is finished
[    2.893083] ubi0: attached mtd2 (name "rootfs", size 106 MiB)
[    2.899066] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.905899] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.912874] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.920199] ubi0: good PEBs: 844, bad PEBs: 4, corrupted PEBs: 0
[    2.926166] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[    2.933599] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 565934091
[    2.942799] ubi0: available PEBs: 0, total reserved PEBs: 844, PEBs reserved for bad PEB handling: 16
[    2.952124] ubi0: background thread "ubi_bgt0d" started, PID 1034
[    2.998366] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 1041
[    3.021491] UBIFS (ubi0:0): recovery needed
[    3.109641] UBIFS (ubi0:0): recovery completed
[    3.114333] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    3.121841] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    3.131824] UBIFS (ubi0:0): FS size: 103231488 bytes (98 MiB, 813 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[    3.142374] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[    3.148266] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID FE66F50E-7F9E-4193-91A2-B16196A57DDB, small LPT model
[    3.161708] VFS: Mounted root (ubifs filesystem) on device 0:12.
[    3.169949] Freeing unused kernel memory: 184K
[    3.638599] init: Console is alive
[    3.855699] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    3.915866] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    3.939408] init: - preinit -
[    4.456899] random: jshn: uninitialized urandom read (4 bytes read, 7 bits of entropy available)
[    4.590324] random: jshn: uninitialized urandom read (4 bytes read, 7 bits of entropy available)
[    4.751399] random: jshn: uninitialized urandom read (4 bytes read, 7 bits of entropy available)
[    4.874283] random: jshn: uninitialized urandom read (4 bytes read, 7 bits of entropy available)
[    5.012599] random: jshn: uninitialized urandom read (4 bytes read, 8 bits of entropy available)
[    5.201424] nuc980-emac0 b0012000.emac0: eth0 is OPENED
[    5.207408] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[    8.692916] mount_root: mounting /dev/root
[    8.707349] urandom-seed: Seed file not found (/etc/urandom.seed)
[    8.834874] procd: - early -
[   11.429299] procd: - ubus -
[   11.499708] random: ubusd: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.592949] random: ubusd: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.605574] random: ubusd: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.614966] random: ubusd: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.626924] random: ubusd: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.640558] procd: - init -
Please press Enter to activate this console.
[   12.267308] kmodloader: loading kernel modules from /etc/modules.d/*
[   12.294866] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   12.337824] ip_tables: (C) 2000-2006 Netfilter Core Team
[   12.382283] nf_conntrack version 0.5.0 (909 buckets, 3636 max)
[   12.444316] NET: Registered protocol family 24
[   12.496449] xt_time: kernel timezone is -0000
[   12.535874] kmodloader: done loading kernel modules from /etc/modules.d/*
[   22.558574] nuc980-emac0 b0012000.emac0: eth0 is OPENED
[   22.568016] device eth0 entered promiscuous mode
[   22.615216] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[  109.348258] random: nonblocking pool is initialized
LEDE login:
#1 2021-12-17 15:14:22
yangquan3
所在地: 中国深圳
Re: 第二批 新唐NUC980 开箱
要做就做真开源新唐NUC980开发板子支持openwrt
SDK源代码和硬件原理图PCB和bom所有资料都在这里
https://gitee.com/hewenhao/nuc980_ylx/
