楼主 #1 2020-02-19 10:41:16
pythinker
已发帖子: 215
python3.7 使用 pip 命令安装 PyQt5 软件包了, 也可以手动安装.
E:\>E:\Python37\python.exe -m pip uninstall PyQt5
Uninstalling PyQt5-5.10.1:
  Would remove:
    E:\python37\lib\site-packages\pyqt5-5.10.1.dist-info\*
    E:\python37\lib\site-packages\pyqt5\*
    E:\python37\scripts\pylupdate5.exe
    E:\python37\scripts\pyrcc5.exe
    E:\python37\scripts\pyuic5.exe
Proceed (y/n)? y
  Successfully uninstalled PyQt5-5.10.1
旧的 PyQt5 运行就出错, 所以先卸载:
然后安装新的:
E:>E:\Python37\python.exe -m pip install pyqt5
Collecting pyqt5
  Downloading https://files.pythonhosted.org/packages/46/83/7c27aec708a1eb12812a
0b985eb42eebfe3bb87e294cdca1c4af308d2fa9/PyQt5-5.14.1-5.14.1-cp35.cp36.cp37.cp38
-none-win_amd64.whl (53.1MB)
    3% |█                               | 1.7MB 9.3kB/s eta 1:32:11
Operation cancelled by user
发现安装速度太慢, 所以去下载一个手动安装:
http://pypi.doubanio.com/packages/46/83/7c27aec708a1eb12812a0b985eb42eebfe3bb87e294cdca1c4af308d2fa9/PyQt5-5.14.1-5.14.1-cp35.cp36.cp37.cp38-none-win_amd64.whl#md5=81d3c49eb109cf1293025fe01cf66739
一切OK:
E:>E:\Python37\python.exe -m pip install d:\downloads\PyQt5-5.1
Processing d:\downloads\pyqt5-5.14.1-5.14.1-cp35.cp36.cp37.cp38-none-win_amd64.w
hl
Collecting PyQt5-sip<13,>=12.7 (from PyQt5==5.14.1)
  Downloading https://files.pythonhosted.org/packages/66/a6/3f1609f1a77445a088be
e7490229a4d430c9d0e1afd8ebd185fbc9c6aa57/PyQt5_sip-12.7.1-cp37-cp37m-win_amd64.w
hl (58kB)
    100% |████████████████████████████████| 61kB
 77kB/s
Installing collected packages: PyQt5-sip, PyQt5
Successfully installed PyQt5-5.14.1 PyQt5-sip-12.7.1
楼主 #2 2020-02-19 10:43:40
pythinker
已发帖子: 215
Re: python3.7 使用 pip 命令安装 PyQt5 软件包了, 也可以手动安装.
#!/usr/bin/python3
# -*- coding: utf-8 -*-
ZetCode PyQt5 tutorial
In this example, we receive data from
a QInputDialog dialog.
Aauthor: Jan Bodnar
Website: zetcode.com
from PyQt5.QtWidgets import (QWidget, QPushButton, QLineEdit,
    QInputDialog, QApplication)
import sys
class Example(QWidget):
    def __init__(self):
        super().__init__()
        self.initUI()
    def initUI(self):
        self.btn = QPushButton('Dialog', self)
        self.btn.move(20, 20)
        self.btn.clicked.connect(self.showDialog)
        self.le = QLineEdit(self)
        self.le.move(130, 22)
        self.setGeometry(300, 300, 290, 150)
        self.setWindowTitle('Input dialog')
        self.show()
    def showDialog(self):
        text, ok = QInputDialog.getText(self, 'Input Dialog',
            'Enter your name:')
        if ok:
            self.le.setText(str(text))
if __name__ == '__main__':
    app = QApplication(sys.argv)
    ex = Example()
    sys.exit(app.exec_())
拷贝几行代码: http://zetcode.com/gui/pyqt5/dialogs/
运行: E:\Python37\python.exe d:\8899\x.py
参考: http://zetcode.com/gui/pyqt5/
试一试, 完全OK
#3 2020-02-19 12:24:52
phpweb
可以跑, 谢谢楼主.
