楼主 #1 2019-10-04 21:33:03
已发帖子: 9,473
Ubuntu14.04 测试 medoo 数据库框架
  1. 安装 Composer:
    参考: https://www.digitalocean.com/community/tutorials/how-to-install-and-use-composer-on-ubuntu-14-04
sudo apt-get update
sudo apt-get install curl php5-cli git
curl -sS https://getcomposer.org/installer | sudo php -- --install-dir=/usr/local/bin --filename=composer
也可以用简单的方法, 参考: https://medoo.in/api/new
下载: https://github.com/catfan/Medoo/blob/master/src/Medoo.php
然后用户 php 代码包含:
require 'Medoo.php';
即可。
  1. 安装 Medoo:
    参考: https://github.com/catfan/Medoo
composer require catfan/medoo
composer update
  1. 测试程序:
<?php
// If you installed via composer, just use this code to require autoloader on the top of your projects.
require 'vendor/autoload.php';
// Using Medoo namespace
use Medoo\Medoo;
// Initialize
$database = new Medoo([
    'database_type' => 'mysql',
    'database_name' => 'name',
    'server' => 'localhost',
    'username' => 'your_username',
    'password' => 'your_password'
// Enjoy
$database->insert('account', [
    'user_name' => 'foo',
    'email' => 'foo@bar.com'
$data = $database->select('account', [
    'user_name',
    'email'
    'user_id' => 50
echo json_encode($data);
//         "user_name" : "foo",
//         "email" : "foo@bar.com",
楼主 #2 2019-10-04 21:44:56
已发帖子: 9,473
Re: Ubuntu14.04 测试 medoo 数据库框架
https://medoo.in/api/create
$database->create("account", [
	"id" => [
		"INT",
		"NOT NULL",
		"AUTO_INCREMENT",
		"PRIMARY KEY"
	"first_name" => [
		"VARCHAR(30)",
		"NOT NULL"
// CREATE TABLE IF NOT EXISTS account (
// 	id INT NOT NULL AUTO_INCREMENT PRIMARY KEY,
// 	first_name VARCHAR(30) NOT NULL
	"id" => [
		"INT",
		"NOT NULL",
		"AUTO_INCREMENT"
	"email" => [
		"VARCHAR(70)",
		"NOT NULL",
		"UNIQUE"
	"PRIMARY KEY (<id>)"
	"ENGINE" => "MyISAM",
	"AUTO_INCREMENT" => 200
// 	email VARCHAR(70) NOT NULL UNIQUE,
// 	PRIMARY KEY (`id`)
// ENGINE = MyISAM,
// AUTO_INCREMENT = 200
调用确实非常方便。
楼主 #3 2019-10-04 21:47:20
已发帖子: 9,473
https://medoo.in/api/query
$data = $database->query("SELECT <email> FROM <account>")->fetchAll();
// This query will be translated to:
// SELECT "email" FROM "account"
// If you have set table prefix from initialization, the above query will be translated to:
	"prefix" => "WP_"
$data = $database->query("SELECT <account.email>,<account.nickname>
	FROM <account>
	WHERE <id> != 100
")->fetchAll();
// SELECT "WP_account"."email", "WP_account"."nickname" FROM "WP_account" WHERE "id" != 100
也支持 SQL 语句
