从log上看似乎是屏幕导致启动失败,以下是完整log:
[33]HELLO! BOOT0 is starting!
[35]BOOT0 commit : 88480af
[38]set pll start
[40]periph0 has been enabled
[43]set pll end
[44][pmu]: bus read error
[47]board init ok
[48]ZQ value = 0x2d
[50]get_pmu_exist() = -1
[53]ddr_efuse_type: 0xa
[55]trefi:7.8ms
[57][AUTO DEBUG] single rank and full DQ!
[61]ddr_efuse_type: 0xa
[63]trefi:7.8ms
[65][AUTO DEBUG] rank 0 row = 13
[68][AUTO DEBUG] rank 0 bank = 4
[71][AUTO DEBUG] rank 0 page size = 2 KB
[75]DRAM BOOT DRIVE INFO: V0.33
[78]DRAM CLK = 528 MHz
[80]DRAM Type = 2 (2:DDR2,3:DDR3)
[83]DRAMC read ODT off.
[85]DRAM ODT off.
[87]ddr_efuse_type: 0xa
[90]DRAM SIZE =64 M
[92]dram_tpr4:0x0
[94]PLL_DDR_CTRL_REG:0xf8002b00
[96]DRAM_CLK_REG:0xc0000000
[99][TIMING DEBUG] MR2= 0x0
[103]DRAM simple test OK.
[106]dram size =64
[108]card no is 0
[109]sdcard 0 line count 4
[112][mmc]: mmc driver ver 2021-04-2 16:45
[121][mmc]: Wrong media type 0x0
[124][mmc]: Try SD card 0
[134][mmc]: HSSDR52/SDR25 4 bit
[137][mmc]: 50000000 Hz
[139][mmc]: 240 MB
[141][mmc]: SD/MMC 0 init OK!!!
[193]Loading boot-pkg Succeed(index=0).
[196]Entry_name = opensbi
[199]Entry_name = u-boot
[203]Entry_name = dtb
[205]mmc not para
[207]Jump to second Boot.
OpenSBI auto-t113-linux-V0.8-3-ge39e937
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
| | | |_ __ ___ _ __ | (___ | |_) || |
| | | | '_ \ / _ \ '_ \ \___ \| _ < | |
| |__| | |_) | __/ | | |____) | |_) || |_
\____/| .__/ \___|_| |_|_____/|____/_____|
|_|
Platform Name : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs : 1
Current Hart : 0
Firmware Base : 0x41fc0400
Firmware Size : 75 KB
Runtime SBI Version : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0 : 0x0000000041fc0000-0x0000000041fdffff (A)
PMP1 : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
PMP2 : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
PMP3 : 0x0000000000020000-0x0000000000027fff (A,ÿ
U-Boot 2018.07-ge987def5-dirty-config-dirty (Apr 03 2026 - 21:02:33 +0800) Allwinner Technology
[00.294]DRAM: 64 MiB
[00.296]Relocation Offset is: 01efd000
[00.301]secure enable bit: 0
[00.303]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
sunxi flash map init
SPI ALL: ready
[00.314]flash init start
[00.316]workmode = 0,storage type = 1
[00.319][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[00.325][mmc]: get sdc_type fail and use default host:tm1.
[00.331][mmc]: can't find node "mmc0",will add new node
[00.336][mmc]: fdt err returned <no error>
[00.340][mmc]: Using default timing para
[00.343][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.362][mmc]: card_caps:0x3000000a
[00.365][mmc]: host_caps:0x3000003f
[00.369]sunxi flash init ok
[00.371]line:703 init_clocks
[00.374]drv_disp_init
[00.386]drv_disp_init finish
GUID Partition Table Entry Array CRC is wrong: 0xfeea7850 != 0x5d9f0dd2
part_get_info_efi: ERROR: Invalid GPT
part_get_info_efi: Using Backup GPT
[00.528]Loading Environment from SUNXI_FLASH... OK
[00.548]boot_gui_init:start
[00.551]set disp.dev2_output_type fail. using defval=0
没有什么头绪,有大佬知道怎么解决吗
