目标板 /etc/config/network 文件是来自于openwrt 源文件哪里呀
www.trtos.com 极客虫 ,makeymakey,arduboy 爱好者
openwrt_widora$ find . |grep etc/config/network
./package/base-files/files/etc/config/network
./feeds/luci/contrib/uci/hostfiles/etc/config/network
看下这个是不是你所要的:
openwrt_widora$ cat ./package/base-files/files/etc/config/network
Copyright (C) 2006 OpenWrt.org
config interface loopback
option ifname lo
option proto static
option ipaddr 127.0.0.1
option netmask 255.0.0.0config interface lan
option ifname eth0
option type bridge
option proto static
option ipaddr 192.168.99.1
option netmask 255.255.255.0
option ip6assign 60
config interface wan
option ifname apcli0
option proto dhcp
config globals globals
option ula_prefix autoopenwrt_widora$ cat ./feeds/luci/contrib/uci/hostfiles/etc/config/network
VLAN configuration
config switch eth0
option vlan0 "0 1 2 3 5*"
option vlan1 "4 5"Loopback configuration
option ifname "lo"
option proto static
option netmask 255.0.0.0LAN configuration
option type bridge
option ifname "eth0"
option proto static
option ipaddr 192.168.1.1
option netmask 255.255.255.0WAN configuration
option ifname "wlan0"
option proto dhcp
目标板上面的/etc/config/network 文件打开是这两个文件叠加的
一般的network文件来自于
平台定制的network文件来自于
target7linux/xxx/base-files/files/etc/config/network
后者会直接覆盖前者
